Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Why would the water and cleaner solution come out without me pulling the trigger? Thanks
3 Suggested Answers
  • 55 Answers
SOURCE: Water doesn't come out my Bissel rug cleaner model 7901
The flat belt on you machine has an access panel to it from the side of the machine. That belt runs the pump if it is broken or came off the machine won't pump.
Check to make sure both of the red/black circular rubber gaskets on either solution or recovery tank are on the tanks and not stuck down inside the inlet valves on the machine itself.
Make sure there is fluid in both tanks. Without fluid in both tanks the pump loses prime and will not work.
If all that checks out then you are down replacing the pump, but usually when the pump goes out, you will have a short burst of water when you first turn it on and then it stops working.
Hope that helps you out-Good Luck
Posted on Nov 25, 2008
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Cleaner leaks
put a new seal on it
Apr 10, 2014 | Vacuums
Water dispenses without pulling trigger. How to stop it?
you should have a lever which controls this spray slid it all to one side then the other sometimes its just trial and error if this doesn't work then see if it has a cut of valve if so it may be broken
Apr 10, 2014 | Hoover F7225-900 SteamVac V2 Upright...
Leaves too much water on floor. Do I release the trigger to suck up water or keep it pulled at all times?
I don't know the particular brand you're talking about, but in my experience I do one pass with the trigger/sprayer on and then two or three passes with just the vacuum to remove the excess water. Devices with sprayers always need at least one pass over without the sprayer trigger on.
Nov 05, 2013 | Mytee 8904 Spinner Hard Surface Cleaner...
Will not supply water from tank to brushes
Pulling trigger pushes a rod which opens valve to allow water to flow. Follow from trigger down to try to locate problem
Sep 29, 2013 | Hoover Max Extract Steam Cleaner
My bissell steam cleaner will not spray any water or soap how do I correct this problem
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
kjgtllgj
Aug 23, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Hoover Steamvac Upholstery Cleaner will not spray water.
In my case when I pulled the trigger on the upholstery hose I barely got a drizzle of water. After looking at the parts online I realized the valve assembly on the spray end of the hose consisted of a black valve housing, with an inner spring and a white plunger part that sprays the water. The white plunger should move noticeably when the trigger is pulled. Since all 3 part of that valve assembly were replaceable I decided to try and take it apart. First I removed the 2 silver screws on the cover of trigger end of the hose and lifted out the valve assemble. The white plunger part was basically frozen in the black valve assembly. Tried pulling the white plunger out by hand wouldn't budge. So I use a pair of plier and pulled the white part out. Sure enough the whole inside was caked with what appeared to be old dried cleaner. I rinsed the spring and the white plunger. There were o-rings on the white plunger, I did not remove them but used an old tooth brush to clean out around them then reassembled. The white plunger now freeing slides a noticeable distance when the trigger is depressed and getting a large V shaped spray pattern. Lesson learned, I will now make sure I run plenty of plain water through the hose to rinse all the cleaner out after using it .
Jan 12, 2009 | Hoover F5832-910 SteamVac Supreme Vacuum
Getting it to work.
The upper tank is the solutiontank. You mix you water and cleaned in it. The when you pull back slowly squeeze the trigger to release the solution and it will vacuum up also in the the lower recovery tank.
May 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
23 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
