Question about Vacuums
Setting time for daylights savings time - Vacuums
    Master:
  • 403 Answers
Why do you need to set your vacuum to daylite savings time
Posted on Mar 14, 2011
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
Tip
You da man, er, Guru! THANKS for the Very Easy Step-by-Step Instructions on the...
When the brushes stop spinning on a Hoover SteamVac, it can be caused by several things. In order to diagnosis why your brushes aren't spinning, please view the diagnosis solution I have done on Fixya:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
If you have diagnosed your machine, and found that the internal receptacle is not spinning, then you'll now need to replace your turbine. This tip will explain in detail how you'll need to complete this repair.
Here's what you'll need to complete this repair:
- Hoover SteamVac Replacement Turbine Brush Gear
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see-thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to un-clip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before you tighten the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
Chris J.
GoVacuum
on Feb 21, 2011 | Hoover V1 SteamVac SpinScrub Vacuum
My oregon scientific projector clock keeps changing time, I think it might be something to do with the time zone. I do not know what a time zone is?
A time zone is section of the country that adjusts for daylight savings time. The United States is composed of four time zones - Eastern, Central, Mountain, and Pacific. Each county is assigned to one of the four time zones. See the attached map to see which time zone you are in. Then you must set up your clock to match that time zone. bblue1967191.jpg
May 03, 2011 | Vacuums
What is the time zone for New Jersey in USA
Eastern time we are on daylight savings now....(GMT -05:00)
Apr 11, 2011 | Vacuums
Dow do I turn off DST feature on Timex T248T
I've looked at the user manual for this model. It doesn't look like it has a daylight savings time feature. Does yours? It looks like you have to set the clock forward and back yourself for time changes.
Here is the owners manual for this model of clock: http://www.timexaudio.com/pdf/T248_IB43485_62.pdf
I hope this helps. If it does, I'd appreciate a vote. Thanks,
Handie Andie
Apr 03, 2011 | Vacuums
HELLO MY CLOCK DID NOT DO AUTO DAYLIGHT TIME HOW DO I FIX THE TIME TO ADJUST TO ONE HOUR A HEAD THANK YOU INGER WELCH
All you need to do to advance your clock an hour for daylight savings time, is hold down your clock button without letting it go. Then press your hour button once and you should be all set.
Most clocks that are older than when they changed the date of daylight savings time will either not change it for you on the right day anymore. Or they don't have that feature in it.
If yours does have an automatic daylight savings feature...you may find it helpful to take it off "automatic" and just change it manually from now on. That's what I do with my VCR. It has an automatic daylight savings time feature, but it's useless now that they have changed the date when we set our clocks for DST.
Some manufacturers will give you instructions on how to change the feature settings so your product will again work correctly for you. But not all will or can. You can look it up at your manufacturers website to know for sure.
Good Luck...and I hope this helps you.
Mar 13, 2011 | Vacuums
The clock changes for daylight savings time on the wrong day. it did this the past few times the time had changed. the date on the back of the unit is 2004. didn't they move the weekend of daylight savings...
Daylight Savings Time was extended in 2007.. (the Act was in 2004)..
So your clock worked fine for three years.. now.. if you can turn this automatic feature off I suggest you do and just set it manually... otherwise you will make the change.. and it will make it again for you!
Best of luck
Mar 12, 2011 | Vacuums
Hello this vacuum cleaner has great suction through the hose but not in the main part, it will not pick up i have cheked to see if it is blocked but does not appear to be. any ideas?
If it sucks through the hose it must have a blockage in the pipe or at the head. Remove head and check for hairs and thread which often cause dust to collect there in a knot. Clean the brushes. You should be able to see daylight at the end of the pipe. Put your fingers in the part of the head that goes onto the pipe and feel for a blockage. Or push a thin wire through.
Feb 13, 2011 | Bissell Upright Vacuum - The Pet Hair...
I am having problems setting the alarms on my Emerson Smart Set clock
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
  • This should work for all Smartsets, but I cannot make the guarantee (and no, I don't have any other directions, sorry)!
  • Adjusting the DST Start Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM1 buttons (at the same time). After 3 seconds the display will show the DST 'start' month, week, and date. It should be alternately showing "4 F" (April and first week week) and "4. 1".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the DOWN (or "-") button 3 times, until the display is showing "3" (March) and the week as "F2". It should alternately flash "3 F2" and "3. 11".
    3. After this is set, the clock should "automatically" reset itself
  • Adjusting the DST End Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM2 buttons (at the same time). After 3 seconds the display will show the DST 'end' month, week, and date. It should be alternately showing "10 L" (October and last week week) and "10. 28".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the UP (or "+") button 1 time, until the display is showing "11" (November) and the week as "F". It should alternately flash "11 F" and "11. 4".
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
And this conclude's Search Marketing Guru's public service announcement. :) We'll be back with relevant online marketing posts with our next posting!
Nov 03, 2010 | Vacuums
My daughter's S3765 bagless canister has good
That means that you need to replace the belt. Here is the belt you need for your model.
Hoover Windtunnel Canister Belt
Dec 20, 2009 | Hoover S3765-040 WindTunnel Bagless...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
