Question about Kodak EasyShare M853 Digital Camera
How to reset a Kodak M853. I does not recharge battery through USB from a computer anymore. I just received 2 new batteries and still not recharge them. When I plug USB cord on the camera, I have 1 green and 3 red blinking ant after nothing. I just ordered a AC and a car charging unit. I hope it will solve the problem. I also cleaned the battery contacts on the camera.
SOURCE:
mads_aye
  • 58 Answers
SOURCE: kodak easyshare m853 digital camera
is the light that's coming on green or red?
if it's red, there's a charging error - contact kodak, they may provide a 5v ac adapter to resolve your charging issue
if it's green, was it blinking or solid? is the battery drained?
if the battery still has a little charge on it, please connect it to the computer then turn it on, check if there's power light
check if the screen is black - that means it's making a connection and the charging is the only issue - computer not detecting it, maybe resolved by kodak's software support
if the camera screen is active - that means there's definitely something wrong with the camera
arrange repairs with kodak, include the battery and usb cable
please visit
www.kodak.com/go/itg - troubleshooting and repair
www.kodak.com/go/usbcharging
Posted on Feb 13, 2008
SOURCE: kodak z812 is problem
I had the same issue with my same brand/model camera for months. I used it maybe twice and then it decided not to turn on, no matter what I did. I finally got in touch with Kodak (the first time they told me to try different batteries, which of course did not help). I spoke with someone who figured out that I had a faulty memory card. When I removed my memory card, I was able to turn my camera on. I had to reset my date, but once I did that (still keeping the memory card out) I was able to take pictures just fine. Give that a try and see if it helps!
Another word of advice, if turns out to be your memory card, you'll need to purchase a new one. Kodak, of course, provides troubleshooting for their brand memory cards as well. Just an FYI.
Hope this helps!
Posted on May 20, 2009
SOURCE: Kodak Z700 not firing up
Same problem as described above. Fresh batteries, turn it on, see the Kodak screen for a second, then it just turns off. I found that if you swith it to the favorites icon (the only one below the Off position) it stays on and I can review photos. But no taking new photos! Help!!!
Posted on Jun 02, 2009
xscrewdriver
  • 246 Answers
SOURCE: Can I use the same USB cable to charge the
Yes, you can use the USB cable to charge the battery. But you need to insert the cable into the computer USB port, no the USB HUB, and the computer is on, not in sleep mode.
Posted on Jul 01, 2009
BillB-SA
  • 2761 Answers
SOURCE: Kodak Easy Share M763 Won't turn on!!
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 15, 2009
Stuck lense on kodak easyshare M853
Try resetting the camera by removing the battery for 15mins then insert a fully charged battery back into the camera and then turn it on.
Dec 26, 2011 | Kodak EasyShare M853 Digital Camera
EasyShare M853 Digital Camera: I lost my charger cum usb cable of kodak digital c...
go to kodak center os showroom and look for univerasl charger to charge your battery and for the usb you can buy card reader to interface you camera to your pc
May 16, 2010 | Kodak EasyShare M853 Digital Camera
My Kodak easyshare M853 want charge.Itworked fine til I let it sit or a while now it want charge. Can you please help? I tried A NEW USB CABLE THE LIGHT FLASHES BUT ONLY FOR FEW SECONDS.I HAVE TRIED 2...
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 30, 2009 | Kodak Easyshare C813 Digital Camera
Can I use the same USB cable to charge the batteries as well as transferring photos to computer from camera. If not could you tell me the serial number of each cable. Also would a universal USB cable be...
Jul 01, 2009 | Kodak EasyShare M853 Digital Camera
Lens error and camera battery not charging.
SORRY TO SAY, BUT I AM READING HORROR STORIES ABOUT THIS MODEL OF CAMERA AND IT'S CHARGING OR LACK OF CHARGING SYSTEM. IT SEEMS IT IS A MAJOR PROBLEM WITH THE M853 AND ABOUT THE ONLY SOLUTION PEOPLE ARE FINDING IS USING A SEPARATE CHARGING BAY. IT SEEMS THAT VISTA HAS A POWER MANAGEMENT SYSTEM ON USB PORTS THAT TURNS OFF THE POWER ON UN-USED USB PORTS AND THAT IS WHY THEY ARE NOT CHARGING. YOU NEED TO GO INTO THE USB PORT SETTINGS AND RIGHT CLICK THEM AND DISABLE THE SETTING THAT ALLOWS THEM TO SHUT DOWN POWER TO THE USB PORTS. IT ALSO SEEMS THAT THERE IS A LOT OF TROUBLE WITH THE MAIN BATTERIES IN THE M853 FROM THE VERY FIRST TIME YOU TRY TO CHARGE THEM. THEY SEEM TO NOT WANT TO TAKE A CHARGE. I KNOW ALL THIS IS BAD NEWS BUT GO TO GOOGLE AND PUT KODAK EASYSHARE M853, NOT CHARGING AND READING THE STORIES FOR YOURSELVES. THEY ARE NOT PRETTY. BEST ADVICE I CAN OFFER IT SEEMS IS SEPARATE CHARGING STATION AND DEDICATED USB PORT YOU KNOW IS HOT. GOOD LUCK ON THIS ONE. IF THE CAMERA IS FAIRLY NEW, I WOULD CONSIDER RETURNING IT! THIS ONE HAS A REALLY BAD TRACK RECORD. IF I CAN HELP MORE, REPLY TO: ARCLIGHT1217
Nov 05, 2008 | Kodak EasyShare M853 Digital Camera
Kodak digital camera
Camera will not charge through USB interface, only DC input jack or camera dock.
Jun 13, 2008 | Kodak EasyShare M853 Digital Camera
I have a camera battery question...Kodak M853.?
Hey cambameriezz,
I would make sure I purchased the correct battery, and if you did I would make sure the battery terminals in the camera are clean by cleaning them with a soft cotton swab. If none of this works I would try charging the camera using the ac adapter rather that plugging it into the computer.
Sincerely,
Allan
Go Ahead. Use Us.
May 04, 2008 | Kodak EasyShare M853 Digital Camera
Kodak easyshare m853 digital camera
please visit
Feb 13, 2008 | Kodak EasyShare M853 Digital Camera
Charging battery
Take it back to the store get your money back and then go out and get a real camera. The m853 is a piece of junk. I had the same / similar problems and Kodak is clueless about the problem.
Nov 20, 2007 | Kodak EasyShare M853 Digital Camera
Kodak EasyShare M853 Digital Camera Logo
114 people viewed this question
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
