Question about SySTOR Systems (310S16) Burner
How do you reformat the hard drive? We think the hard drive is corrupted
  • 746 Answers
Use on track disk manager, sure it will sort out your problem.
Good Luck
Posted on Mar 14, 2011
  • Shahzad  Waseem Akbar
    Shahzad Waseem Akbar Mar 14, 2011
    You can contact me back for further more information, I will guide you step by step and resolve your issue.
    Best of Luck
My n205 says it cannot access hard drive (probably the result of a virus) so I think I need to reformat the drive, or look for appropriate solution
I would not assume that the drive is corrupted by a virus. Viruses generally don't cause the machine to not be able to find the hard drive (they can...it's just not very common). If your BIOS supports a hard drive diagnostic I would first use that to check that the BIOS is seeing the drive, and that the drive doesn't have errors (as you don't have to get into the operating system). However, if you decide to reformat you can try it, but if the drive is having physical problems the install probably will not execute.
If the machine says it cannot access the hard drive, and the BIOS cannot see the drive, it is highly likely not a virus but a failed hard drive and you won't be able to reformat.
Hope that is helpful.
Dec 31, 2010 | Toshiba NB205-N311/W Netbook
Not saving games lost files seems to be corrupted
You can try to reformat the entire hard drive, or you can buy a new hard drive.
To reformat the drive, in the PS3 menu:
NOTE: This will erase everything you saved on the hard drive.
1) Go to the Settings menu, then select System Settings.
2) Select Format Utility, then select Format Hard Disk.
3) Select Quick Format
To replace the Hard Drive, buy any 2.5 inch notebook hard drive that has a serial ATA connection. Then remove the old hard drive from the left side of the PS3 and install the new hard drive.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
I cant reformat my hard drive. (Windows XP)
Hi. There are several causes for this type of error. Either your Windows CD is corrupted, hardware is faulty (Motherboard, RAM, hard disk, video card, etc.). You may want to try to reformat your hard drive using another computer first just to isolate if your hard drive is faulty. If you can format it using another computer, try installing windows on that computer.
Aug 27, 2009 | Microsoft Windows XP Professional for PC
WD passport fried I think. Can I reformat?
Well in this case, formatting should no be performed. the Western Digital data recovery tool should be taken a try first of all. If it doesn't help, then take the device for data recovery services if the data is really important to you.
Remember - DO keep the deivice safe from data overritten or physical damage. Regards.
Aug 13, 2009 | Western Digital WD Passport 250GB Portable...
Saying hard disk corrupt then restores but game freezes
Is this a game on your hard drive or a CD? If it is on your hard drive then it quite possibly had a bad download OR your hard drive is on its last leg.
Aug 08, 2009 | Sony Playstation 3 (PS3) Console
Toshiba satellite a200 not booging, when the power switch is switched on the fan spins for 5 sec and off by itself, and no further booting. The battery charging and power supply DC jack are ok.
The problem is not with the power supply or the power adapter. The problem is the hard drive of the computer itself. The hard drive could be corrupted and needs a reformat.
You have to reformat your hard drive as soon as possible so that you could still save it. The common cause of of corruption is virus.
Apr 09, 2009 | Toshiba Satellite Pro A200-EZ2204X...
How do I reformat my Raid?
You don't mention which operating system you're on, and reformat instructions are specific to the OS. Also, I assume the OS is installed elsewhere, on another primary drive. If your OS is on this hard drive it's whole different kettle of fish.
It sounds like there is some corruption in your files, and the drive wants you to essentially erase them clean so it can clear up the mess and start anew. That is what is meant by reformat.
Please go to this link and attempt to follow the LaCie instructions to "Fix volume corruption"
http://www.lacie.com/support/support_manifest.htm?id=10244&article=search
If you have trouble with this, or don't understand how to go about data recovery, you will need to learn how to backup the entire content of the drive before reformatting it. In that case, I recommend you consider using a full image backup utility like Acronis True Image http://www.acronis.com/ or Symantec Ghost.
If you have current backups of the data stored on this drive, and understand how to work with them to restore the information to your hard drive, you can safely proceed with the reformat.
If this answers your question, please take a moment to rate this post. And by all means, if you're not certain about how to proceed, write back and I'll be happy to point you to some tutorials that can guide you through the process.
Mar 28, 2009 | LaCie 4TB Biggest Quadra U SATA II Hard...
Corrupted hard disk's
It sounds like the system can't reformat the drive on it's own. This means that most likely the program that the system uses to reformat is what is corrupted in the hard drive. If that's the case, unfortunately you'll need to get in contact with either sony or a licensed repair center. It's possible that Sony or the repair center can send you a disc with the repair program on it.
Hope this helps.
Steven
Mar 01, 2009 | Sony PlayStation® 3 (60 GB) Console
Hard drive corrupted try to restore but keeps saying hard drive corrupted can you help thanks
Hello. You need to replace the hard drive, or reformat your hard drive with your PC using an external USB connector.
Oct 06, 2008 | Sony Playstation 3 (PS3) Console
SySTOR Systems (310S16) Burner Logo
37 people viewed this question
Top SySTOR Systems Computers & Internet Experts
David Payne
David Payne
Are you a SySTOR Systems Computer and Internet Expert? Answer questions, earn points and help others
