Question about OKI B4200 Led Printer
PRINT SPOLLER SERVICE NOT WORKING - OKI B4200 Led Printer
    Guru:
  • 78 Answers
If you are having issues with your system's print spooling services. You can try this steps:
Click here: PRINT SPOOLING
Hope this helps!
Good Luck!
Posted on Mar 14, 2011
SPOLLER SERVICE IS NOT RUNNING
To solve this problem, go to Start - run - type services.msc and click on ok or go to start - control panel - administrative tool - services - double click on the printer spooler service to start automatically - restart your computer. If this does not work, go to start - control panel- add/remove program - uninstall the printer and reinstall the printer again
Jul 10, 2012 | Samsung ML-1610
SAMSUNG MI-1610 SPOLLER SERVICE IS NOT RUNNING
Jul 10, 2012 | Samsung Office Equipment & Supplies
My hp 5610 printer says off line. How do I get it back online.
Hi!
  1. Make sure the printer is on and that it's properly connected to your computer.
  2. Go to Printer and Faxes, right click on the printer's icon and click on Use Printer Offline.
Regards,
Pelu.
Feb 14, 2011 | HP Officejet 5610 All-In-One InkJet...
My printer is not working properly and not printing what to do
First solution will be you can stop service called print spoller service and start it again. if still is not working then you can uninstall the drivers and try to install it again.
And to stop print spooler services
Go to run type command services.msc
Search for print spooler.
Stop it
And then start it again.
Sep 28, 2010 | Office Equipment & Supplies
Worked for the first time then stop working the second time.
BEFORE reinstalling try sol 1
>>reinstall the printer diriver with an updated version form vendor site
somtime the drive may have bugs with the os and new updates so please get an updated driver from the vendor website
sol 2 >>or try windows update for find on for you goto www.windowsupdate.com and see whether you have an driver update
sol 2 >>try restarting the spoller service this small this works on most printer with an corrupted spoller
Start, control panel ,admistrative tools, services, scroll down to
print spooler and do a right click select restart
for more information
http://support.microsoft.com/default.aspx?scid=kb;en-us;324757
please rate solution.. and remeber reinstall will solve the problem but you dont know what acctuall happend you nmay need to do the same thing again costing you big time
Apr 11, 2010 | Lexmark X4650 InkJet Printer
How do I clean the heads as printing is not clear enough
clean it from the software of the printer ..
else u can go to control panel
click prnter and hardware..
open ur printers hardware software ..(it will b on the same page)
go to maintainence
u will have a various option like clean head
clean spoller
clean all the device..
insert a blank page...in the printer so that it can clean
Mar 11, 2010 | HP DeskJet 5150 InkJet Printer
Printer spoller
Check the printer cable is connected with the system.
Check the power cable of the Printer.
Install printer driver in the system.
Jan 25, 2010 | HP DeskJet F380 All-In-One Printer
Dell laptop print spooler service is not running
go into control panel under administrative tools and go to spoiler and enable it
Mar 29, 2009 | Dell Inspiron 6000 Notebook
I have just installed my brand new Kodak AiO printer driver onto my MacBook Pro. When attempting to print, this printer will not show up. I seem to be unable to add it manually. Help?
LET'S TRY THIS;
I think MAC calls the printer spoller the same; check the file for device management and make sure the spoller is selected ON.
SOME HOW SOME WAY THE SYSTEM HAS TO FIND THE PRINTER
Might try; AFTER DRIVERS AND ALL DIAGS RUN---------power down printer; restart system with printer power on first.
Dec 28, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
@wowway.comprinter spoller won't run can't find dependacy
This issue can occur if the Print spooler service is not running.
To start the service:
1.
Click Start, click Run, type services.msc, and then click OK.
2.
In the Services pane, right-click Print spooler, and then click Properties.
3.
Under startup type, make sure that the startup type is set to Automatic. If it is not, click Automatic in the startup type list, and then click Apply.
4.
Under Service status, click Start.
5.
Click OK to close the Print spooler Properties dialog box.
If that doesn't help, you can try this:
try this to kill the dependency services that are not starting:
Remove all Print spooler service dependencies other than the Remote Procedure Call service.
  • Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
Now your print spooler service should start re-install your printer if it is usb remember to unplug the usb cable until the install software tells you to connect it.
Hope this helps. Please remember to rate this information.
Thanks
Sep 05, 2008 | Lexmark Office Equipment & Supplies
OKI B4200 Led Printer Logo
122 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
