Question about HP D4360 DeskJet Printer InkJet
Hp deskjet D4360 printer prints in purple instead of black. Is there a fix?
  • 238 Answers
SOURCE: HP Deskjet 5150 won't print black
ya hi, the nozzels must have got dried up and choked, put a few drops of hydrogen peraoxide on the nozzel for some time and then clean it, this will free the pores in the nozzel, be careful with the chemical, or take some proffessional assistance.. let me know
Posted on Dec 16, 2007
SOURCE: HP Deskjet 4280 does not print. 'E' error on Control panel button
I had the same problem. It was solved once I bought an original color cartridge. Refilled cartridge seems not to work on this printer. Glad if it might help.
Posted on Jun 18, 2009
  • 523 Answers
SOURCE: HP Product Assistant disk
go online to Hp webpage, download the driver and install it. it will fix your problem.
Regards
Posted on Aug 02, 2009
chanddra2009
  • 615 Answers
SOURCE: hp deskjet d4360 keeps going online and offline
Dear sir,
It seems to be problem with computer USB port.
First check with another USB port or connect it to the another computer.if problem solved,may be problem with your computer USB port or If it shows the same problem,the problem is from the printer side,printer main board have to replace.
leave a feedback,we glad to assist you
Have a nice day!
Posted on Sep 14, 2009
SOURCE: A Deskjet 990 that only prints in pink and black.
If you've already gone through all the HP recommended troubleshooting steps for this, at http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00224&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=61237, then I would highly recommend the unconventional (and unsupported by HP) method that has worked for numerous people having the symptoms you describe with multiple model families of HP deskjet printers:
http://www.fixyourownprinter.com/forums/inkjet/13694#20
  1. You soak the bottom of the color cartridge (the nozzle) in very hot water for 20-30 minutes and (optionally) run it under hot water in the sink.
  2. Dab the tip against a paper towel, careful not to leave lint behind on the print cartridge, and make sure you see all three colors coming out.
  3. Let the cartridge sit out for 20-30 minutes to completely dry before inserting it back into the printer.
If you read through some of that thread, you'll see that it seems to work for most people. Some people had to go through those steps several times before color was printing again.
Good luck! david
Posted on Feb 15, 2010
My printer won't print in color
Check your color ink levels, the cartridge may need changing.
If they are fine check in the printer settings that you have both color and black cartridges are selected to print from.
Enter control panel, click on Printers (may differ for you), right click your HP D4360 and select properties, you will see a maintenance tab, select the tab and search for Ink Cartridge Settings. In there you can choose what cartridges to print from.
The names of the tabs may differ slightly as its not the exact model I have previously worked with.
Jan 09, 2011 | HP D4360 DeskJet Printer InkJet
Which cartridge do i take out for photo printing
yesssssssssssssssssss,,,,,, if urs is having a PHOTO print Support
May 04, 2010 | HP Deskjet D4360 InkJet Printer
My text papers are printing grey instead of black
Suggest you check your print properties page. Look at the Features tab. check the Print in grayscale, print high quality (multiple passes) or black only (one pass).
Hope this works.
Apr 13, 2010 | HP D4360 DeskJet Printer InkJet
When i try to print from microsoft 4.5 i get an out of memory (deskjet d4360) if i switch to my other printer canon it prints fine
Issue : The solutions in this document address the issue of print jobs getting stuck in the print queue need to restart to get the print
Solution :
Check this link
Step one: Download and install the Print Diagnostic Utility
Step two: Run the Print Diagnostic Utility
Step three: Resolve diagnosed printing problems
Solution two: Resolve the issue manually
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01851354&cc=us&lc=en&dlc=en&product=3374281#Solution1
Jan 03, 2010 | HP D4360 DeskJet Printer InkJet
Printer is printing wrong colors
Make sure it's the right ink cartridge for that model printer.
Check if any of the colors is out
Try running a calibration on the printer to make sure heads are lined up properly.
Link to the manual - Aligning print cartridges is on Page 70.
http://h10032.www1.hp.com/ctg/Manual/c00905552.pdf
Apr 06, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Brandnew hp deskjet d4360 and it's not printing dark enough at all.
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | HP D4360 DeskJet Printer InkJet
HP D4360 DeskJet Printer InkJet Logo
81 people viewed this question
Seeker5211
Seeker5211
