Question about Health & Beauty
My quickie will only turn to the right--will not go straight--seems like the right wheel is not engaging.
    Scholar:
  • 50 Answers
Hi pedio869
I have seen this too often. Use a programmer to determine which motor has a proble, but I think it is the right one. Durable Medical Equipment Companies (DME) can send a tech out.
1. Check all connections on your right motor.
2. Check your brushes on the right motor. (need at least 1/4 inch)
3. Your brake may be bad. Your Tech can check this for you.
4. You may have a bad motor.
This is the website for your chair.www.sunrisemedical.com You can enter you zip code for a tech near you.
Good Luck
mimobility
Posted on May 05, 2011
How do I get the left wheel of a Murray snow thrower to engaged when the traction lever is engaged?
You will find there is a shear pin that has broken in the wheel that will not engage. Not sure if its a pin or bolt. I had to replace one several years ago.
Jan 24, 2016 | Murray Feiss Murray 27" Dual Stage Snow...
New holland T7050 4wd does not de engaged in the auto setting position while turning the steering wheel left or right
It may be low on lube and binding when wheels are turned keep them straight and try that - check & change the oil in the transfer case
Nov 11, 2014 | Garden
Slight noise when turning left. RF hub bearing?
Wheel bearing by the sounds of it. These cars are known for wheel bearings going bad. Hope this helps
Jan 04, 2013 | 1997 Chevrolet Cavalier
The stroller wants to turn to the right, it wont stay straight.
Turn stroller upside down (sans baby ;-) First spin each back wheel to check it turns freely and it's fully engaged into the chassis. Front wheels should spin easy and rotate 360. If this is all good check the handle locks, are both sides locked or is only one side locking causing the handle to twist and put uneven pressure on the chassis.
Nov 01, 2010 | Bugaboo Cameleon Stroller
Stuck with this problem
The front axle isnt disengaging completely. You need to probably replace the vaccum solinoid located right above your distributor on the firewall. To test you simply disconnect the two vaccum lines and splice them together. Then turn the 4wd on and see if all is normal.
Mar 16, 2010 | Chevrolet Blazer Cars & Trucks
4x4 transimission clunks when engaged?
When engaging the 4WD system, you are pulling the lever on the Transfer Case right? Not the transmission, it's a different gearbox.
There were several versions of transfer cases that used both full and part-time 4 wheel drive.
From your description this sounds like a part-time transfer case.
Going with that, it is somewhat normal to hear and feel a mild clunk when engaging 4WD high range, especially if you are at a complete stand-still or under full throttle.
Try engaging 4WD High while slowly rolling at idle - no throttle. It should pull in fairly smoothly.
Once 4WD is engaged it will literally LOCK the front and rear axles together. So do not do it on hard dry pavement.
These older style 4WD systems need a little "give" especially when turning. The engineers assume you are not engaging 4WD unless you are in a somewhat slippery scenario.
Many CV joints, axles, U-Joints, differentials, and transfer cases are damaged and broken by folks who don't understand this.
Reading the owners manual should provide a clearer description of what you've got.
Bear in mind that when you come out of 4WD it may not completely release, again due to hard pavement binding up the axles. You can try this: backing up 10-25 feet in a straight line, or getting one set of wheels on the shoulder or in some gravel. That should allow it to release the transfer case and go back to everyday 2WD high.
I hope this helps.
May 14, 2009 | 1996 Jeep Grand Cherokee
Hi, I have a flat rear wheel. I must remove the wheel to repair it. I've removed the central locknut, but the wheel does not come out. There seems to be something else that must be done to remove the...
wd-40 and a rubber mallet tap around the wheel so not to bind one side, or you may have to take it to a dealer with a wheel puller, PS do not lose the key that holds the axle to the wheel
Apr 21, 2009 | Quickie Wheelchairs Quickie Aspire Power...
2000 Toyota Camry - car ignition seems to be jammed or keys worn - has a transponder key just won't turn
What you have is the anti-theft portion of the steering column has became engaged. When you remove the key from the ignition, there is a pin that retracts, and, when the steering wheel is turned, this pin enters a hole in the column's steering shaft. This prevents the car from being "steered" if someone defeats the ignition switch, while trying to steal it. This locking function will not happen if the car is parked with the front wheels straight ahead; the only time the locking function occurs is when the steering wheel is turned left or right, as in parking whilst turning the steering wheel. This is a normal occurrance, the locking of the steering wheel, as it denies steering to potential theives.
SOLUTION: When the key will not turn, try to turn the steering wheel to the left of right (whichever way it is "turned" to), and, simultaneously, turn the key in the ignition. The "turning" of the wheel relaxes the tight fit of the pin into the hole, and then the key will turn, as it retracts the locking pin from the hole in the column. Hope this helps; and thank you for choosing FixYa!
Oct 12, 2008 | 2002 Toyota Camry
Health & Beauty Logo
227 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
