Question about Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
Modifying the DC18RA from 220V to 110V. how? - Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
  • 4,340 Answers
Really, this is not something that can be changed easily, just buy a 110 charger...
Posted on Mar 14, 2011
2 Suggested Answers
  • 313 Answers
SOURCE: Modifying the DC18RA from 110V to 220v
don't replace the transformer in ur charger.just get a step up transformer like 110v to 220volts with plug in receptacle.
Posted on Aug 21, 2008
I have a pro cut 25 i would like to change it from 110v to 220v
The pro cut 25 will run on ether 110v or 220v without changing anything. I made a 220v to 110v adapter. It works well and if I want to run it on 110v it will still plug right in.
Dec 05, 2013 | Lincoln Electric Plasma Cutter, Pro - Cut...
Makita Dc18rc from 110v to 220v
Did Someone Succeeded to Change the DC18RC from 110v to 220v ??
What are the component that should be replaced ??
Where can i get them ?
Thx ,
Lio
May 17, 2013 | Drills
My fan running 110v how to convert in 220v
Use a stepdown transformer to reduce the 220v back to 110v. You can buy them on the internet for using 110v gear in 220v countries
Apr 13, 2012 | Air Purifiers
My charger is accidentaly connect into 220v and this is burn. im here in philippine. its this to repair and i use again...
Is this a 110Volt version that you plugged into 220v?
There is a ceramic Fuse inside the unit that might be blown. It is the first thing on the circuit board near the power cord connection.
Open the unit up and post a photo of any burned components ?
Jul 10, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have the Makita DC18ra s charger for 110V. by mistake i insert it to 220and burn the fuse and a components as described on the borad VDR1 01 Do someone knew what is this components thank alon
yes you can fix it i have done 2 charges but white you are in there if you chance the large round capacitor to a 450v one you then can use the charger in 220 v you will have to increase the size of the voltage resistant diode to 240v (the vrd101 part in the charger) or by pass it with a straight bridge then the charger should work in 220v because the rest of the charger is exactly the same the parts will be around $10 ibought the parts from farnell
May 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
MAKITACHARGER 220v to 110v problem after using of right converter
hi all,
I added another HowTo page for moding the DC18RA from 110V to 220V , you can find it here
Have fun and good luck
Jan 07, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita DC18RA charger conversion
You can't use the same capacity as it gives you a very
large and expansive capacitor.
I used the max. diameter of 30mm that could go into the PCB of the model I have and it is 470uF 400V
You'll need to replace another capacitor, see my mod page !
This works !
I added another HowTo page for modding the DC18RA from 110V to 220V , you can find it here
all the components details are in it
Jan 06, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
DC18RA from 110v to 220v
The varistor you have to change is the one that runs parallel on the current after the fuse, in my case it was easy to find as it was the one with the plastic hood on it.
I'm going to update the webpage with some new pictures that I hope would hetp to clarify it.
Nov 16, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Hi there the solution for how to mod a DC18RA charger can be found here. The "how to" comes with pictures and descriptions and it should be easy to follow, and best of all it works :)
Jun 27, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
493 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
