Question about Savin 2545DP Black and White Copier
We have a Savin 2545 copier. We received an error message SC 726. Can you give me some idea what we need to check?
  • 34 Answers
That error is for the shift tray motor in your finisher where the copies come out. The tray should move from side to side when you switch the machine off and on. It sounds as if it is binding for some reason.
Posted on Mar 14, 2011
How do I wipe the hard drive from a SAVIN 2545 Copier manufactured in 2002?
you can use aomei partition assistant, it is free and has the feature erase hard drive, you can see this tutorial: http://extend-partition.com/help/wipe-data.html
Jan 11, 2013 | Savin Office Equipment & Supplies
My SAVIN 2575 is giving error code sc820, any idea what the problem is ?
Unfortunately, I've never seen this error, so I can't give you much help beyond what the code means and the possible solutions that the service manual provides...
SC820:
Self diagnostic error: CPU - Unexpected external error or interrupt occurred.
• Controller board defective
• Software defective
The manual indicates this is a "C" type code, so this should not be displayed on the OP panel, only logged in the SC history in the machine.
Jun 23, 2011 | Savin 2575 Black and White Copier
Savin 2545 communicating light blinks but nothing prints
YOU NEED YOUR FIRMWARE UPGRADED BUT ONLY A SERVICE TECH CAN GET IT AND DO IT.1 HOUR OF TIME SHOULD BE PLENTY AND THAT SHOULD INCLUDE A CLEANUP PROBABLY ABOUT 150 TO 200 DOLLARS
May 18, 2010 | Savin 2545DP Black and White Copier
Savin 2545 document feeder gives a gray band on the copies
Yes - surprisingly - we had the same problem, the gray stripe along the side of the page only showed up when the original was fed through the document feeder on top. Cleaned the small area of glass under the feeder repeatedly with no change to the resulting stripe, but then while cleaning the upper roller, above the area of glass where the scan lamp illuminates during the copying from the ADF, we found a small piece of paper adhering to the top roller in the paper path, cleaned it off, and no more band. We didn't see the bit of paper on the upper roller until we rolled it while cleaning. Still can't figure how that made a stripe....but hope this helps you.
Feb 22, 2010 | Savin 2545DP Black and White Copier
Savin 8025 SC-546 error message
you have an over heat error. you need to test your thermistors, s and lamps for continuity.replace bad parts. then you need to go to service mode and reset the code
Jan 28, 2010 | Savin Office Equipment & Supplies
Savin Copier 2020, IP 192.168.2.100 functional error SC672
yes a 672 is an address book error. do you have scanner feature on this machine?. it may be bad. you may need a tech to come remove the option. turn the machine on and use it as a copier. then reinstall the option and see if the error returns. it could be a static build up or the option is bad.
Dec 26, 2009 | Savin Office Equipment & Supplies
Functional problem with the copier (Savin 2545) Service Code SC 546
Hello sir; Your machine need to reset, the procedure as follow;
1, press "clear mode", "107", then hold down "clear/stop" key, until screen change message to sp mode.
2, turn power off and back on ,machine will in working condition.
May 29, 2009 | Ricoh Aficio 450 Copier
Savin 2545 copier error code sc541
Hit the yellow botton ( Reset/ CA), then 1 then 0 then7 , then hold down the (Stop) botton till the display changes... Then turn the copier "OFF" then "ON" it may clear the code. The code has to do with your fixing unit.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Savin 2545DP Black and White Copier Logo
135 people viewed this question
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
