Question about Lenovo Computers & Internet
Last night i was working on my Lenovo laptop, it was all going well, suddenly my laptop switched off immidiately and i switch on the adapter/battery with laptop but it was not detected on laptop at that time and my laptop worked for a minute or two and again it turned off and not displaying anything on screen. but the three lights of bateery is enabled plz help me out
  • 746 Answers
Check you RAMs and replace with each other on slauts.Contact me back for further more information.
Best of Luck
Posted on Mar 14, 2011
Lenovo thinkpad t400 laptop wont open
try changing the keyboard because switch is on keyboard and use adapter to plug and test
Mar 25, 2014 | Computers & Internet
Slow booting and sudden switch off
The reason may be one or more problems acting together. The problem nowadays is that it is very difficult and time consuming to monitor and take care of your Lenovo laptop. Even experienced users find it hard to perform such tasks on regular basis because you might need to prepare a huge amount of time and energy to deal with each issue separately.
If you want to fix the problems more efficiently, try the Lenovo speed up program. Regards!
Aug 02, 2012 | Lenovo 3000 Y500 7761 Laptop AC Power...
Laptop is not switching on
The Lenovo maybe damaged beyond repair.
You should not have turned on your Lenovo and imediately removed the battery then drained the water and place the Lenove in a warm dry place for several days to make sure it was completely dry, then take it to a computer repair shop and get them to check out the Lenovo.
I suggest you take it to a computer repair shop, they may charge you for a quote unless you go ahead with the repair.
You could remove the battery and dry out the Lenovo for several days and then replace the battery and then boot it up. If it does work then I suggest you get a new laptop.
You can remove the hard drive and insert it into an USB hard drive adapter case and use it as an external USB hard drive.
Apr 12, 2012 | Lenovo 3000 Y410 Laptop
My lenovo G550 appears not to charge when the charger is plugged in despite turning the mains power on and off to see if power is getting though and the blue neon light showing on the mains...
Hi m529,
I see you are having issues with you G550 charging.
You mentioned that the light on the charger is lit up but then it suddenly switches Off, and you also mentioned that the charge still has a light but the power is somewhat low despite of a fully lit up charger Light.
Have you tried draining the power from the system?
  • Remove the battery and the Charger or AC Adapter as well call it from the G550 then press and hold down the power button for 10-15 seconds to drain power from the system motherboard.
  • Once drained connect the AC adapter but do not connect the battery yet, then turn the Laptop ON to see if the system will power ON using the AC adapter/Charger if it powers up then there is no problem with the AC adapter/charger.
  • After testing the AC adapter if it is working power down the Laptop doing a normal shut down.
  • Once shut down or turned Off insert the Battery back in the Laptop then turn the Laptop ON using the battery only without the AC adapter/charger see if the system will turn ON using the Battery only.
  • If the Laptop powers On using the battery alone with out the AC adapter then the battery is most likely working as well on the issue.
  • Now power down the Laptop then connect the AC adapter to the Laptop with the Battery in the Laptop as well then turn the system ON again see if the problem will Occur again having the battery and the AC adapter/charger if the Problem happens with both Battery and AC adapter on the Laptop then the problem is the Motherboard, most probably the motherboard is having issues relaying power from the AC adapter to the battery and may be sent to the Depot for repairs.
I suggest that you call Lenovo for further information about your system, if you still have warranty and is still in the one year period then your system will be covered for any repairs needed - you can call @ 1 877 453 6686 for troubleshooting, you will be asked for a serial number Located underneath the Laptop on a small white sticker that states s/n meaning serial number.
I hope that this Helps.
Have a nice day,
mvincentc
Jun 18, 2011 | Lenovo G550 PC Notebook
My lenovo 3000 Y 500 7761 47Q is shutting down abruptly. Hi Team, I am using Lenovo Laptop since Aug 2007. Around an year back April 2009 my laptops adapter was short circuited and I purchased a new one...
Have you tried a different battery. When the system is on, please check your battery settings to see if it is fully charged. Go to Start/Control Panel/Power Options and the very last tab.
This should tell you how much battery power is in. If it is very low it means that your battery is not getting a full charge and this could be the cause of your problem.
Let me know how it goes. Don't forget to vote for me.
Mar 24, 2010 | Lenovo IdeaPad Y510 Notebook
Lenovo 3000 N200 laptop not starting up, power light on
Keep pressed the power button of your laptop for about 30 seconds, the machine will power down.
--The above step may not be required as already so many days passed by.
Then plug it into the power adapter.
Switch the laptop on.
Boot in "safe mode" (F8 during boot).
This will fix any driver or some operating system issue during previous failed boot process.
Once it boots completely, do a normal shutdown and reboot your laptop in standard mode (no more F8 this time).
Now your laptop will be ready to use.
Sep 30, 2009 | Lenovo 3000 N200 Notebook
My Compaq Pres V2000 laptop does not get on with power on switch
Take out the battery and only hook up the AC Adapter to see if the laptop turns on. If it does then you know the battery is shorting out the laptop and either has very little power to turn on the laptop or is shorting out the laptop cause its bad.
If you don't get the laptop to turn on, make sure your using a well known working wall outlet to plug the laptop to and only use the AC Adapter. If you AC Adapter is hooked up and the Green Led turns on then you know the adapter is good.
After those two steps, you can also try taking out the dvd drive and the hard drive. Then try turning on the laptop and if the laptop still doesn't turn on then the motherboard is bad in the laptop.
Aug 29, 2009 | HP Compaq Presario V2000 Notebook
HP nx7300 no boot
I guess your battery needs to be flash.
Apr 10, 2009 | HP Compaq nx7300 Notebook
Panasonic cf51 toughbook display
you HAVE a cosmos virus i got one recently basically your boned unless you wana pay out the ass to fix it when you'll eventually spend the amount of a new one and give up on it like me ............... i didnt have the same computer just the same problem
Oct 26, 2007 | Panasonic Toughbook 51 Notebook
Computers & Internet Logo
103 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
