Question about Sceptre X5g-Komodo VII 15'' LCD Monitor
I gives me the message that it is out of range. What do I do?
  • taurinski Mar 14, 2011
    I changed it but it still reads out of range? However, the monitor works when it is in safe mode. Is there anything else I can do?
    Is there any place else in the computer to change this? The monitor tab has the properties grayed out so I can't access it there
    Guru:
  • 767 Answers
This means that your system has been set to a refresh rate or resolution higher than what the monitor can handle.
You will need to press the F8 key while your PC boots up, this will boot it into safe mode. If you are getting the out of range message and cannot see anything even when you press F8 then you will need to get another monitor to change the settings.
When you are able to see the desktop whether it be in safe mode or from another monitor, right click on the desktop and click Properties from the drop down menu. Then go to the Settings tab and click Advanced.
Once in the advanced screen go to the Monitor tab. Now change the Screen Refresh rate to the lowest it can go, 56-60 Hertz should be fine.
Then click OK to exit the Advanced settings. Now check that your Screen resolution is set to 1024X768. Once you have done this click OK to exit the Display Properties window.
Shut down the PC and connect the 15" LCD. Now switch on the PC and it should display fine.
Posted on Mar 14, 2011
  • Jean-Pierre Damstra
    Jean-Pierre Damstra Mar 14, 2011
    Did you change the refresh rate or resolution?
    Is the value under the heading Screen refresh rate greyed out under Monitor tab in the
    Advanced Settings? Also make sure the box is ticked where it says: "Hide modes that this monitor cannot display."
    You can go Start>Control Panel>Display to bring up the same properties window.
    Boot into safe mode change the resolution to the lowest setting or at leat 800x600 (Safe mode runs at 800X600 so you know this resolution works). Then boot up and see what happens.
    Guru:
  • 254 Answers
Hello
it is because the vga you have and monitor you have is not compatible at the first use, you have to press F7 while booting up. or if did not work you have to use another monitor to change your resolution into 800X600 and plug it again into the monitor which is out of range to be able to work.
just leave a comments
thank you
Coolant level - repeating message
Sometimes the float that tells the sensor how much fluid is in the tank sinks. When it sinks it is giving the impression that the tank is empty giving you that low coolant warning. You will have to replace the tank.
Mar 31, 2014 | Land Rover Range Rover Cars & Trucks
Oven gives err message when set above 275 degrees
Your range has been reset to celsius from fahrenheit. It must be reset to fahrenheit.
Press bake and broil pads simultaneous for approximately 3 to 4 seconds.
When SF comes on, press the broil pad.
You should see the Letter C.
Press again and the letter F will come on.
Press start.
Your range shouldproperly set the temprature now!
May 03, 2012 | GE Profile JTP56 Electric Double Oven
When I turn on the stove an F3 message comes on
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nov 26, 2009 | Magic Chef 31000 Gas Kitchen Range
Showing message out of range
Your monitor settings within windows are set too high for the monitor to display... When computer first boots.. be ready and press the F8 key...
Enter safe mode.. Reset the display properties in control panel to 800 by 600 for a start. Setting the resolution too high past the monitors ability will give you that message.. Most monitors are able to display 1024 by 768 just fine.. Out of range.. means the display settings within windows are out of the monitors range of ability to display the screen resolution you have set... Good luck!!
Feb 18, 2009 | Dell Dimension 8200 PC Desktop
Kenmore Range model 665.95792000 gives E1 F3 message
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 26, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Tried to selfclean my NEW oven but get error message F5E1
Reading all the questions and responses - I had the same problem (would press "self clean", it would run for less then a minute then give the error message), so once I saw the code was E5F1 and what it meant (thanks for whoever posted that), I just pressed on the door for the first minute of the cycle, and self-cleaning then worked. Go figure :)
Jan 06, 2009 | Whirlpool RF378 Electric Kitchen Range
FAULTY MGE UPS
a 3 ph ups normally can work upto 450 volts because the normally its the transmisson range of voltage
220 to 250 is the voltage range of normal 1 ph line so check for proper line voltage or load voltage
Nov 06, 2007 | Computers & Internet
Oven gives me an -F3- message and stops working
F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse
May 21, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Sceptre X5g-Komodo VII 15'' LCD Monitor Logo
110 people viewed this question
Top Sceptre Computers & Internet Experts
Cleverer2
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
