Question about Samsung LN40A630 40 in. LCD TV
How to install fan #1 - Samsung LN40A630 40 in. LCD TV
    Top Expert:
  • Samsung Master
  • 74,482 Answers
Hello
Put on the work gloves. Turn the Samsung rear-projection television around so that the back is facing you. Use the Phillips screwdriver to remove the screws from the bottom left, the bottom right and across the bottom of the TV. Remove the screws that are directly above the ones on the bottom left, the bottom right and the bottom of the TV. Put the screws aside
Insert the flat-edged screwdriver into the seam between the bottom plate and the back of the TV. Wiggle the flat-edged screwdriver into the seam to loosen the bottom plate. Remove the bottom plate and put it aside.
Locate the fan assembly inside of the TV at the left corner. Use the Phillips screwdriver to remove the screws from around the fan assembly. Put the screws aside.
Posted on Mar 14, 2011
  • The Knight
    The Knight Mar 14, 2011
    Pull out the fan assembly's power cable from the connector inside of the TV. Pull the fan assembly out of the TV.
    Use the Phillips screwdriver to remove the screws from around the defective fan in the fan assembly. Remove and discard the defective fan. Insert the replacement fan in the position that is now vacant. Use the Phillips screwdriver to attach the screws to the replacement fan.
    Place the fan assembly back into its position inside of the TV. Attach the power cable from the fan assembly into the connector inside of the TV. Attach the screws to the fan assembly using the Phillips screwdriver. Screw the bottom plate back onto the TV using the Phillips screwdriver
    OK.
It is making a loud noise as if it is catching onto something it comes and goes sometimes louder than first time it started
I'm guessing your problem is the fan in the oven. To fix: 1. with oven cold, remove back wall fan cover in oven. 2. remove fan. 3. clean and lubricate. 4. install fan. 5. install fan cover making sure fan is not touching. If cover does touch fan, gently bend cover away from fan and install.
May 15, 2016 | Ovens
How replace fan belt for Ford Crown Victoria 2000?
Mechanical Fan Belt Removal & Installation - Refer to Illustration below
Ford 4.6L Engine - Ford Crown Victoria, Mercury Grand Marquis, Lincoln Town Car, Marauder
1. Loosen the fan clutch-mounting shaft from the water pump hub.
2. Loosen the fan shroud from its radiator mounting and remove the lower hose from the shroud.
3. Lift the fan and clutch assembly and the fan shroud from the vehicle.
4. If necessary, remove the fan-to-fan clutch retaining bolts and separate the fan from the fan clutch.
CAUTION
Closely examine the fan for cracks or separation, to avoid the possibility of personal injury or vehicle damage.
To install:
1. Assemble the fan and fan clutch. Tighten the retaining bolts to 15-20 ft. lbs. (20-27 Nm).
2. Install the fan and clutch assembly and the fan shroud. Mount the fan clutch shaft to the water pump hub and tighten to 37-46 ft. lbs. (50-62 Nm).
3. Slip the shroud into the lower mounting clips and install the shroud retaining screws.
Fig. 1
To view this JPEG image better, you can Right-click on it, "Save Image As..." then
view it or enlarge it within Microsoft Windows Media Player, or Real Networks RealPlayer.
Sep 04, 2011 | 2000 Ford Crown Victoria
Hi i just bought 3 chassis fan and i installed 2 on top and 1 rear... there is already one installed in the front when i bought the case....i want to know wich direction i have to put my 3 chassis fans (2...
Case fans tend to blow in the air out of the side of the fan which has the four plastic bars and normally the sticker. The fan may also have a set of arrows describing direction of rotation and flow of air.
May 18, 2011 | Computers & Internet
Need diagram for serpentine belt
Fig. 1: Exploded view of the belt drive fan assembly-1992 vehicle shown
To install:
1. Position the fan on the drive clutch. Install the bolt and washer assemblies, then tighten to 12-17 ft. lbs. (16-24 Nm).
2. Position the fan drive clutch, fan assembly and fan shroud, then bolt the fan and clutch assembly to the water pump hub. Install and tighten the clutch retaining bolt and water pump assemblies evenly and alternately to 15-22 ft. lbs. (20-30 Nm) for the 3.8L engine or to 36-47 ft. lbs. (48-65 Nm) for the 5.0L engine.
3. Install the fan belt. Align the fan shroud and adjust for equal fan-to-shroud radiator clearance but maintaining a minimum of 0.38 inch clearance to the fan tip on 5.0L engines.
4. Install and tighten the shroud retaining screws. On 5.0L engines, snap the air deflector assembly to the sub-frame cross brace.
Hope helps (remember to rate and comment this
Dec 03, 2010 | 1995 Ford Thunderbird
I need a serpentine belt diagram for a 1991 ford thunderbird v-8 5.0
To install:
Hope helps (remember to rate and comment this).
Oct 01, 2010 | Ford Thunderbird Cars & Trucks
Replacing fan clutch
prev.gif next.gif Engine Fan REMOVAL & INSTALLATION Except 5.2L Engines VISCOUS DRIVE FAN
  1. Remove the upper fan shroud bolts and lift the shroud from its lower securing tabs. Fig. 1: Remove the fan shroud 86743p24.jpg
  2. Remove the accessory drive belts.
  3. Remove the fan flange-to-pulley mounting nuts. Fig. 2: Remove the fan flange-to-pulley mounting nuts . . . 86743p25.jpg
    Fig. 3: . . . then remove the fan assembly 86743p26.jpg
  4. Remove the fan and viscous drive as an assembly.
  5. Remove the fan blade-to-viscous drive bolts and separate the assembly. To install:
  6. Position the fan on the viscous drive. Install the bolts and tighten them to 187 inch lbs. (24 Nm).
  7. Position the mounting flange of the viscous drive assembly onto the pulley. Install the nuts and tighten them to 18 ft. lbs. (24 Nm).
  8. Install the accessory drive belts.
  9. Insert the shroud into its retaining tabs and install the upper bolts.
Aug 11, 2010 | 1996 Jeep Grand Cherokee
04 trail blazer
there is a big nut that is part of the fan clutch that unscrews from the water pump .I use a long punch to break it loose then a big adjustible wrench.
Aug 25, 2008 | 2004 Chevrolet TrailBlazer
Light cover/Dish for ceiling fan
My installation instructions say call 1-800-295-4448 and give the following infromation: 1. Part number 2.Part description 3. Style number of your fan. It is part number 31 Glass Shade
Jul 11, 2008 | Dryers
Casa Blanca Fan Installation
how wide is the beam - be more specific please.
Sep 10, 2007 | Casablanca Fan 6373T Victorian® Oil Rubbed...
Samsung LN40A630 40 in. LCD TV Logo
166 people viewed this question
Henry  Thomas
Henry Thomas
