Question about Microsoft Xbox 360 Elite Console
I have wireless internet, and a wireless adaptor for my xbox. Its saying the signal is too low. How do i boost the signal?
  • 108 Answers
Here is a great entry for way to increase your signal. WIFI-Boost. Aside from physically moving it closer to the modem/router and/or running a cable to it.
Posted on Mar 14, 2011
My x box 360 keeps freezing ans saying you are disconnected from xbox live, what do i do ?
If your screen freezes when playing on Xbox LIVE, the problem may be related to your Internet connection. A weak wireless signal can cause poor Xbox LIVE performance. If you are using wireless connection:
1. Go to My Xbox and select System Setttings. 2. Select Network Settings. 3. Select Wired Connection or the name of your wireless network. 4. Select Test Xbox LIVE Connection.
If your wireless signal is only one or two bars, try improving your signal strength by following the suggestions below.
  • Move your router or gateway off the floor and away from walls and metal objects such as metal file cabinets).
  • Minimize obstructions along a straight-line path between your Xbox and your wireless router or gateway.
  • Shorten the distance between your console and your wireless router or gateway. Ideally, your network hardware should be near the center of your home.
  • Change the position of the antenna on your Xbox 360 Wireless Networking Adapter (external adapter only).
  • Turn off wireless devices. If your router uses the 2.4 GHz band, try turning off wireless devices, such as 2.4 GHz cordless telephones and Bluetooth devices.
  • Try changing your wireless channel. Wireless routers and gateways can broadcast on different channels and one channel might be clearer than another. See your hardware documentation for help changing wireless channels.
  • Add a wireless repeater to extend your wireless network range. You can boost your signal strength by placing a wireless repeater halfway between your router or gateway and your console.
  • Add an Xbox 360 Wireless N Networking Adapter.
  • Switch wireless signal bands. If you have a dual-band router and an external wireless adapter, try switching the router to a wireless protocol that transmits on the 5 GHz band (wireless protocol A or N). Please see your hardware documentation for help with changing the wireless protocol.
  • Switch to a cable.
Apr 05, 2011 | Video Game Consoles & Games
We have virgin wireless and a wireless adaptor but it is telling me that my signal it to low is there anything i can do to boost the signal
There are a few 'signal boosters' can you purchase that claim to boost the signal.
But, honestly, most of them are a scam.
I'd save your money and just ghetto-fy it.
Basically, put a metal pie pan underneath your virgin mobile adapter, this will amplify the signal.
For free.
Mar 14, 2011 | Microsoft Xbox 360 Elite Console
My wireless adapter says i have a good connection, but when I go to play games online my signal strength changes so much it makes the game glitch
Whats going on is that your signal strength from the router is good but when playing a game the green bars that you see are not that of the signal strength but that of the internet Speed. Seems the signal is there but the internet speed is not I would restart modem and router see if this helps boost speed you can always check speeds at speedtest.net to be sure you are getting what you are paying for.
Jan 24, 2011 | Microsoft Wireless Network Adapter Xbox...
My connection is very bad, is it because of my wireless adaptor?
The problem is not with the wireless adapter . Your problem is your wireless connection has low band with and your not getting a strong signal . Try moving your 360 closer to your wireless base station or to a room thats closer to your wireless . If the problem persist use an internet cord and run a direct link to the wireless base to the xbox 360 . Also check to make you dont have any other wireless devices connected to your network as this can reduce your band with and cause your Xbox 360 to not get a strong signal .
Dec 14, 2010 | Microsoft Xbox 360 Console
Constant red light now on my xbox wireless adaptar after working
my first suggestion is check your setting to make sure everything correct. to be sure re-enter everything if you still have problems. I would then check if the adapter can read your router (this can be done by searching for a signal). if the router is found and can connect but failes connecting to internet your router itself may not be connected. make sure your router can connect by itself and that you can connect to internet through the router from your computer. if all these steps are takin try config your router so it will accept incoming signals and that it has the right security for the xbox to connect.
Feb 02, 2010 | Microsoft Wireless Network Adapter Xbox...
I have just set up my computer with wireless internet. My laptop picked up the signal with no problem. I have purchased an wireless adaptor of the x-box 360 but am unable to connect to the internet. It...
On the setup for your wireless network through your router, you have to allow access for other devices. Your internet provider should also be able to walk you through this process as they did for me when I had the exact same problem.
Jan 01, 2010 | Microsoft Xbox Console
How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
The easiest way to connect to Xbox Live without using your pc is to buy a
wireless network adapter for your Xbox.
You would then go into the system settings on the Xbox and configure the settings for your wireless network.
http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
Xbox 360 - direct to internet - No PC.
Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
Connection wont work
it could be a number of things first make sure the firewall on ur pc/laptop is set to low then try again if this does not work u will have to go into ur routers settings from your pc/laptop .if this is the case open your internet browser and type 192.168.1.254 and press enter then your connection information will come up click wireless on the left hand side the click custom services then go to the box and scroll down to the bottom and and u will c xbox live click it then it should say select host device click the box then click on your xbox whitch i think will be the bottom one
Jan 10, 2009 | Microsoft Xbox 360 Console
Message saying put disc into xbox 360
1. Turn off your XBox and unplug all cables from the console and the wall, including a wireless adaptor if you have one.
2. Clean off your game discs using a non-scratch cloth.
3. If your game discs are already scratched, you can most likely take them to a video game store, such as EB Games, and get it cleaned for a small fee.
4. Plug your cables back in, except for the wireless adaptor or network cable (ie. don't connect to the internet).
5. Start up one of your games and see if it loads.
6. If it loads, turn off your XBox, and connect to the internet.
7. If it still does not load, it may be a disc drive problem in which case, contact Microsoft XBox 360 support at: www.xbox.com
Dec 28, 2008 | Microsoft Xbox 360 Console
Low signal from my wireless adaptor / router
Have you tried connecting the laptop in a different wireless network? Try changing the channel in your router and you may also upgrade the firmware of your router.
Oct 04, 2008 | NetGear WGR614 Wireless Router
Microsoft Xbox 360 Elite Console Logo
76 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
