Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My lid switch broke , how do I replace ? - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
  • Whirlpool Master
  • 2,605 Answers
Welcome to FixYa.
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...
**If this is something you think is not within' your scope of expertise please call a pro.**
I will try to help in any manner I can of course, let me know. Good luck.
Regards,
Macmarkus :)
Posted on Mar 14, 2011
  • ronbettsjr May 19, 2011
    Thank you for the help. Worked flawlessly. Hardest part was getting cover back on fully. Took all of 20mins to put the part on and test. Now on to the dryer that stopped working after my move. Pretty sure it is a fuse after browsing the site. Many thanks. Part was <$10 on Amazon and was original Whirlpool part.
Whirlpool cabrio 2yrs old lid lock broke replaced it now I'm getting a lid light and machine will not start
Every machine operates from a timer switch . The lid lock isnt functioning correctly recheck your work maybe a faulty switch programme
Feb 05, 2015 | Whirlpool Washing Machines
Broken lid switch on washer
you must take the cabinet off by removeing the screws from the consloe and flip it back and remove the 2 clamp,s and remove the cabinet and replace lid switch
May 02, 2010 | Kenmore 24032\24036 Top Load Washer
Washing machine stops mid-cycle, water doesn't drain
Sounds like you have a bad lid switch, or the plastic plunger on the lid that engages the lid switch is broke. if the plunger is broke, it is cheap, and only 2 screws to remove and put new one on. if that is not broke, check the lid switch. This model is a lid switch, and lid lock in one. You can test it before replacing it if you have a meter. you need to hinge the lid up to check and replace the lid switch. use a putty knife, on each side between the top and top of the front panel. slide the putty knife in one side, it will hit a bracket if your in the right spot. press in, and lift on that side of the top. do the same on other side, just don't let go of the first side or it will latch again. then swing the top back, the back side is on hinges. the lid switch is on the right side attached to the top. unplug washer, remove the 2 wires on the switch and check continuity. there should be continuity, or "open" when the lid is closed, and no continuity, or "closed" when you open the lid. if it is "closed" even when lid is closed, replace the lid switch. let me know if you have any further questions, shane.
Sep 12, 2009 | Washing Machines
Maytag washing machine (PAV3240AWW) does not do the spin cicle
this could be a couple different things. if it stops at the spin cycle, and makes no noise at all, you need to check the lid switch. if you open the lid, the lid switch is on the right toward the rear. there is a plunger on the lid that activates the switch when you close the lid. if the switch is bad, or the switch housing is broke, replace the switch. be sure to make sure the plunger on the lid isnt broke, and not going in far enough to activate the lid switch. if this all turns out to be ok, it could be the motor slides or jammed pump bearing. you would no if it is one of these if when it gets to the spin cycle, you hear the motor run and it doesnt spin. the motor pivits on slides to one spot to aggitate, and to another spot to spin. sometimes these slides get dry and you just grease the slides and the motor plate so the motor can pivit again. if it is the pump bearing, you will hear the motor and smell "burning rubber". if this is the case, replace the pump. let me know if you have any questions, good luck. shane
Sep 01, 2009 | Washing Machines
Kenmore Elite Oasis 27062, the lid lock broke
Simply attach both wires from the switch to jumper.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
''lid closed switch needs to be reset?''
In all likelyhodd the housing of the switch assembly is plastic. It's secured to the cabinet top by two screw, and the mounting holes on the switch are probably broke. The "lid switch" would have to be replaced. No further information can be offered without a product model number.
Be sure to unplug the unit prior to making any repair.
Apr 27, 2009 | Washing Machines
Kenmore lid switch broke inside washer?
Bought a new lid switch and replaced it.
Apr 08, 2009 | Tecnik TKL9260 Front Load Washer
How do I replace the lid switch on my waher it's a Roper
buy a replacement switch and the top lifts off from the front.  It could be the switch has only come loose or the probe on the lid has broken off.
Feb 27, 2009 | Roper RAX4233PQ Top Load Washer
Lid Switch broke.
you can jump the lid switch. to remove cabinet remove two screws out of back flip up controls remove lid switch connection.unplug jump red to white . green is ground it will work now
Jul 29, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
628 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
