Question about LG LFC23760SB Side by Side Bottom Freezer French Door Refrigerator
The refrigerator section quit working though freezer sections works. Model lfc23760sb. Purchased 3/30/2009. There is some ice build up in freezer but very little. Refrigertor had been making noise prior to quiting for sometime. Currently there is popping noises coming from the back close to the frezer. Is this the circuit board problem reports by other? Is it worth fixing.
  • Mary Branigan Jun 19, 2013
    mine has done the exact same thing!! did you figure out the problem?
  • LG Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
The refrigerator section does not cool enough, although freezer works fine.
First check to see if the evaporator fan motor is operating correctly. It is usually located in the freezer section. If this fan is operating, check for ice build up at the opening into the refrigerator.
Oct 20, 2014 | Refrigerators
Our BR18VC model fridge is no longer cooling as it should. It does still run but the freezer section only gets down to about 30 degrees farenhiet. We purchased it here in Denver at a Lefty Martin...
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
From repairclinic
Jul 26, 2008 | Amana Refrigerators
Kenmore refrigerator(model 10653606202) freezer is cooling, can hear the circulation fan' noise, also see defrosted water in the bottom collection pan. but the refrege is not cooling.
If the freezers is freezing everything and you can hear the circulation fan, maybe it is a defrost problem. Sometime ice will build up behind the rear panel in the freezer section that blocks either the chilling tubes to the refrigerator section.
You will need to remove the food from the freezer, then remove the shelves and inside back panel of the freezer. If you see a lot of ice, that is probably your problem. DON'T use water to defrost, either unplug and let it set with the door open or hurry it up with a hair dryer.
It also means your defrost assembly has stopped working and will need replaced, but the unit will work without it for several weeks before the ice build up redevelops.
Jun 07, 2011 | Refrigerators
Fridge part of my side by side registers above 40, spoils milk; freezer section which is frost free gets frosty buildup in in; ice maker quit working also. freeze food still?
Look into the back of the freezer to see if frost is building up on the rear panel. If yes that is a sign of the defrost system failed. I will need your model number. When most refrigerators begin the problem it is a sign that defrost is not happening. Ice makers stop working above 5 degrees. Send me your model number and I will help you get this solved or pointed in the right direction, Sea Breeze
Feb 13, 2010 | Refrigerators
Whirlpool 25.6 cu. ft. side by side Refrigerator with in door ice
The process of Refrigeration is for one section to be hot while cooling another section. I.e freezing in one section result in the heat build up and dissipattion else where. Any compressor working properly is going to be quite warm to the point of being hot to the touch when working NORMALLY. There is nothing that you need to do for the continued safe operation of your compressor. If your freezer has ice build up again in the near future your uint is not defrosting properly. If it functions normally after 2 or 3 days of use then you more than likely had a one time buildup of ice usually caused by someone leaving the door partially open
Jan 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hi, We have a whirlpool eb22dkxfw01 bottom-freezer refrigerator. The freezer part is working OK, compressor is running, but the refrigerator part is getting rather close to room temperature, and...
need to check for ice build up in air vent. if not make sure you hear your evap fan blowing in the freezer section. this blows your cold air into the fresh food side. do you have ice build up on rear wall of freezer section?
Jun 21, 2009 | Refrigerators
Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator section not cold
u would need to replace heater and tstat and defrost timer depending on model
Mar 19, 2009 | Refrigerators
Both the Freezer and the Refridgerator quit working...
Do you have ice build up on the back wall in the freezer? If so you have whats called a defrost problem. (can be timmer, adc, heating element or thermostat)... All cold air in you fridge side come from the freezer, therefore if you have ice build up behind back wall in freezer it is blocking air flow....
Dec 21, 2007 | Maytag MTF2156GEQ Top Freezer Refrigerator
LG LFC23760SB Side by Side Bottom Freezer French Door Refrigerator Logo
223 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
