It is one of the many microsoft errors that they supposedly try to fix with a couple billion dollars. I have had this happen about 3 times. The first time was when i figured out how to fix it. The 2nd and 3rd were temporary.(Just needed to be turned off for a moment) You need to shut the
console off for atleast 15 minutes 10 at the lowest with everthing unplugged. I mean the
hard drive,
memory unit, and all cables, and adapters. Then after 10-15 minutes plug everything in and
DON'T PRESS the
BUTTONS ON THE XBOX OR THE CONTROLLERS. Press the button to open the tray and take out the
game or
dvd and put in a different one. If this doesn't work do it all over again and then put in a different game or dvd not the previous ones and turn on the
console the same but then a soon as you get the disc in and closed in shut it off then open the tray and wait till you are at the main menu go into any program so you can't see it is reading and close the tray. If that doesn't work contact the
xbox support line. Really hope this works for you.
