Question about Health & Beauty
The shaver sat, in a safe environment, for about a year. naturally, the battery wasn't working, so I plugged it in to charge it. It's been charging for about 2 hours, but nothing seems to be happening. When I press the of/off button it lights, but no "buzzzz". Am I doing something wrong, do I need to be more patient, or should I just get a new one? Thanks for any help you can provide. Michael
  • 35 Answers
The battery has died because it was left discharged for too long. If you can get a replacement battery you should if it is a reasonable cost compared with replacing the shaver. Can you get the battery out? If so I will try to help further
Posted on Mar 15, 2011
Battery not charging even after I replaced it with a new one
recheck your solder connections and ensure that polarity is correct
Apr 20, 2013 | Health & Beauty
My Mephisto 979 will not hold a charge or work directly from electric point .Previously it would only work directly pluged into the electric point. I imagine there are rechargable batteries in it that need...
The procedure for removing the batteries at end of life for recycling is described in the user manual, naturally no instructions are given for re-assembly - take notes as you take it apart and better yet do sketches. The batteries are standard 800mAh NiMh AAA with nickel plated SS solder mounting ribbons.
Mine was bought as a spare and sat on a shelf unused for 3 years - when I went to use it the power unit didn't work due to dodgy soldering on the internal pcb.
Feb 23, 2011 | Carrera Health & Beauty
Worked fine, next time would not run at all. 1.5 years old. Light showes charging and charged OK
mcdevito75 here, It"s possible, an Old battery would show a full charge and still not be fully charged or even charged enough to run the shaver, try changeing the battery--ies.
Jun 30, 2010 | Health & Beauty
My Norelco electric shaver #1378/E does not work any more after years of good service. The green charging light is on when plugged in and it flashes when the machine is plugged-in for a time. I...
When your shavers batteries get old enough, they will internally short out or severely corrode. If they internally short out, you will not be able to run the shaver even on the cord. If the batteries are severely corroded, the corrosion may interfere with the switch or wiring causing it not to work. To get it running, you will need to change the batteries and maybe do some work with the wiring and/or switch.
Batteries can be purchased at shaveroutlet.com. They also do repairs if you need it
ShaverOutlet com The Ultimate Shaver Source
Mar 27, 2017 | Norelco Reflex Shaver 5885XL Electric...
Braun 5614 rechargeable cordless shaver light flickers
Your batteries are starting to degrade, but the good news is they're still holding a charge for a week, so you really don't need to rush to replace them at this point.
The flickering of the charged indicator is normal, as the shaver is still plugged in and the batteries are fully charged. The flickering is due to the batteries chemicals breaking down, and as such, the charge cycle keeps "topping" them off while it's still plugged in.
When you finally aren't able to get a decent amount of cordless operation and run times from your shaver, then you'll want to get them replaced, whether you decide to do that yourself or have it done by a professional service center, is up to you.
Here's a reference for your future use. www.electricshaver.com carries replacement (factory OEM) batteries for most brands of shavers and they also will provide the repair/replacement service for you, should you decide you don't want to do it yourself. You can also give them a call at 1-888-476-1785 and request a price quote, etc.
Anyway, your shaver is working fine and all you need to do is make sure you're not letting the shaver stay plugged in and charging constantly for more than a day, since any "extra" chargind isn't doing anything except keeping the batteries at a constant state of charge. Heat is a byproduct of charging and discharging any battery and as such, you want to allow for a cool down period before recharging them.
I tend to use my shaver until it is almost completely discharged before recharging it. By doing this, you can get the longest working life out of your batteries before you'll have to replace them.
Hope you find this Very Helpful and best regards!
Oct 21, 2009 | Braun Flex XP 5614 Electric Shaver
I purchased phillips series 7100 on 27th Nov. 2007 and it is now not holding the charge. I have adherd to the 8hr. charging & there is nothing wrong with the supply to the razor. As this is within the...
It sounds like your batteries are no longer able to hold a charge and are in need of replacement. With all rechargeable shavers, once the batteries are incapable of holding even a minimal charge, the shaver becomes unable to be used, sometimes even wih the power cord plugged into an outlet. My Braun shavers all worked for about a year after it would no longer operate on battery power alone, then the shavers all stopped working regardless of being plugged in directly to an outlet.
As you mentioned you are still under the warranty period, I would suggest you contact the company and request warranty service for your shaver.
if you weren't under warranty, I would advise getting the replacement batteries and doing a repair yourself.
Sep 11, 2009 | Philips Health & Beauty
Norelco 8894XL will not take a charge
Sounds like you're getting to the end of your natural battery life. As for replacing the batteries, it's not an easy job. You need to have a special Torx screwdriver to undo the screws.
The batteries are soldered onto the Control Board (it's unfortunately not just a case of cracking open the case and putting in batteries in an instant)
It may be worth speaking to your local Philips Service Center (refer to www.philips.com)
Not being at work, I can't check whether your shaver is a mains/rechargeable, but if you plug it in and it works full power immediately you've got a workaround. I usually recommend if you're replacing a shaver to spend a little more $$'s to get one that is mains and rechargeable so that when the batteries die, the shaver is still useable.
Apr 15, 2009 | Norelco 8894 XL Electric Shaver
Braun Shaver 360 Complete #8985
the 110 plugin goes into a circuit which changes AC to DC for charging the internal NiCad batteries. If there is NO charge whatsoever in the batteries, the shaver will not work. If you have any electronics background a simple test with a VOM will determine if the bridge rectifier is putting out any DC.[you must disassemble the shaver] If you have no experience on circuits take it to a repair location.
Sep 10, 2007 | Braun 360° Complete 8985 Electric Shaver
Motor does not start.
electric shaver hq5812 charges,light is on but does not cut efficiently
Aug 25, 2007 | Philips Philishave HQ5812 Electric Shaver
Health & Beauty Logo
44 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
