Question about Craftsman Single Speed Rotary Tool
How do I change parts, i.e. from grinding wheel to sandpaper wheel?
    Problem Solver:
  • 13 Answers
There is a collet type on most rotary type tools. This is located on the end of the tool where the grinding wheel is inserted in the device. The collet has a normal thread pattern. Turn counter clockwise to loosen the collet. Some time the collet gets tightened to toght and then just take a block of wood and gently hit the collet to see if this will loosen the bit.
Posted on Mar 16, 2011
I have a honda c-rv 97 and it produces grinding sound on the rear left wheel. When I jacked the wheel and tried to remove it, rhe rim got stucket with the wheel drum so I used a piece of timber to hit the...
Most likely your rear brake shoes are worn down far beyond the min limits and you now have metal to metal contact, which causes the grinding noise, overheating and poor braking. You most likely will need to replace the drums. The other rear wheel will probably be the same.
Feb 05, 2015 | Honda Cars & Trucks
Car Headlights. How do I remove the film. I assume it is with sandpaper,but I need more details. HELP
they make a kit that you can buy from an auto parts store to do this, I have used it in the past and depending on how bad the lenses are it works pretty well. BUY the best kit with the grinding/buffing wheel for best results and follow the manual. Let me know if you need more assistance.
Jan 01, 2012 | Red Devil Devil 289022 220 Grit Sandpaper...
I've got a B & D Pro 4247 Grinder and I need to change out the grinding wheel and use another (because of the material that I'm grinding)... but I don't know how to remove the wheel that's on the...
if you don't have a spanner wrench, I would find a punch and loosen the outer flange, but the spanner wrench is not that expensive to have in the future. the part number is 149645-00. let me know if you need more assistance
Feb 11, 2011 | Black & Decker 7750 4 1/2'' Small Angle...
The screen color started flashing funny. I turned the TV off. When I turned it back on, it makes a horrible groaning almost grinding noise, on and off, then finally stops trying to do what ever it's trying...
This tv have a colors wheel,it dying,now it dead.Colors flashes black&white and grinding noises,the colors wheel was spinning off of it motor axis and rubbing it sides wall.The colors wheel,now require changing to make the tv work again.The colors wheel it pretty hard to replaced,because it require take out many machanicals parts even can get to the colors wheel to replaced it.Best it to hire a tv tech. to do the job.If u never done or change anythings,that require take out alots and many machanicals parts before.
Oct 20, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
I am getting a grinding noise fron my front wheel like a sandpaper sound is it the brakes? any thoughts on this?
seems that the disc pads are rubbing continuously against the disc plate. Check the wheel front alignment and/or the disc plate for any change in it's shape.
Jan 26, 2010 | 2007 Yamaha YZF-R1
My daughter want to change her Scion alloy mag
That's definitely possible.
She'll need to thoroughly wash the wheel.
Then she'll need to sand the wheel down using 120 to 320 grit sandpaper in order to remove the gloss from the current finish and prepare it for primer. If your wheels are chrome, you need to get below the glossy surface to the dull finish below. Use 600 grit sandpaper to smooth out the the rim.
Then use a rag to remove the remaining dust.
If the tire is still on the wheel, tape and cover up the tire.
Lay the rim down on a flat surface in a well ventilated area and spray 2 to 3 coats of primer
Once it dries, gently sand it again with 600 grit sandpaper to to smooth it out again. use a rag to remove the excess dust.
Then spray 2 to 3 coats of the paint that she wants. and let dry.
Sand again to remove any runs in the paint.
Then spray 2 to 3 coats of clear coat. sand with 1000 to 1500 to remove any burrs. Then use a polishing agent to bring the shine back
Sep 22, 2009 | Scion TC Cars & Trucks
Rollers don't appear to grab the papers it won't print
the rollers aren't grabbing the paper because the teeth on them are wearing out, on the lexmark printers you usually can't get replacement parts cause they aren't available, you would have to get a new printer.
Since the model of your printer is not listed here I would verify with Lexmark about the availablity of parts for your printer just to be sure.
Here is the Lexmark tech support number:
1-800-LEXMARK (539-6275)
Aug 15, 2009 | Office Equipment & Supplies
Paint is blistering on edge of hood. Can it just be re painted, or is hood replacement. This is a 2004 Ford Explorer.
First Wash the area, than take a dremel and with the wire wheel @ high speed, grind off the bistering and feather as best into good paint. Next rough up the area with some 100 grit sand paper. Use body filler (bondo 2 part filler) and smooth over with plastic blade. When dried work with 220 grit sand paper till you achieve the lines you want. spray cover with primer and apply touch up paint(Dealer has the best matchs) in coats. When happy with color use a 400 grit wet sandpaper to get a highly smooth finish and when dried cover with a clear coat finish.(Auto part stores). Buff when that dries and I guarantee thats the cheapest easiest d-i-y- fix you can get.
Aug 08, 2008 | 1995 Ford Explorer
Open Questions:
Craftsman Single Speed Rotary Tool Logo
220 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
