I have a Maytag lat9593. It agitates fine but will not spin and during the "spin" cycle a faint burning rubber smell begins. Is this the trans? Help! Thanks Greg
  • gmfontana1 Mar 18, 2011
    Yes, absolutely. Sorry for not getting back sooner. I did raise the machine, remove the drive belt and tried turning the large pulley. It seemed to bind up at one point in the rotation and I did find a sock stuck at the top of the inner drum. The drive belt was also glaxed and cracked. I replaced both belts.
    Best $12 bucks I ever spent.
    Thanks
    Greg Fontana
  • Washing Mach... Master
  • 2,605 Answers
Welcome to FixYa.
Based on what your describing it could simply be a worn/stretched drive belt. First though, answer this. Does the tub drain OK if you let it continue ?
If it is indeed draining OK, then I'd lean towards the drive belt being stretched and "glazed" so it slips and burns with the load of water/clothing in the spin cycles.
The other possibilities do include the transmission or the brake assembly, but I'd certainly check the belt first.
**unplug the unit from the wall before servicing...safety first**
With the unit empty and leaning back slightly ( careful the edges are sharp under the machine...and don't let it fall on you, use a block of wood to hold it up 6" or so ) turn the drive pulley in the center both ways. One way will agitate, the other spin. Getting it to spin will require some pull though, even emptied.
I will try to help in any manner I can of course, let me know. Good luck.
Regards,
Macmarkus :)
Posted on Mar 14, 2011
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Noise during wash cycle & got even louder on spin cycle then washer stopped completely
Could be bad belt, or agitator sleeve cracked / or broken. Not catching.
Aug 08, 2012 | Maytag HAV3460AWW Top Load Washer
Maytag Performa PAV920AWW makes squeeling sound when agitating/spinning. Water does not drain completely during spin.
Sounds like brake is partially engaged. There is s kit that may fix that. Part # 12002213.
Sep 19, 2017 | Washing Machines
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
My Maytag Performa doesn't work on spin cycle. Burning rubber smell. Belt looks okay. Pumps out rinse water but drum won't spin.
Brakes are locked in the spin cycle or the pinion shaft has dropped down from within the transmission not to engage the agitator.
Nov 05, 2009 | Washing Machines
1 yr machine. Won't spin but has burning smell
The reason to this problem can be due to the
brake rotor.It need's to be replaced.
Sep 01, 2009 | Maytag Centennial MVWC500V Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
Top Washing Machines Experts
