Question about Garden
1960 Allis Chalmers D17 lift arms won't go down. need help ASAP!!!!!!!!!!! Raised round bale ( about 1100 lbs.) now unable to lower bale. Thats with the engine running and off.
SOURCE: Allis chalmers AC 5040 is leaking water/fluid
looking for in the oil cooler inside the radiator maybe is broken.
Posted on Jul 11, 2009
SOURCE: What is the correct way to hook up the starter
Well first make sure that the routing coil is clean of debris and dirt. Then you are going to want to oil both sides before assembly. The cellinoid connects the same way an oscillating pendullum does. Just with a bolt! Easy as that on both ends....just be sure to adjust pressure from valve so you don't create a dangerous situation from pressure build up!!........Happy trails!
Posted on Aug 11, 2009
SOURCE: allis chalmers 912 hydro belt diagram
I also have the same tractor but i have what your looking for so my email address is rickralston73@yahoo.com
Posted on Sep 06, 2009
  • 61 Answers
SOURCE: my b-112 allis chalmers riding
ck battery,cables, fuses.
Posted on Sep 07, 2009
  • 2418 Answers
SOURCE: My Allis Chalmers D12 is popping on the #4
Could be one of the valves are out of adjustment or one is not seating right or burnt thru in the seat area. Thin valves and or carbon deposits in the chamber can do this. Also could be fuel delivery to much air getting into the manifold in this area.
Posted on Oct 31, 2009
My belt is sqceeling on my d17 when i try to turn it right but if i turn i left it does it it does not scqeel
'squeal'
'squealing'
Check the steering pump fluid level and the drive belt tension. Spray all your belts with belt conditioner spray.
For anyone else reading this and wondering what the vehicle is, we are taking about an Allis Chalmers D17 Tractor.
http://www.chatstractors.com/2009%20tractors/1477-Allis-chalmers-D17-left-side.jpg
https://www.google.ca/search?q=d17&sourceid=ie7&rls=com.microsoft:en-CA:IE-ContextMenu&ie=&oe=&gfe_rd=cr&ei=yV9QWKPOAu7L8Ae-rbX4CA#q=d17+tractor+steering
Dec 13, 2016 | Garden
Have an old allis chalmers tractor that leaks gas out of carb..is it the float or needle valve or what..
Yes it is the needle valve that is leaking or If you had this happen after a rebuild kit was installed then you have the float set to high.
Sep 28, 2016 | Dmm Allis Chalmers Tractor D17 Series 4...
190xt 3 point won't lift or very slow when hot
Series IV D17 3 point problems - AllisChalmers Forum - Page 1 ...
www.allischalmers.com > ... > Allis Chalmers > Farm Equipment
Apr 15, 2013 - 30 posts - ‎11 authors
I have a few issues with the three point on my D17. ... As soon as I close it, the armsraise back up (not ever touching the spool valve lever). ..... for 50 HP and a hydraulic pump with great volume at slow engine speeds. ... Or the oil is just cold and they won'tgo all the way down normally unless the oil is hot?
Nov 26, 2015 | Cars & Trucks
How to replace rear oil seal. Allis D-17 series III. Constant oil leak. Not tried yet do not have info
Separate the engine and the transmission, then extract the seal and press in a new one. I hope this helps. Joe
Feb 11, 2011 | Dmm Allis Chalmers Tractor D17 Series 4...
The hydraulic pump does not shut off and the lift arms will not go down on my d19 allis chalmers tractor.
Sounds like you have a hydraulic flow valve problem. Check the lift arms when the pump is running to see if you have any hydraulic fluid leaking there.
Nov 18, 2010 | Dmm Allis Chalmers Tractor D19,d21,210,220...
Hydraulics get were they won't lift anything like round hay bales etc.
can be a lot of different problems-check fluid level if low fill to proper level --leak in hydro line-check all lines for leak--air in system -bleed system -wrong hydro fluid in system-check for correct fluid---seal at pump leaking-check around pump--controls leaking not holding allowing back pressure--test controls for internal leaks repair or replace if necessary--hydro pump internal malfunction/valves/piston/gears-pressure test repair or replace if necessary
Feb 01, 2010 | Diesel Allis Chalmers 190xt Tractor...
Garden Logo
155 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
