Question about Toshiba DR4 DVD Recorder
I have a Toshiba DR19DTKB2 DVD Recorder & every time I put on timer to record it doesn't. There is an E21 code that comes up when I go into the timer menu to view if the recording has actually happened!!! Any ideas please???
Palmbeach
  • 185 Answers
SOURCE: Panasonic DMR-E55 DVD Recorder
Ok guys, you asked for a fix for the DMR E55 Self Checking cycle. Here goes.
In 99% of cases this is caused by a faulty regulator on the main power board. The power board is located on the right hand side of the unit. The regulator is IC001 which is mounted on a thin metal strip which acts as a totally inadequate heatsink. This means that this component constantly works at temperatures beyond its tolerance. Because of this it usually lasts a couple of years and then starts causing problems. The Self Checking syndrome is typical. If the regulator burns out completely, it can take other components with it, blow fuses and scorch the circuit board.
If you are competent in using a soldering iron with care, order an STRG 6353 regulator. These can be obtained online from a number of suppliers. Disconnect your DMR E55 from the power source and remove the lid.
Next, remove the fixing screws from the circuit board on the right where the regulator is located. Carefully remove the multi connector on the left side of the board. Remove the screw above the power connector on the rear of the unit. The power board can now be removed from the cabinet. Using a small pair of wire cutters, clip all five pins from the old regulator as close the the top of the board as possible. Undo the screw securing it to the heatsink and remove the old regulator which can now be thrown away.
Next, using your soldering iron, remove what's left of the pins from the printed board and with a solder sucker or desoldering braid, clear the holes ready to accept your new regulator. Be careful because if you over heat the print it can lift away from the board.
Use a little heatsink compound on the back of your new regulator, poke the pins through the circuit board and then secure it to the heatsink. I usually fit an extra heatsink on these units which helps to reduce heat and prolong the life of the new component.
Next, resolder the 5 pins on the print side of the board. Use a magnifying glass and make sure you haven't missed anything or bridged connections in error and caused short circuits.
Now put the board back. This can be a little trick but it's easy enough if you take care. Replace all the screws and carefully reconnect the multi connector.
If you have followed this correctly, switch the unit back on, pop in a DVD and give it a try. Unless you are very unlucky, You DMR E55 will no longer repeatedly self check and will operate correctly. Whilst it saddens me to hear that some of you guys would toss your DMR E55s into the trash can for such an easily repairable problem, please do not attempt this unless you are confident in your own ability.
Finally, do check that the fan operates but remember it is temperature controlled and will not activate until it is needed. Do not assume it is faulty because you do not see it working straight away. I have repaired lots of DMR E55s and I have never found a single fan or fan control circuit to be faulty. That's not to say it can't fail. good luck...
Posted on Jan 15, 2008
SOURCE: my LG dvd recorder/video cassette recorder
LG DVR 597X
Posted on Oct 18, 2008
  • 98 Answers
SOURCE: dvd/vcr recorder stops recording
I finally got word back from a pal at LG regarding this issue as where I work we are getting these and as of Friday had about 18 to 20 units with this issue.
LG told us that this has to do with the encoding with the commercials (a one time record issue) on the one time record disks (DVD-R and DVD+R) now their "TEMP" fix for this is to used DVD-RAM or DVD-RW disks (these are not regular -RW they have a encoding CPMsomething I don't remember right now) but they will update us when they have a permanent solution. I will get the type of disk for the -RW on monday and post it here for everyone.
Posted on Nov 09, 2008
SOURCE: i have toshiba dvd recorder,the
Make sure you Finalize the disc when you are done recording, otherwise it won't be read on other players or computers. To do this you go to Setup> Disc and choose Finalize. It takes a few minutes per disc, don't turn off the player while it it finalizing. In the same Setup menu you can choose an option to autofinalize the disc when you are done recording, so you do not have to to it manually each time.
Posted on Dec 31, 2008
  • 6 Answers
SOURCE: recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Posted on Jan 27, 2009
My hdd dvd recorder will not record e51 , help
i think thats the code for the hard drive fail. if anything is recorded try to play it if will not play or it jumps about then the hard drive has failed and would need replacing.
Jun 29, 2017 | Toshiba Televison & Video
I need a users manuel for a toshiba dr420 dvd recorder
Toshiba has the manual for the DR420 on their support site: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2805096&rpn=undefined&modelFilter=D-R420KU&selCategory=2797338&selFamily=2797342 . (If you need to, click on the User's Guide tab.)
If this doesn't work, start at http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp . Click on Product Support and then DVD & Blu-ray and then DVD Recorders and then the model number in the various drop down menus.
Note this manual is the one for the DR420KU which is the USA version. If you are in another country, try that region's version of the Toshiba support site.
I hope this helps.
Dec 17, 2011 | Televison & Video
LOOKING FOR USER MANUAL FORTOSHIBA RD329DT 320GB 1080P HDD & DVD
The direct link to the manual is: ftp://CCFTPcustomer:909ohedr@195.35.123.32/CCFTP/Manuals/DVD/RECORDER/RD329DT/RD329DTKB_OM.pdf . This link is actually on the old Toshiba support site.
If this direct link doesn't work, start here: http://www.home-entertainment.toshiba.co.uk/Support/ , the Toshiba UK support site. Scroll down and click on Download Owner's Manual. Then click on the DVD, Blu-ray & Recorders section. Then click on the link to the older Toshiba manuals (pre-2008). Expand the DVD folder and then the Recorder section. The manuals are listed in alphabetical order.
I hope this helps.
Oct 16, 2011 | Computers & Internet
What should my toshiba dvd recorder say while
while recording the real time can be showing / remaing time of the event being recorded /timer clock will showcase the speed if enable or alert if there is a problem and if all is well the a red dot should also be showing
Mar 18, 2010 | Toshiba RS-TX20 DVD Recorder
When I turn my Toshiba D-VR4 recorder on, it won't go to DVD
I figured it out with absolutely no help from the manual. To initiate recording, you have to press the timer/set button. After the DVD recorder finishes recording, you have to re-press the timer/set button to take it out of recording mode. I think their book needs to explain that more clearly.
Sep 29, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Toshiba DVD recorder timer recording does not start
Does the unit not require to be in "Standby" for recording to commence.
Nov 30, 2008 | Toshiba DRW2 DVD Recorder
HELP
I am trying to set the timer record to channel 185, but my unit will only allow me to set to channel 125.
Apr 15, 2008 | Toshiba DR550 DVD Recorder
Dvd do not record
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
Apr 04, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Toshiba DVD/VCR Recorder
The only thing you can do is to program the recorder to come on and record at a certain time and also program the event timer for the Bell Expressvu.
Mar 13, 2008 | Televison & Video
Toshiba DR4 DVD Recorder Logo
167 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
