Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Can't secure internet.... I have had this d link for about 3 years never had a problem with it but got new ISP and they had their wireless built in to their modem. then I got another ISP provider I now have to use the d link again and can't secure my internet can you help ??
  • 108 Answers
Try doing a hard reset on the router? Are you trying to change these setting on wireless, if so try connecting to modem with Ethernet cord and then change the setting. Sometimes security setting can't be changed on wireless. Worse case if that doesn't work and are tech savvy/follow directions well you can install DD-WRT or tomato and unlock way more features. You can Google it and have multiple tutorials to set it up. Very straight forward and easy. Or use it as an excuse to update your router!
Posted on Mar 14, 2011
  • Adam Olivero Mar 14, 2011
    DD-WRT or Tomato won't work on this model router. Too old and not Linux based.
  • cheezycow Mar 14, 2011
    Ah thanks for the catch. I misread the model. Acid is correct.
  • 27 Answers
I will be able to help you with this. First can you tell me the model reversion of your D-Link router. Look on the bottom and see if its Reversion A, B, C, D, or E. Then we can go onto securing the router.
What is needed to concect to interrnet
You first need to contact an Internet Service Provider(ISP) and they will help set you up to connect to the internet. The ISP will provide you with all the hardware needed. If you have a computer built within the last few years it should be able to connect to the model wireless( if you have a wireless modem)
Mar 02, 2012 | Compaq Presario CQ60-220US PC Laptop
Problem with D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch
What HW version is your router?
What FW version is currently loaded?
What ISP Service do you have? Cable or DSL?
What ISP Modem do you have? Stand Alone or built in router?
What ISP Modem make and model do you have?
Ensure DNS IP addresses are being filled in under Setup/Internet/Manual?
Turn off QoS options.
Turn off Advanced DNS Services if you have this option Setup/Internet/Manual.
Turn on DNS Relay under Setup/Networking.
Setup DHCP reserved IP addresses for all devices on the router.
Ensure devices are set to auto obtain an IP address.
Set Firewall settings to Endpoint Independent for TCP and UDP.
What wireless modes are you using?
Try single mode G or mixed G and N?
What security mode are you using? WEP, WPA or WPA2? Preferred is WPA2 and Cipher type to AES only if your device support this.
Feb 18, 2012 | D-Link DES 1016D (DES-1016D) 16x10/100...
How do I secure my wireless connection
Hi Joyce,
Either you have to setup the Encryption password ( network key ) or you need to contact your ISP ( internet service provider ) to do so.
Click on the link below and it will guide you how to set security to your router ( network )
Secure D-Link Wireless Router
Regards,Suhail
Nov 13, 2011 | D-Link DIR-300 Wireless Router
I HAVE RESET MY D LINK 624 ROUTER MODEL DI 624 BUT NOW IT IS NOT SECURED. I Had to do this as i forgot password I can't find out how to secure with a new password help help
1. You will have to use the CD that came with the router and go through the "setup Wizard" and establish a new password.
2. contact your ISP ( internet service provider0 and get the information to input into the router to connect properly to the internet.
3. Go to the D-link page and an instruction set for your model router is there to guide you through the setup.
Jun 14, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link VisualStream DSB-C310 Personal Web Camera
Here are the recommended steps to connect to a wireless base router 1. Check and remove power from both your router and the DSL ROUTER/CABLE ROUTER MODEM 2. Wait one complete minute until applying power to modem then wait one minute before applying power to wireless router. 3. Ensure you have green lights across both devices, specifically, the recieved and sent lights. These same lights will tend to blink rapidly when there is active data, at times this will still blink, and a DNS error will prevent you from connecting to the internet. If this is the case, call your ISP Internet service provider 4. Check your authentication Security key on your router first, then check all your wireless devices to ensure they are on the same network name, key, and channel with the same type of encryption as the router 5. Start one device at a time and check for connectivity, if your still experiencing a problem, check the settings on all your wireless adapters, device drivers, internet browser settings, firewalls and proceed. 6. still have problems, connect a rj45 cable from the router directly to your computer to at least see if your wireless settings are bad or if the router may be bad. 7. Contact your ISP to determine if your receiving singal 8. Avoid using a splitter or parital power backup for yours routers 9. Still having problems, change your wireless router only after your ISP changes their faulty modem 10.Attempt the same process when setting up your new wireless router and or modem
Jan 26, 2011 | D-Link VisualStream DSB-C310 Webcam
How to conect with wireless internet
The Network and Sharing Center in Microsoft* Windows Vista* can be used to set up a secure wireless connection to the Internet.
Note: If an Internet connection is not automatically made by the operating system, you may need to contact your access point (AP), broadband wireless router manufacturer, or Internet Service Provider (ISP).
Set Up a Secure Wireless Connection to the Internet
These steps assume that your network adapter; AP or router; and cable, DSL or another type of modem have already been physically connected and configured. They allow you to create a new connection and configure it accordingly.
Follow these steps to set up a secure wireless connection to the Internet.
Note: If a wireless profile does not exist, you will need to create a secure wireless profile before you can set up a wireless connection to the Internet.
1. Access the Network and Sharing Center.
2. Select Set up a connection or network.
3. Click Connect to the Internet.
4. Click Next.
5. Select Wireless. At this point, if the network(s) that are listed say that the network settings do not match the network requirements, as shown in Figure 1, create a secure wireless profile and then follow the steps again.
6. Select a network and click Connect. If you are not connected to the Internet, you may need to contact your AP/router manufacturer or ISP.
To access the Network and Sharing Center, use one of the following methods:
  • Start » Control Panel » Network and Internet » Network and Sharing Center
  • Start » Network » Network and Sharing Center
  • Right-click the network system tray icon (the icon that displays two computer monitors) » Network and Sharing Center
Jan 21, 2011 | Computers & Internet
I hooked up my D'link to modem and computer and connection is good. But i can't find it when i search on laptop wireless connection. I think you need i driver but i can't find one. Thank You
4. Click Next.
B52Computers
Jan 14, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Can you hook the ps3 up to the internet wirelessly
Yes you can connect wirelessly to the internet with your ps3.
Minimum Requirements
  • PlayStation®3 computer entertainment system
    Note: PlayStation 3 40GB / 60GB / 80GB / 160GB models ONLY (20GB model does not have built-in Wi-Fi connectivity)
  • SIXAXIS™ wireless controller (and USB cable)
  • AC power cord
  • A high-speed Internet account (cable or DSL) with an Internet Service Provider (ISP)
  • Router
    • Wireless router compatible with 802.11b or 802.11g Wi-Fi standards
    • Or an Ethernet (wired) router with a Wireless Access Point (WAP)
      You may need to open firewall port numberson your router to connect to the Internet.
      The PlayStation 3 will not connect to the Internet through the USB ports.
  • Updated system software installed on your PlayStation 3
    Visit PlayStation 3 System Software Update to download and install the most recent version.
  • Your Wireless Network Settings
    • SSID
      You will need to know the Service Set Identifier (SSID) of your wireless network. Also make sure the WAP or wireless router is set to broadcast the SSID; otherwise, the SSID will NOT appear on the PlayStation 3 scan results.
      If you do not know this information, speak to the person who configured your home network (i.e., wireless router) settings.
    • WEP or WPA Security Key
      If your wireless network access is security-enabled (encrypted) from open access, you will need to know your WEP (Wired Equivalent Privacy) and WPA (Wi-Fi Protected Access) security key or password
      If you do not know this information, speak to the person who configured your home network settings.
    • MAC address
      You may need to enter the Media Access Control address (MAC address) of your PlayStation 3 into your WAP if it is required by your network settings.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
67 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
