Question about Hotpoint NVL333EY Electric Dryer
Dryer hums when start switch is turned
My dryer is a Hotpoint NCL333EB (made Nov '03). The other day, after being shut off to check the load, the dryer would not restart. It only hummed when the switch was turned.
All of the suggested solutions I have read mention popping the top of the dryer. However, there does not appear to be any way to do this. Opening the front door reveals no accessible screws for the top panel.
  • Anonymous Nov 29, 2008
    dryer hums byt won't start
  • berkeleyins Dec 07, 2008
    when i tape down the door switch and turn the tub inside it starts. however when i stop it and try to start it again it starts the humming sound and will not start unless i manually start it
  • 481 Answers
You don't have to "pop" the top off the dryer. the only thing you can do to possibly solve this problem without a professional is to:
  • tape down the door switch with strong tape, or have someone else hold it down.
  • physically turn the tub inside the dryer while pushing the start switch.
  • this will hopefully loosen whatever has the motor stuck.
if this does not work then the motor in the dryer might be bad or going bad, especially if a burning smell is present when you hear the humming sound.
Posted on Aug 01, 2008
Hummin noise hotpoint TDC32P dryer
That noise is usually associated with a failed AC motor that turns the dryer drum.
Dec 01, 2016 | Hotpoint Dryers
Hotpoint drier model tcd970k won"t start flashing on languages
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!!
Oct 01, 2014 | Hotpoint Dryers
I have a Hotpoint Dryer NVLR333ETOWB, I opened the door mid cycle, to check on load, make sure it was drying, I shut the door, and when I turn the start knob, all I get is a buzz, and the dryer does n
Electric dryer no start does nothing
Sep 29, 2014 | Dryers
It will not come when i shut the door
if you know it worked proper before. it may just be the door switch itself. it will not start if switch is bad. to check turn off power to dryer, remove the 2 wires on the switch, tape these wires together.try to start it. if it starts its a bad switch. hope this helps! good-day!
Nov 11, 2012 | Hotpoint Dryers
Our DLB2650B Hotpoint dryer will not start. When I turn the start switch to on, something just hums, and that's it.
The thermal cut-off will just turn off the element if the thermostat fails to. Did you try troubleshooting the motor?
May 22, 2012 | Dryers
Dear Expert, When I went to turn on my Roper dryer it made a humming sound for a few seconds then quit, without out the dryer ever starting. I then had my wife depress the start know while I held the...
check and see if there is any thing in the dryer vent if not.open the door hold the door switch in like the door is shut.have your wife push the start switch in and turn the drum counterclock wise if it starts then the motor has gone bad if it hums still its still the motor.if it does start stop the dryer and try restarting several times sometimes they get a dead spot and it may work for years or may die tomorrow but these are a couple of things to try good luck
Dec 19, 2010 | Dryers
I have this same dryer. I was drying a load of clothes stopped it mid cycle to get something out when I went to restart it would not do anything but hum. Can this be fixed?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 07, 2010 | Hotpoint NBXR333EGWW Dryer
I have a tumble dryer.
Sounds as if the door switch is the problem. This is normally a safety switch that stops the dryer when the door is opened.
Unplug the dryer.
Remove the door switch and check the switch condition with a continuity meter after removing the wires. Try turning the switch on and off....the meter should read power on and off when you do that.
You may have to remove the front of the dryer to get to the door switch.
Good luck,
I hope this helps
Oct 05, 2009 | Hotpoint Dryers
HOTPOINT KEEPS FLASING F-03
The error code F03 indicates that the wash thermistor is open or short circuit.
Check heater element and thermistor,if ok, then you need to call an engineer.
Sep 22, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint NVL333EY Electric Dryer Logo
106 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
