I've used plain warm water, warm water with a gentle detergent, and just dusted and STILL my screen is dirty and streaky. I want an inexpensive method to clean my screen thoroughly!
I HAVE A SPOT ON MY FLAT SCREEN.IT'S CLOUDY BLACK SPOT.ALMOST LOOKS LIKE BLACK PAINT WASHED OUT WITH WATER.I THINK MY GRANDCHILD SPRAYED TV SCREEN WITH WATER BOTTLE.CAN YOU TELL ME WHAT TO DO
Posted on Mar 16, 2011
  • 31 Answers
Try using a solution of equal parts water and rubbing alcohol. Add a few drops of ammonia if you have it.
dampen a paper towel with the solution and gently wipe down the screen. If there is stubborn residue on the screen that is of a sticky nature, add small amount of lemon juice to your solution instead of the ammonia (make sure the lemon juice is pure, no added sugars or the like) and give the stubborn spots a little more attention. If even that doesn't work (for sticky stains), spray some WD-40 on a rag and then a few drops of lemon juice. This should loosen up sticky residue, but you will probably need to re-clean the area with a water/alcohol solution.
The alcohol/water solution is the same thing as common lens cleaner, and both the alcohol and the ammonia evaporate very quickly, which helps to reduce the streaks that normal dish detergent can leave behind. You can also use this mixture to clean computer screens and even slightly dirty windows. You can even add a few drops of ammonia to windshield wiper fluid to help with streaking. Adding the lemon juice or WD40 more closely mimics "goo" products designed to remove price tags are glue residue.
Do not ever spray your tv or computer screens, always apply any cleaning solution to a paper towel or cloth first.
Posted on Mar 14, 2011
What is the best settings to wash jeans on.
While hand washing and line drying is safest, it's also costly in terms of time and effort. Unless your jeans are particularly dirty, it's best to wash them in cold water, select one of the gentler cycles, and dry them at a low temperature. Special detergents formulated to preserve dark colors really do work.
What temperature do you wash jeans? When to Use Warm Water - For man-made fibers, knits and jeans, use warm water (90°F). Most of your clothes can be washed in warm water. It offers good cleaning without significant fading or shrinking. When to Use Cold Water - For dark, bright colors that bleed or delicate fabrics, use cold water (80°F).
Wash your jeans in the sink or a tub.
  1. Fill a tub with a few inches of cold or lukewarm water. Mix in a gentle, color preserving detergent.
  2. Turn the jeans inside out, then lay flat in the tub. Don't bunch them or wrinkle them. Let them soak for about 45 minutes.
  3. Run them under the water to rinse. Hang up to dry.
  4. Can you put jeans in a tumble dryer?
    According to Good Housekeeping "All fabrics and especially jeans benefit when youtake them out of the dryer slightly damp. ... If, even after tumbling on low heat and a delicate cycle, you see lots of lint on the dryer's filter, you may want to switch to linedrying your jeans to help preserve the fabric.
    hope this helps you out.
Oct 28, 2017 | Washing Machines
CD is not working: when reading a disk displays the message "no disk".
You can try cleaning the reader. There are kits for this where you simply put the cleaning disk in. If this does not work you reader is most likely shot and the only fix is to replace it.
Apr 20, 2014 | Onkyo TX-SV545 Receiver
Lots of Dishwasher Issues- I have a Bosch dishwasher that is approximately 1 year old. For the first 6-9 months it cleaned perfect. It would wash everything off the dishes and leave them sparkling clean...
Do you have hard water? Many states have passed laws that outlawed phosphate as an ingredient in dishwasher detergent. If you have hard water, the detergents don't work very well anymore. The residue is probably hard water deposits (calcium and magnesium). Not harmful but it looks awful on your dishes. There are some new products that were designed to solve this exact problem. They are inexpensive and effective. Can't say the name or I'll get banned (again). Internet search will uncover it.
May 07, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
I washed some very dirty baseball pants on Whitest whites, with bleach and Tide detergent. Not only are the pants still "tan" from the dirt but all the other whites are also "tan." I ran them through a...
Try this: Soak the stained clothes in a solution of 1 quart of warm water, 1 teaspoon of liquid dish detergent and 1 tablespoon of white vinegar for 15 minutes. Then, rinse with water.
If this doesn't get everything out, then wash in warm water (or what the fabrics allow) using a color safe bleach and detergent.
The problem is that there was more dirt than what your detergent could handle. If you have a really dirty clothes item in the future, get as much of the dirt off using a vacuum or by soaking alone as you can. Then wash the item in warm water with detergent and color safe bleach.
Sep 28, 2017 | Kenmore Elite 45986 Front Load Washer
What do i clean the screen with?
Cleaning is simple. Vacuum the rear vents to remove any dust that has built up.
For screen and the fascia, -
1. Unplug the monitor from the power supply.
2. Fill a bowl with warm water with some washing up liquid - just as you would to clean dirty dishes. Soak a soft clean cloth in the water (Kitchen cloth - NONE ABRASIVE!! and not a sponge!), and wring the cloth out so that it is damp (not wet!) and gently wash the screen. When finished use kitchen roll to dry off the monitor.
3. Stubborn marks on the LCD, using the same damp cloth, apply a spot of neat washing up liquid to the cloth. Clean as before - DO NOT PRESS on screen. When finished, use kitchen roll as before.
Voila!
May 14, 2010 | Acer 22" X223w LCD Monitor
What can I use to clean my t.v. screen?
Unplug the AC power cord connected to TV set from AC power outlet before cleaning. Wipe gently with a soft cloth. If dust is persistent wipe with a soft cloth slightly moistened with clean water. If it does not help and dust still persists then use soft cloth moistened with mild detergent solution. NEVER USE AN TYPE OF ABRASIVE PAD, ALKALINE/ACID CLEANER, SCOURING POWDER OR ALCOHOL
Mar 15, 2010 | Televison & Video
Dirty steam cleaner help
You can just run plain water thru it. But, the best way to clean it is to first knock all the stuff loose you can with a brush.
If you want to put detergent in it., use use liquid laundry detergent -- a small amount
Apr 30, 2009 | Vacuums
What is best for cleaning the screen of a rear projection tv?
A mild detergent soap and hot/warm water.
Use it in moderation.
Mix up some dish washing soap and warm/hot water in a bowl. Use a lint free cloth and dunk it into the water and then wring it out. Wipe the screen down and repeat until clean.
Then use plain water to wipe the screen (on a wringed out cloth) to remove any residue until you have purged and dried the screen.
Tips: Make sure you use a lint free and soft cloth. Make sure you wring out the cloth so that you only have minimal water or soap on it.
DO NOT use alcohol or ammonia based cleaner on the screen.
Expect to spend around 10-15 minutes to properly clean the screen.
Jan 23, 2009 | Televison & Video
Computer tv screen
Is there a model number to this 22 tv monitor ?
Most buttons control picture, input, some do language on screen, some change the format for using as a tv versus a monitor
Safest cleaner is A LITTLE plain warm water (Distilled water leaves less spots) and a soft clean cloth
First blow all the loose dust off or use a feather duster to remove the dust.
Oct 11, 2008 | Computers & Internet
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
