Question about Toshiba SDV393 DVD Player/VCR
Toshiba SD330E Turned it on one day to find no power light or other lights. Has it just died. Its only a few years old. Is there a fuse I can change (other than the plug - I have tried several different power cables which I know work).
  • maxypaxy Oct 07, 2008
    I had the same problem with a SDV393. I called tech support and they told me to unplug is for 3 minutes and then press the "STOP" button on the front panel for 5 seconds. It worked on the power came back on. Just a suggestion.
I had the same problem with a SDV393. I called tech support and they told me to unplug is for 3 minutes and then press the "STOP" button on the front panel for 5 seconds. It worked. The power and display came back on. Just a suggestion.
Posted on Oct 07, 2008
  • 14 Answers
Take off the back of the tv and look for a glass fuse if the inside of the fuse looks broke replace it by going to radio shack if still no fix get a new tv sincerely john
Posted on Aug 01, 2008
GE JVM1190BY died
The keypad control board may be the problem, or the inverter board if 7 years old or less, cost should be considered.
Apr 29, 2012 | Whirlpool Microwave Ovens
Toshiba projection tv 50 inch
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Right on schedule since your TV is 10 years old)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Jan 07, 2008 | Toshiba 50H72 50" Rear Projection...
Subaru Forester 2001. Parking lights stay on when car is turned off. Lights go off only when fuse removed. Light switch on steering column was changed to no effect. Separately, AC, fan and heater...
I have had the parking lights on my 1998 forester stay on w/ no way to turn off. Used the remote door lock to lock and unlock car and the lights went off?????????? This has happened twice with the same solution
Nov 26, 2010 | Subaru Forester Cars & Trucks
My old laptop toshiba m35x-s161 won't turn on the light on the power botton turns on and it makes some noise but nothing more happens
Sounds like there is a faulty connection between the power switch and the computer. Probably why its making a little noise.
Take in for repair and replace power button.
Jul 24, 2010 | Toshiba Satellite M35X-S161 Notebook
Toshiba Camileo h20 battery problem Toshiba Camileo H20 camcorder bought in July O9 Worked fine on 2 week holiday and have recharged the battery 2 or 3 times since. Latterly battery charge didn't last very...
It's eight years old now, and if as you say it has had intermittent use, then the battery will probably have died unless charged at last once a month.
Mar 27, 2017 | Toshiba Video Cameras
Same Problem - Suddenly Died ~2yrs old, very light use.
Probably a fuse inside the unit. Can be caused by overheating or by door switches not working properly.
Sep 10, 2009 | Panasonic NN-P794SF Microwave Oven
Toshiba A135-S4527 will not boot
Could be power supply (ac block and power cord) is dying or died. Laptops are notorious for this.
Aug 01, 2009 | Computers & Internet
COMPUTER WILL NOT TURN ON
Your problem is one of two things:
  1. Power supply inside the computer has died
  2. The motherboard has bad capacitors.
I would get your local neighborhood geek to have a look, or drop the PC off at the local computer store for diagnosis and repair estimate. If it's only the power supply, those run about $25. If it's the motherboard, those run up to $150, and for a PC that old---I'd replace the entire unit rather that put that kind of repair money into something that actually has reached the end of its useful life.
May 19, 2008 | Dell Dimension 2400 PC Desktop
Blinking led light on Toshiba
wow i must be another one with this toshiba common problem bug. Has anyone even remotely helped on this site?
Feb 27, 2008 | Toshiba TP50F50/51 50" Rear Projection...
Toshiba SDV393 DVD Player/VCR Logo
175 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
