Question about Canon CanoScan 5000F Flatbed Scanner
Using Canoscan program start to scan, Message given :"adjusting lamp" Then after peroid of time Message given: "Can not scan, Reason: Lamp may not be warmed up." Lamp does light. Should be warm in 5 minutes. Orginal problem was no power. Bought replacement power adapter. Now have lamp problem. when acquiring from scanner it does not complete and gives reasons as bulb heating or object out of place etc. I checked scanner in control panel and it passes tests. I have removed all and reinstalled and the problem remains. XP Pro
2 Suggested Answers
SOURCE: Canon Scanner 5000F fails when adjusting lamp before scan.
Have the same problem. Suspect a lamp problem but cannot find any info/help to check lamp or to replace it
Posted on Oct 15, 2009
Have just been given a canoscan lide 20, i have downloaded the drivers and the canoscan toolbox but now im lost. When I push the SCAN button I get a message that asks me to 'specify the program where the...
Whichever program you wish.
MSPAINT comes with the operating system, so you may want to point it there until you get a better program like photoshop or corel photopaint.
Mar 04, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
Re CanoScan 9950F: I opened Toolbox (v. 4.9.3.4), selected Scan setting "auto mode". Under "Save Scanned Image", I ttyped in a "File Name" , Saved it as JPEG/Exif, For...
Hello
Actually you do have to select a program for working with photographs such as Photoshop, or Adobe Elements, maybe Microsoft Paint or Picasa maybe. Then your scanner will scan and the pictures will be saved and they'll be opened in the photo program you have chosen afterwards.
Jan 04, 2011 | Canon CanoScan 9950F Flatbed Scanner
My canoscan 8400F suddenly stopped working last week. I had been scanning slides thru Photoshop when on my next scan attempt, I got this message: Cannon scan for these reasons: -The original may not...
You have to remove the white protective sheet from the the lid. Once you remove it you will be able to scan film. Also make sure the lock button is not in the lock position.
Open the Canoscan Toolbox.
Click the Save option.
Put a check in the box that states "Display the Scanner Driver".
Click Scan.
Click the Advanced Mode tab.
Make sure Select Source is set to "Platen".
Click the Preview button at the top left
Another thing is this can be caused by a faulty FAU cable. One or more of the eight wires within this cable has fractured
Oct 16, 2010 | Canon CanoScan 8400F Film Scanner
May 27, 2009 | Canon CanoScan 5000F Flatbed Scanner
Adjusting the lamp
Hi,  This is normal for the 4200F and it's just the time taken to warm the scanning lamp up. Once it's warmed up it shouldn't need to go through the process again for any additional scans, unless it's had long enough to cool down again of course.
I've noticed from another answer to an earlier question that if it's a big problem you can change the following keys in your registry:
HKEY_CURRENT_USER\Software\Canon\ScanGear\8.6\Devices\CNQ4200
 Energy save changed to 1
 Lamp Off Time changed to 0
Looks like this would prevent your lamp switching off at all unless you unplugged your scanner which would undoubtedtly shorten your bulb life. It may be a better idea to play about with the 'lamp off' key number until it just stays on long enough to not cause you problem.
Cheers, Derek
Dec 24, 2008 | Canon CanoScan 4200F Flatbed Scanner
Canoscan 20
I had the same problem..the way to get around this is to open the toolbox and click "Save" instead of "Scan" After you do this you just create a file name and save it into a folder..also make sure you change the "save as type" to JPEG
Dec 18, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan 4400 won't scan
Try disconnecting other USB devices to determine if it is being caused by some other device.
Mar 21, 2008 | Canon CanoScan 4400f MultiFunction Color...
Error message 2-178-0. What does this mean.Changed drivers but no change in message?
Try this:
Open the CanoScan Toolbox.
Click Scan.
Click the Preview button at the top left.
If the error still occurs, then most likely it will be a service issue.
One thing to check...see if the inside lamp illuminates when you turn the scanner on using the power button at the back left side of the scanner.
Jan 31, 2008 | Canon CanoScan 8400F Flatbed Scanner
Which program do i use to transfer the scanned image too?
Sounds like the CanoScan is looking for a photo enhancing/utility program. Programs for this purpose are Adobe PhotoShop, PaintShop Pro, ACDSee, or even the simple Windows Paint.
Additionally, the CanoScan Toolbox might have a basic photo utility program. Normally basic photo utility programs like this are included in the CD installer of a scanner, a digicam or even most color printers.
Hope this be of some idea/help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 01, 2007 | Canon CanoScan LiDE 25 Flatbed Scanner
Error message when scanning
Seen this B4 ya scanner system board is borked... the power Supply failure is a symptom.. Probably ya port inerface/PSU ... so it's either shop it or ship it ... :)
Aug 24, 2007 | Canon CanoScan D1250U2F Flatbed Scanner
Canon CanoScan 5000F Flatbed Scanner Logo
64 people viewed this question
old marine
old marine
