Question about Hotpoint Washing Machines
Hi there The door light flashes but does not click so any cycle can start have been told it needs a new door catch but dont know where one of these could be purchased from
  • 1,998 Answers
You can go to www.marcone.com and under contact us there is a 1800 number they ship anywhere in the world and are usually the cheapest you would be ordering the door lock assembly as well when you call them make sure you have the model number to your machine if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in the future Thanks Rick
Posted on Mar 14, 2011
Door locked light flashes which prevents it from working
hi if your interlock is playing up this will cause this try giving a bit of push on door were catch is dont slam door if light stops flashing doors locked its good idear change interlock to do this take band from round door rubber pull rubber of rim take two screws out interlock you can get it through the gap unplug put new on should be ok then but try a push on door 1st when doing lock unplug machine hope tis helps
Jan 24, 2014 | Hotpoint WMA35 Front Load Washer
Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
Jan 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Lights flashing and unable to start cycle. Helped once when turned off at mains but not now.
Hi it could be your door lock switch your machine on and wait for 6 seconds and try to open the door if you can thats your problem or may be that the door catch ic worn try and push the door shut with a bit more force
Jun 29, 2011 | Hotpoint Aquarius WF210 Front Load Washer
HE3 no error codes, will not start when button is pushed. All mode lights are on push any wash cycle and no go. Checked water lines, drain line, no obstructions. When you push the wash cycle button it...
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel. Pull the door lock/latch assembly out of the washer and disconnect the wiring harnesses.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel. the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Feb 26, 2011 | Kenmore HE3T Washer
Door won't unlock and cycle won't start
The interlock has failed most likely. Its a small electronic part that the door catch connects into when you close the machine door. Its tricky to release but can be done. Unplug the machine, remove the lid, put your hand down the front of the machine to where the door catch goes in and fiddle until it releases. It takes a bit of luck when you dont know what your looking for.
May 24, 2010 | Bosch Nexxt 500 Plus WFMC5301UC
My samsung frig suddenly started clicking (the bell that lets you know the frig door is opened.) checked to make sure all doors were closed but bell keeps ringing and now the temp. is rising inside. what's...
Can you pull the gasket back slightly (flat screwdriver or dull knife, don`t cut/rip the gasket) from the side of either fridge door and tell me if the cabinet light is on inside ? I need to know if the light is on without opening either door.
I`ll watch for your reply.
macmarkus :)
Feb 04, 2010 | Samsung RF265AA Bottom Freezer French Door...
Smeg DI 612 C Domestic Dishwasher
I was told by a SMEG engineer that I needed to replace the detergent dispencer. Just waiting for him to get back with a new one.
Aug 15, 2008 | Smeg 24 in. DWI612 Built-in Dishwasher
Start/reset button flashing
The GE technician came to my place this morning and here what he told me.
The start / reset button is used to reset the current wash cycle. You just have to close the door and 90 sec later the dishwasher will be ready to start another cycle. This button is used usually to cancel a wash cycle.
A more drastic measure is to turn off the dishwasher breaker in the electric panel for 30 minutes in order to clear the memory of the panel. After 30 minutes, turn on the breaker and the dishwasher will be back to the factory defaults.
At this point you should not have any problems.
Michel
Jan 16, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Door locking is flashing so it wont start a cycle
Try pressing "end of cycle" button; wait a couple of minutes to open your door, do not force. Then shut door to restart your new cycle..........
Rate me pl. if helped. If not click 'thanks for trying', this prob will come up for others to solve.
Jan 13, 2008 | Washing Machines
Problem with washing machine
New door sensor im afraid,unless the machine senses that the door is properly shut none of your wash or spin cycles will start.Sensor located inside washer casing , where lock pin on door handle enters machine.It may just be loose,try tightening the two screws either side of lock keep.If it needs replacing you will need to UNPLUG washer ,remove lid and slide your arm down inside front of washer to access.Good luck.
Oct 23, 2006 | Zanussi FLE1416W Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
