LG DR197 DVD Player/HDD Recorder Logo
Posted on Mar 14, 2011
I own a LG DR197 DVD Player / HDD Recorder. While playing a DVD movie it stopped suddenly. Finally it was ejected, but after that, no other DVD could be read with the indication "unknown disk".
5 Related Answers
Kirsten5
  • Posted on Jun 05, 2008
SOURCE: LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
spencers775
  • Posted on Dec 01, 2008
SOURCE: LG RH265 - Problem when trying to register blank disk/dubbing
The DVD needs to initialise the disk first. Come out of the HDD dubbing menu and press DVD on the remote. The blank recordable disk should be recognised and you should see Initialise disk? on the screen. Press Start and hey presto, you can now dub from the HDD Movie dubbing menu (as per the manual instructions).
e_bettio
  • Posted on Feb 02, 2010
SOURCE: LG HDD DVD recorder RH7521W is not able to read
Mine had a similar problem. I assumed there might be some dust on the laser. I used an air compressor and pointed it at the DVD slot as it was opening and closing to blow some air around inside the unit (and hopefully dislodge any dust). It worked. The discs that would not play before did play after. I didn't have the air compressor nozzle too close to the opening as I didn't want to dislodge anything I wasn't supposed to. If it was dust on the laser, you might be able to clean it in other ways, such as removing the cover and using a cotton tip (take power off first!). That would have been my approach if I didn't have an air compressor.
Anonymous
  • Posted on Feb 14, 2010
SOURCE: LG RH278 HDD/DVD Recorder
I have an LG RH278 HDD/DVD Recorder, which was suffering from the problem that it could not play any bought DVD movies, which were previously working fine in that same player. It would however play svcd and DVD+R/-R movie discs.
The solution was to replace the laser tray. I found a new LG DVD BD lens LPC-815 laser tray here: http://www.laser-xh.com/en/?act=showproduct&proid=1147
I bought two for $5.50 each. Shipping was $32 (DHL), all together $45.10 (PayPal fees included). Delivery was fast and accurate within 3 working days (China - Sweden).
Anonymous
  • Posted on Mar 02, 2010
SOURCE: LG DVD Recorder "Unknown disk error"
I have the same problem with my LG DVD player, with some discs saying disc error all of a sudden. I solved the problem by cleaning the lens of the laser very gently. The player must be opened to reach the lens. It is very important to get the plug off the mains so as no electricity supply is in the DVD player. The lens was cleaned by using a soft dry cotton bud (those used to clean the ears). NO solutions liquids etc. were used. Well, till now the problem has been solved. The lens was full of dust which come from the static of DVD's. The rest of the inside of the DVD was generally clean.
I have recordered many home movies to a dvd+r
Dvd+r disks are the least compatible to most devices.
Try using Dvd-r instead.
Will play discs burned from hdd but not commercial movie type dvd
The solution is simple.I rang LG service (so called - LOL)
Asked for a fix or reset method. (Which can be done but they won't tell novices how)
Got no joy, so now I will bin it,and spend the rest of my days telling people to avoid LG.
After all the posts I have since read about the same problem on various LG models,it is obvious their product sucks,they know it does, but won't accept the responsibility.
If I stop 4 people buying their ****,that's at least $1000 they miss out on.
If the process snowballs,how much then$$ ?
It would cost me $120 just to get it to and pick it up from the repair place.
Plus parts and labour added.
Before buying an LG DVD recorder go online and check out how many dissatisfied customers there are. In short, DO NOT BUY !!
Doesn't read my DVD's burnt off my mac anymore
r u sure the format for your DVD that u burnt from MAC is same as DVD that usually can play in DVD player?try to compare your burnt ne with ordinary DVD that can play ib your DVD player...if it is not same, then u have to burn it by using the same format as your ordinary DVD..or if it is same, then your DVD player cannot support the type of DVD that u use...for example like DVD-9, most cheapest DVD player cannot recognize the type of DVD that is used eventhough u use original DVD...
3helpful
10helpful
2answers
LG HDD DVD Recorder remote control not working with LG TV
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
LG rh7624w
Call their tech support. The # is on the DVD.
LG RH277H - won't play bought DVD'S
The cd tray eject after put in the DVD movies, but VCD working fine...it is means that the drive's region code haven't set yet .(please refer to user manual to setting the region code) ..or unplug the recorder drive from the dvd player,using the computer setting to change the region code by connecting to computer's IDE cable .
2answers
Ld dvd hdd player rh7624w recorder
To make the unit play all regions do the following: 1. Put in a DVD that will play (in our case region 2) 2. When it starts playing, press eject 3. While the drawer is open press "0" seven times 4. When you get the "Congrats" press Enter and done! Please update the question & let us know if the information given was useful to you - Good Luck!
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
