Question about Denon AVR-485 Receiver
I'm looking for an "Input Selector" knob. Can you
  • 56 Answers
There are two knows on the front of the radio. The one on the left is the input selector and the knob on the right is for volume adjustment.
Posted on Mar 14, 2011
The input selector knob won't change the input and I have no sound.
Your receiver has gone to receiver heaven. With labor costs being what they are and the good inexpensive electronics available, it might be better to replace than repair.
Sep 06, 2015 | Audio Players & Recorders
The input selector switch has a mind of its own and changes when it likes to what it likes. There is a clicking relay sound when it occurs. Is this a faulty relay or a dirty switch. (Sorry about previ
I havd the same issue. u need to get a good contact cleaner and spray the selector rod( remove knob first with preamp facing up), the liguid will find leak into selector and clean contacts.
after doing mine, the slector knob feels more solid when turned and does not change input anymore.
Junior
Jan 04, 2013 | Technics Audio Players & Recorders
What is the heat selector knob?
This allows you to adjust the temperature to match what you are drying. Some fabrics and clothes require low heat or you may only be drying a small amount of clothes and don't need much heat. You also may not want high heat to avoid shrinkage of some clothes.
Jul 16, 2012 | Avanti D110 Electric Portable Dryer
The imput selector on my technics su-c800um2 stereo controller behaves erratically
This is due to a possible fault in the digital logic switcher which is at the input selection and could be a failure of the logic gate or a fault in the subprocessor IC.
You can remove and clean the amplifer if there is noticable dirt , also check for DRY SOLDER or faulty connector or joints if a TAP bring this fault up.
Jul 02, 2012 | Technics Audio Players & Recorders
We have a DENON L.C twin transformer amplifier PMA-735R that has an input selector that freaks out now and again. Recently it has gotten worse, it just goes back and forth between tuner and cd etc. for...
Hi Readers to of Fixya,
This entry is January 22, 2016.
I own a Denon PMA 735R which I bought new in 1999, it is very good Amp; starting about a few years ago the input selector would occasionally randomly jump from CD to Phono to Tape etc., but would always end up back at CD so it was not terribly annoying until a few days ago when it started happening all the time. I am a very knowledgeable electronics person (I built musical keyboards at one time) so my thought was just that it was a dust problem and I started with that premise. I fixed it using an Electrical Parts Cleaner spray and here is how I did it:
I unplugged it, removed the CD input RCA cables and removed the L & R speaker cables and took it off its shelf and set it on a towel on my soft sofa; I removed the casing by unscrewing four big silver screws on the sides (my model is silver) and the three small black screws on the back top; I removed the Input Selector indicator knob on the front and the Record Out Selector indicator knob and the Volume knob, I then removed the small nut that holds the three of them tightly in place to the front panel; I then stood it on its back so that the front was facing up; I then sprayed my Electrical Parts Cleaner spray into the Input Selector indicator post liberally and then put the knob back in place and kept turning the indicator back and forth for a few minutes to work the cleaner inside the post down into the circuit board connection; I did the same with the Record Out Selector indicator post and I did the same with the Volume post; I then put the small nuts back on the three posts and tightened them; I then put the knobs back on the three posts; I then stood it back on its normal upright position and put the casing back on and then the screws; I placed back on its shelf and hooked up the cables and switched it back on and played my CD's, it has been working perfectly fine. The whole process took less than 30 minutes.I hope this helps.
Feb 20, 2012 | Denon Audio Players & Recorders
Su-c800u pre-amp switching not steady, keep darting from one mode to another and disrupting smooth flow of music
I had the same issue.the contacts on selector switch is dirty.All u need to get a good contact cleaner and spray the selector rod( remove knob first with preamp facing up), the liguid will find leak into selector and clean contacts.
Junior
Jan 14, 2012 | Technics Audio Players & Recorders
I have a Whirlpool electric dryer, it is a Duet with a model # of: GEW9250PW1. When I try to select the the "normal" setting on the automatic side, it lights up the delicate light and has the...
Is the selector knob loose on the stem? Look on the knob to see if there is a set screw of some sort that you can tighten to set it where it belongs, it just seems it's loose and isn't pointing to where it should. Let me know if this works or not,
Please rate and comment, Thank you,
Joe
Sep 01, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have " E
E1 - Control board problem
Notes: C, E
C:
Disables clean mode in Thermador device, allows cook and microwave
E:
1. Turn the clock selector knob to OFF
2. "Tweak" the oven control by turning the clock selector knob slightly to the left
(counter clockwise).
This may stop the flashing message/beeping and clear the display window.
Hope helps.
Jul 24, 2011 | Thermador T18BF70FSE Freezer
Boots slowly , takes 10min ( bad caps?) and have broken fx selector knob are parts available ? I'm in Canada and the music store I deal with says that Behringer is very slow to resspond to ...
Hi, It is not on selector knob, but it could be on capacitor(s). As stabilizer capacitor has role to maintenance the good power feeds to system. Please check it then.
Regards
Feb 12, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Input selector on my Yamaha RX-V596 stuck
Hi Dush
Sounds like the processor has locked up in the unit. Try powering it right down from the wall socket for a day to reset, and then retry operation. If that does not work, leave it disconnected for about 10 days to erase backup memory completely and then try again. Good luck. Don't forget to give me a "FixYa" rating if this works. If it doesn't, get back to me in here and we can talk more about it.
regards
Graeme
Sep 16, 2007 | Yamaha RX-V596 Receiver
Denon AVR-485 Receiver Logo
75 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
