Question about KitchenAid KSRS25IL Side by Side Refrigerator
My refigeraton is not cold. how to reset temp? How
My refigeraton is not cold. how to reset temp? How long after I reset temperture it go to normal operation getting cold. if reset does not work whats next thing i do
  • KitchenAid Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
Heater blows cold air and the temperature guage reads cold after driving for 20 minutes
Best case scenario is your thermostat is stuck open. When this happens the engine will take a long time to warm up and will never get up to full temp. Worst case could be a serious problem such as a blown head gasket. If there is no coolent in the engine the temp gauge will not register either.
Dec 15, 2013 | 1999 Ford Explorer
My 2007 Chevy HHR 2.2L, coolant temp sensor is reading that the coolant temp is 20 degrees warmer than the outside temp after sitting for over 12 hours and the operating temp gets to 214 degrees without...
Sure the engine coolant will be warmer than the outside temperture and if the car has been sitting a long time in cold weather and the outside temperture warms up it could be the other way around. The coolant temperture sensers aren't real accurate as they are a relaitive senser beween hot and cold and the numbers reported don't have to be real just the change from hot to cold and the reching of the coolant to the operating temperture. Noe it the senser doesn't read the opertating temperture coprrectly you'll have all kinds of problems. The therostaste will try to set the temperture of the water to it's set temperture and can open or close completly to get 195 degrees F. Many times if it's too cold then the stat is bad and needs to be replaced This shows up in alot of cars first thing after winter and the first onset of cold weather when the daily tempertures vary the most from day to night.
May 06, 2011 | 2007 Chevrolet HHR Special Edition
How do you program this heater
temp setting
1. press the temp/timer button untill the temp icon blinks
2 use up and down arrows to set temp.3 the temperture icon will stop blinking and the current room temperture will appear after desired temp. is set.
4 the heat will turn off shortly after the desiredtemp. is reached and the temp. ndisplay will blink.
5 the heater will turn back on when room temperture drops below the set temp.
timer : auto -off press the temp/time button untill timer icon blinks. the hour display will apear. the auto off icon will also appear.
2. use up and down arrow buttons to set the heater operation time between 1 and 10 hours. this function will activate once the timer icon stops blinking.
3. the heater will automaticly turn off when time runs out.
set temperture first so heater will cycle on and off till shut down time reached
Feb 02, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
Operating temperture changes from center to 3/4 on Gauge recentl
for the cost of it renew the thermostat ,dont forget teh antifreeze ,2 litres of pure minimum ,if in a cold zone then pure antifreeze
Jan 09, 2010 | Hyundai Motor 2003 Elantra
With AC on cold, Drivers air full hot & passenger side full Cold
that is a good possibilty, but before I pulled the trigger I would try this first. unhook the battery for 5 minutes, rehook it, now turn the key on, wait for 2 minutes, now start the truck and see if the doors now work. sometimes this works, its worth a try.
Sep 26, 2009 | 2005 GMC Sierra
Temp gauge up and down
It is IMPORTANT That you Correct This ,as Engine Temp is Important. I Recomend the Coolant Temperture Sensor Be Replaced to Correct this.
Sep 11, 2009 | 2003 Dodge Stratus
Temperture gauge goes from normal temp to cold and back repeatly when at free way speed
Check for a loose connection on the engine temperature sender circuit,
Check/ replace temp sender unit.
Aug 26, 2009 | 2006 Chevrolet Colorado
Changing a 2001 Alero Temperature Gage
Why change temp gauge, unless need be, what is the problem? Thermostat is the cheapest way to start!
Jan 27, 2009 | 2001 Oldsmobile Alero
Tempreture Gauge
I had the same problem or more so that my temp would run cold for miles and miles then go to normal and drop. It was my glow plugs. They needed to be changed. My boyfriend changed them himself in 10 minutes after I had been quoted 2 HOURS for labour!!
Jan 09, 2009 | 2002 Volkswagen Golf
KitchenAid KSRS25IL Side by Side Refrigerator Logo
299 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
