I need to replace my door latch assembly for frigidaire atf6000fs1. how do i remove the grey rubber seal?
    President:
  • 1,430 Answers
Try this link it should help Door switch replacement
Posted on Mar 14, 2011
How to change seal on atf6000fs1 washer
Good Afternoon Friend,
I understand you want to know how to replace the seal on your Frigidaire washer, model# ATF6000FS1. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance, and should be able to replace the seal with ease. Hope this is helpful.
-Best Regards-
WP
Jun 11, 2014 | Frigidaire ATF6000ES Front Load Washer
Door won't unlock on my ATF6000FS1
Hello Friend, this is Z. Thank you for allowing me to assist you!
I see that your Frigidaire washer (ATF6000FS1) door will not unlock. Sometimes, resetting power to your washer for about to 10 minutes does the trick. Once you turn on your washer, select a normal cycle and verify if the door will unlock. If not, your washer may possibly have a faulty door lock assembly, or a communication problem with the control board. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Jun 04, 2014 | Frigidaire Affinity ATF6000F Front Load...
Atf6000fs1
Hello Michael - Thank you for your post! Let's try resetting the washer. This can be done by either unplugging it or flipping the household circuit to the off position. It is important to wait roughly ten minutes and then turn on the unit. Will the door lock? If the issue persists, then more than likely the unit is experiencing a communication issue with the control board and the door latch or the washer has a faulty door latch/lock assembly. In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your appliance.
Jul 10, 2013 | Frigidaire Affinity ATF6000F Front Load...
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
I close washer door but it wont go through cycle
Check to see if one of the two tabs on the door latch assembly are broken. If one is broken, replace the door latch. If the door latch is ok, you might have to replace the door switch and the door latch. To replace the door switch you have to remove the front panel. Remove the two screws holding the door switch assembly in place and drop the door switch assembly down into the bottom of the washer. Remove the wires and transfer to the new switch. Reach up and line up the new switch and install the two screws. Remove the two screws on the door latch assembly on the door, and remove old door latch. Install the new latch and replace the front panel. I hope this helps.
Jan 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
The door on my dishwasher will not close
There are a few problems that can occur with the diswasher door assembly. These usually involve the latching mechanism, the door seal, the counterbalance spring assembly or the hinges. 1) The door latch plate can occasionally become out of alignment. Some door latch plates are adjustable, some aren't. If yours is adjustable, try loosening the retaining screws and repositioning the plate. It's trial-and-error, so have a lot of patience. If this doesn't work, then the latch needs replacing.
2) A new dishwasher or a newly installed door seal can be difficult to close for a while until the seal softens and compresses over time. You can try adjusting the latch, if possible.
3) If the door feels unusually heavy, there could be a problem with the counterbalance spring assembly. These counterbalance assemblies allow the door to open and close easier and are held by two springs. On some dishwasher models, holes are positioned in line so you can re-tension the springs by moving the spring hooks to other tensioning holes. If any of these springs break, they will need to be replaced as a pair.
4) The door hinges might be bent. They can seldom be adequately fixed and should be replaced.
hope this helps
Nov 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Door latch replacement
remove spring from around front of door seal roll seal away from door frame remove the 2 screws holding lock assembly to frame pull latch toward opening unplug the wires reinstall in reverse..reinstalling spring on door seal will be hardest part but not too bad
Nov 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Front door buzzing Frigidaire front loading washer
replace entire door lock assembly ..remove spring holding the door boot in place and roll boot back ..unless you have the one where the seal is glued then carefully slide knife under edge to cut through glue take the screws from lock and pull through opening remove wires and install new lock ..if noise is only issue use till it blows then replace
Jul 30, 2008 | Frigidaire FWT449
Will not start
That sounds like your door latch. In the door frame where the door is secured, you should see 2 black pieces in your door frame. The bottom one (square in shape) receives the pin sticking out from the door. The upper one (round in shape) should have a pin sticking out of it from the machine. This is the machines way of detecting wether or not the door is still open. If the pin gets broken off, the machine will not run. It is easy to get snagged when putting in or pulling out laundry. I have had customers who have simply found something to super glue back on so it functions like the missing pin again, however I don't recomend bypassing this as it is one of two systems that keep the machine from flooding your house if the door doesn't stay closed. Bluntly, if you can't jury rig it right, just replace it.
As far as replacement, remove the 3 #20 torx screws holding it in. Remove the clamp around the front grey rubber seal. (pring it off with a small, flat head screw driver works well. Pull around the edges and the seal will come off. Reach to the right hand side and you will feel your latch. Lift slightly up on it (there are 2 clips it sits in, then pull slightly toward you. There are 3 connectors that have to be removed (don't worry about the order, they all only fit back in 1 way). Push on the tabs that are holding them in to remove them. Replace the latch assembly with one you have purchased from the manufacture on line or from a local appliance parts store. (you will need the model number of your washer located in the door frame for this at either place). Now place the 3 connectors back in. Put the assembly back into the tabs inside. Re-attach the torx screws. There is a gap in the grey rubber seal that the metal lip of the washer sits in. Re-seat it. Now place your small flat head screw driver in one of the holes next to the spring on your clamp. Again, there is a gap on the seal it fits it to keep it tight. Work it back in keeping 1 hand on the screw driver and moving a round object (screw driver handle) around the edge of the clamp until it is seated all of the way around. You should be all set.
Please be sure to rate this information if it was of help to you.
Jul 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
439 people viewed this question
Top Washing Machines Experts
