I have a Color LaserJet 1600 that is only printing half of a page. The problem started today when I noticed the entire right side of the page was missing. I'm not sure where to begin to remedy the problem. Any advice is welcome!
  • 1,915 Answers
This is likely caused by a bad cartridge. Your description fits what happens when a bad drum on a cartridge draws too much current and the power supply cannot energize the drum units on all colors. The most common color I have seen this error with is yellow, but it could be any of them. If you recently changed one cartridge, that is the likley suspect.
Posted on Mar 14, 2011
Testimonial: "Thank you! I DID just change the yellow cartridge last week. I truly appreciate the help."
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 1600 When I print a page, the red comes out as as orange - sometimes only at the top but, today, on the left although the right was OK. There is plenty of ink in all the cartridges.
Hi there, Your laser unit is dirty which will cause your colors to be faint on some sides. This is normally thing and the Printer just needs to be serviced and the laser unit needs to be cleaned. So i would advise taking it to a Service Agent or Computer shop to have it cleaned.
Regards,
Jul 27, 2011 | HP Color LaserJet 2600n Printer
HI tech, I have this HP LJ1600 and I have this mark on the right hand side from top to bottom just as a roller mark the page. When I do a self test page there is a colour band on the right and it is split...
If the band is one particular color then it is quite possible that you have a bad toner cartridge of the color that matches the band. You can also try printing a test page from the secondary service menu. Access the menu as follows:
To enter the secondary service menu, use the following procedure:
1. Confirm that the device is in a Ready state.
2. Press the button (Select) to enter the main menu system.
3. Press the button (Left arrow) and the button (Cancel Job) simultaneously.
4. Press the button (Select) to confirm 2ndary Service.
5. Press the (Left arrow) button and button (Right arrow) to navigate to the secondary
service menu.
Find the option for test print.
May 28, 2011 | HP LaserJet 1600 Printer
Hp 1600 laser, entire page comes out sligtly black
How old is it?
Page getting dark sounds like the drum getting old.
Mar 12, 2010 | HP Hewlett Packard LaserJet 1600 Printer
Dull colors on half the page
I would replace the transfer belt see if that makes a diffrence hope this helps
Nov 20, 2009 | HP Color LaserJet 2600n Printer
What are the starting instructions?
I believe you can download the operators manual from HP's website.
Jul 30, 2009 | Office Equipment & Supplies
Yellow cartridge says low after printing 200 pages for hp laserjet 1600
200 is not much, but possible if you print a lot of pictures at paper size. Normally when a HP 1600 starts notifying about low toner, you still have about 20 %.
Apr 09, 2009 | HP Color LaserJet 2600n Printer
Smudge mark along entire right side of every page.
HP 1600 is quite a decent little printer, so you shouldn't be dissapointed - if it's working properly, which clearly it's not in this case.
It seems that you have 2 problems here.
Firstly it shouldn't click loudly, so you need to be talking to whoever you bought the printer from.
The smudging - is probably a dirty fuser.
There are laser printer cleaning sheets, that will work quite well, but ideally it needs a little bit of dismantling to get at the fuser to clean the two fuser rollers.
I've seen lots of these with dirty fusers, and a clean with IPA does the trick.
Jan 03, 2009 | HP LaserJet 1600 Printer
Printing quality off? 2550 HP laser jet?
When installing new cartridges, it's always a great idea to perform a cleaning and recalibration of the machine. Below are the steps needed to do just such a task. You may want to print these out or save them somewhere for future reference as well. They are directly from the HP website.
Please rate the tip accordingly and thanks for using Fixya.com.
Cleaning the printer
  1. Verify the printer is turned on and in the Ready state.
  2. Open the HP Color LaserJet 2500 Toolbox. Click Cleaning Page on the Troubleshooting tab, and the click Print (HP Color LaserJet 1500 or 2500) or Cleaning Page (HP Color LaserJet 2550). A page with a pattern prints from the printer.
  3. Remove any paper that may be in tray 1.
  4. Remove the page that printed and load it face down into tray 1.
  5. At the computer, press Clean .
Calibrating the printer There are two methods of calibrating the printer manual: at the printer or from the Toolbox on the computer. From the printer Turn the printer off and then on again. From the HP Color LaserJet 1500 or 2500 Toolbox on the computer
  1. Open the HP Color LaserJet 1500 or 2500 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 1500 or 2500 Toolbox icon on the computer desktop.
    • Select Start , Programs , HP Color LaserJet 2500 , and then HP Color LaserJet 1500 or 2500 Toolbox to open the Toolbox from the Windows desktop.
  2. Click Diagnostic Tools on the left side of the screen on the Troubleshooting tab.
  3. Click Color Calibration to perform the calibration procedure.
From the HP Color LaserJet 2550 Toolbox on the computer
  1. Open the HP Color LaserJet 2550 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 2550 Toolbox icon on the computer desktop.
    • Select Start , Programs , Hewlett-Packard HP Color LaserJet 2550 series , and then HP LaserJet Toolbox to open the Toolbox from the Windows desktop.
  2. Click Print Quality Tools on the left side of the screen on the Troubleshooting tab.
  3. Click the Calibrate Now button to perform the calibration procedure.
Nov 04, 2008 | HP LaserJet 2550Ln Printer
HP Color Laserjet 3500 printer - no black on left side of page
The folded paper solution for for me. Thanks to all for sharing!!!!
I had the same problem. No black or cyan on the left side of the pages. From this advice... I folded a stack of 4 pieces of paper in half and then half again. I took out the transfer unit and put the folded paper in the upper left corner and then put the transfer unit back in. WORKS BEAUTIFULLY! Thanks you all sooooo... much!
Sep 25, 2007 | HP Color LaserJet 3500 Printer
128 people viewed this question
k24674
jasbo
jasbo
