Question about Danby DFF1144W Top Freezer Refrigerator
Danby ref Model no. DFF 1170brwy do seem freezer is ok but ref side is not cooling. thanks
  • 1,998 Answers
Most likely you have a defrost issue click this link to see why http://applianceoutletservice.com/appliance-care-tips/refrigerator-tips/refrigerator-defrost-system-information.htm you need to remove the rear panel inside the freezer to assure that you do not have an ice build up and also that the fan located above the condensor is working properly as well if you have any further questions message me back Thanks Rick
Posted on Mar 14, 2011
My Danby DKC645BLS is not cooling consistently it will run and run and never get below 50 degrees. The cooling fan is working properly. Please Help?
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Aug 10, 2011 | Danby DKC645BLS Compact Beverage Cooler
I have a Whirlpool side by side it does not have the water dispenser in the door and does not have an ice maker. Found out today that the freezer was slowly thawing and that the fridge is not cooling. The...
I'm Leo
If this was helpful please rate me
Leo Ponder
imufo2
Thank you for using fixya
Leo Ponder
Please VOTE FOR ME IF THIS WAS HELPFUL.
Please click for article
Jul 26, 2011 | Whirlpool ED5VHGXM Side by Side...
The cooling dont work well bat de frizzin ok.
I'm Leo
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Also check evaporator fan in freezer
Leo Ponder
imufo2
Jul 24, 2011 | Kenmore 57029 Side by Side Refrigerator
Freezer works great but the refrigerator doesn't seem to cool real well.
Please as long as the ref. is running, it should freeze very well. if this is not happening check the following.
1, The setting on the thermostat.
2, Check if you have enough gas in your system.
3. Check if your system is not leaking.
4. Check if your door seals are ok.
May 11, 2011 | Danby (DAR604BLS) Refrigerator
I have a Kenmore fridge with the freezer on the bottom model # 52600. What is happening is the fridge is not cooling but the freezer works.If you have any suggestion please e-mail me. thanks
if the freezer is ok,the damper of the ref side is close need to adjust or replace,2 is the sensor is the sensor is defective the ref side not cooling even the sensor of freezer side if defective may cause why not cooling in ref side,its hard explain to remove or to check the unit by its your self,much better call an service technician to check what the exactly coz why not cooling,and you get a warranty for the service compare you buy a part,but you dont know what how to test the part if is ok or not.
Jan 01, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Danby Propane Refrig-- Low Cooling Output
good day,
hope this link below will solve your problem.
ref
Aug 12, 2009 | Danby DPR2262 Top Freezer Refrigerator
Defrost heater not turninh on
That model has what is called a adaptive defrost on it this fails very often it is located inside the ref under the control panel, The only other possible cause would be a defrost thermostat, this is located near the heater.
Aug 11, 2009 | Maytag MSD2650H Side by Side Refrigerator
My Kenmore fridge, Model 596-58692890 is not cooling and I've lost use of the water/ice dispenser. The motor and compressor seem to be working but the cool air is not blowing. What part might need to be...
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 24, 2009 | Kenmore Refrigerators
Fridge not cooling
hi there.
welcome to fixya.
initially try to defrost the ref and clean it.
Feb 26, 2009 | Amana ASB 2623 Side by Side Refrigerator
Danby DFF1144W Top Freezer Refrigerator Logo
160 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
