Question about Toshiba Computers & Internet
I have a 17 month old Toshiba qosmio G30. Today a thin white vertical line has appeared on the right hand section of the display. I do not (yet) have the requisite external monitor leads to enable me to check whether this is a screen or graphics problem. 1. Is this a common fault? 2.Will it get worse? 3. Is there a reasonable solution?
Im having the same problem and from wut I am reading in alot of diff places the screen is going bad or has cracked from rapid temp change is the most popular answer I have recived, as for a fix check ebay and buy a new one...I found some for as cheaps a $98 and some change and I have already taken mine apart to see how hard it will be to replace...its pretty simple...there are 6 rubber feet on the screen bezal remove them and keep them face up so the sticky stuff dont get anything on them...next there are 6 screws under each one of the rubber feet remove them...pull the bezal off gentaly so u dont break it...next there are 4 screws onthe sides of the screen itself remove them...next remove the flat wire and the backlight wires from the screen and there ya go all apart...to put it back together reverse the steps. :D...
and I know this post is just over a year old but I figured since no one else has posted a fix, I would just in case either he/she still has the same problem or even if some one else has this problem... well good luck
Posted on Sep 13, 2009
Display has vertical white lines. Hook up a external flat screen and it works fine . Toshib Qosmio g25
this indicates you have a bad screen, and if you press around on the back (top) of the computer display the lines will disappear until you take your hands off the area effected, and the screen needs to be replaced.
Jul 12, 2009 | Toshiba Qosmio G25-AV513 Notebook
Qosmio g30 , problem with boot up screen
try the following
update your video graphic drivers,
try with another ram,
if still you have problem try to repair or reinstall the os
Jan 17, 2009 | Toshiba Qosmio G25-AV513 Notebook
Thin Vertical lines on the screen
Ebay - new screens $110-$135. Google for step-by-step replacement instructions.
Dec 30, 2008 | Toshiba Satellite P30 P35 Series Notebook
Vertical colored lines
Hi Hagfoot see below from member PNWSolutions, I don't know if they were sucessful but worth following up Best Solution posted on Dec 24, 2007 3%20stars.png
PNWSolutions
Rank:master_s.gif Master
Rating: 77%, 15 votes
I had the same problem, what you need to do is call Pamela Saunders at Toshiba Corporate in Irving, CA and she will get it repaired for you at no cost to you regardless of warranty. This is a bad batch of computers.
The Phone Number is: 800-457-7777 or 949-462-6000
Aug 23, 2008 | Toshiba G15-AV501 Qosmio Notebook
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Vertical lines in my laptop screen
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
Toshiba Qosmio G20-117 laptop computer. The display has developed a thin, vertical white line the entire height of the screen about 2cm from the left-hand edge of the screen. Is this a software (screen...
It's a hardware fault, you will normally notice if you push on the screen at the top of the line it will disappear, unfortunately you will have to replace the screen.
May 17, 2008 | Toshiba Computers & Internet
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
Thin bright red vertical line from top to bottom of screen
that is the screen burned out. if still have a warranty return to company and get a return/exchange.
Oct 26, 2017 | Sceptre X7G-Naga 17" LCD Monitor
Computers & Internet Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
