Question about Hotpoint Aquarius WF220 Front Load Washer
Hotpoint HVL241 - drum lifter how to fit - - Hotpoint Aquarius WF220 Front Load Washer
3 Suggested Answers
apart4u
  • 213 Answers
SOURCE: How do I replace Drum paddle on Hotpoint WF860 washing machine
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Posted on May 06, 2010
SOURCE: I have a Hotpoint AQXXF149PM washing machine, and
I have exactly the same problem on my ...129 model. I'm a mechanical engineer and looking at the design it apears that these aren't designed to be replaced. The 90 degree tab looks to be only accessed from the outside of the drum so can only lock the tumbler in place from the factory. It needs to be bent flat to get the paddle on!
I hope someone can prove me wrong??
Posted on Jul 31, 2010
Can i replace the drum paddle lifter on hotpoint wmd960, one of mine has a hole in the side of it!
You can indeed, part number for a new lifter is 1604464 and is aprox 11-15pounds.
just basically slide the old lifter towards you( bit of force) and it will come off.
line the new one up to the holes and slide back into posistion
May 23, 2012 | Hotpoint Washing Machines
Can I remove the detergent drawer in a hotpoint hvl241?
There should be a release tab in the dispenser, push down, pull out
if NOT
Remove the screws along the rear top of the washer,lift the top, remove.
Nov 08, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Oct 19, 2009 | Indesit W 123 Front Load Washer
Lifter broken on Hotpoint BHWM129 - replacement on order but need to get the old one out Hotpoint says its easy to do but I am stuck - its a twelve hole lifter and I cant find out how to release the...
Grasp it firmly with both hands, and pull it towards you, it requires quite a bit of effort to do this.
Fit new one by pushing it in and towards rear of drum until you feel it click into place..
Please rate my solution.
Thanks.
Jul 30, 2009 | Hotpoint Ultima WF860 Front Load Washer
Drum paddles keep falling out (Hotpoint BWD129 washer/dryer)
I had this problem, and I was advised by the guy who has apparently 'replaced hundreds of these bloody things on this housing estate' to never buy this machine because 'its cheap and ****'
However, if you bend the long central tab ,the one that looks like it does bugger all, upwards into the drum (carefully though, only bend it a little) this will increase the tab tension, and your lifters should last for over six months instead of the previous couple of washes mine was doing.
As for the comment on washing trainers, I put a single towel in my machine and the lifters broke...
Jul 17, 2009 | Washing Machines
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Thanks.
Mar 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Plastic lug securing paddle in drum have broken off
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint WD860
Aug 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Drum Paddle broken Hotpoint Aquarius
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WF220 Front Load Washer Logo
32 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
