Question about Citizen Eco-Drive Calibre 8700 Wrist Watch
My watch shows a day behind, it is still on time
How do I change the day and date on a cardinal wrist watch?
Hi Andrew , is there a model number on the back of the watch
Oct 13, 2017 | The Watches
Module 3070 - PAW1300 > AM / PM problem apparently. Everything works except day and date 12 hours behind. EX: In HNL (Honolulu) on Monday morning, September 6 watch gives correct time, but shows SUN...
Hi, Obviously you need to roll the time 12 hours ahead. If the watch doesn't receive the Atomic signal properly at first, go to page three of your manual, and try doing it manually following the detailed procedures there.
If you don't have the manual, get it here:
http://world.casio.com/wat/download/en/manual/
Take the four-digit (3070) module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Sep 07, 2010 | Casio Pathfinder Watch Green PAW1300 3V
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
Jul 08, 2010 | Seiko Watches
My red hour hand doesn't stay the same time difference . Sometimes it's two hours behind BST and sometimes six!
mcdevito75 here, Sounds like your watch is showing a different time zone, refer to your owners manual or vist a locl jeweler for adjustment on timeing, setting your watch. Your watch may be set up to show different world time zones, if so, you may have hit a button and now your watch is showing time in a different time zone as an example London / New York.
Jun 29, 2010 | Rolex Explorer II 16570 Wrist Watch
Watch stops or loses time every time i wear it.
normally automatic watch need to wear at least 8hrs in a day ,then it works for next 30hrs.if it stops or loosing time, it indicates that needs service with lubrication .
Feb 23, 2010 | Navy Seal Luminox Dive Watch
I have the correct time and date but the day shows Sunday and it should show Saturday. I need to understand the setting sequence.
The day changes at midnight but if your watch thinks it is displaying 11a.m. when it is in fact 11p.m., then it won't change over until noon the next day.
Solution; wind your watch forward 12 hours (tedious, I know). You will then need to reset the watch to the correct day.
Dec 19, 2009 | Citizen Watches
Setting watch date, day, etc.
yes. i do this problem
Jul 04, 2008 | Watches
Time keeping.
Check in the instructions about the time zone setting and that the feature for auto day light savings are turned on.
If you go to the manufacture site for many of these watches, they have downloadable PDF instructions. They also have service centers that can give support.
Jerry G.
Mar 18, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Citizen Eco-Drive Calibre 8700 Wrist Watch Logo
51 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
