Question about Canon LV-7265 Projector
Hello, Sorry for my bad english but i'm french... I've got a problem with my canon lv 7265 video projector. I changed for twice time the lamp and it doesn't work. 1. I turned off the projector 2. i unplugged the cord 3. i changed the lamp 4. I plugged the cord 5. i turned on the projector 6. Power button and lamp light become red but it's impossible to switch it out of standby, there is no reaction when i push on the power button ( on the projector or on the remote control)... Thanks for your help.
  • sportin33 Mar 14, 2011
    Thanks
    It's Ok with reset procedure.
  • 5,370 Answers
Be sure to replace the lamp when the message [Replace with the new lamp.] appears. If you continue to use the lamp after the lamp has reached the end of its usable life, the lamp bulb may shatter, and pieces of glass may be scattered in the lamp case.--------------- POWER Indicator :------When this indicator is green, the projector is on; when this indicator is orange, it is in standby mode.----------- WARNING Indicator:-------- If this light blinks red rapidly, it indicates that an error has occurred, the lamp cover is not attached properly or the projector has overheated. If this light remains orange, it indicates that you have pressed a cabinet key while the Key lock is enabled. ----------- After your lamp has been operating for 2000*hours (up to 3000* hours in Quiet mode) or longer, the LAMP indicator in the cabinet will blink red and the message "Replace with the new lamp."will appear. Even though the lamp may still be working, replace it at 2000* (up to 3000* hours in Quiet mode) hours to maintain optimal projector performance. After replacing the lamp, be sure to clear the lamp counter. Resets the lamp clock back to zero. Selecting this option displays sub-menu for a confirmation. Select [Yes] and press the OK button. ---------- NOTE: The projector will turn off and go into standby mode after 2100* hours (up to 3100* hours in Quiet mode) of service. If this happens, press the INFO button on the remote control for ten seconds to reset the lamp clock back to zero. Do this only after replacing the lamp. --------------- Over-Temperature Protection:------- If the temperature inside the projector rises too high, the over-temperature protector will automatically turn off the lamp with the WARNING indicator blinking (2-cycle On and Off.) Should this happen, do the following: - Unplug the power cord after the cooling fans stop. - Move the projector to a cooler location if the room where you are presenting is particularly too warm. - Clean the ventilation holes if they are clogged with dust. - Wait about 60 minutes until the inside of the projector becomes cool enough. --------------] Now as you mentioned that you have replaced the lamp, so did you got original lamp or used or second hand lamp.Only original lamp is advisable.If you got lamp from ebay sites ,then most of the cases they provide used lamp,and in some cases they dont work.In that case new lamp is advisable.But if you got new lamp and still the same problem then check the lamp cover.The cover which you open to remove the old lamp.If that lamp cover is not closed properly then this problem occurs.If the cover is checked ok then other possibility is temp ventilations dirty.Clean the ventilations,check the internal fan is it running or not running.If its not running then fan is the problem.Its stuck with dirt or its got faulty. But if fan checked out ok and all dirt and ventilations cleaned and still the same problem then try reset procedure.Its mentioned above( press the INFO button on the remote control for ten seconds to reset the lamp clock back to zero. Do this only after replacing the lamp.) .Try reset if still the same problem then its faulty circuit board in the projector. ---------- Click this link for user manual:--- http://www.aboutprojectors.com/pdf/canon-lv-7265-manual.pdf --------- This will help.Thanks.Helpmech.
Posted on Mar 14, 2011
Rectification of Power Supply Unit of CANON Projector Model No : LV -S4 Serial No : T701182A
the power supply unit is USD60
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Feb 15, 2014 | Canon LV-LP12 Projector Lamp for LV-S1,...
Power Supply Unit of CANON Projector LV-S4 COST PRICE
power supply foe lv s4
usd60
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Feb 15, 2014 | Canon LV-LP23 Projector Lamp for LV-S4
CANON PROJECTOR LV-S4 POWER SUPPLY UNIT
power supply for S4 ,Unit price is USD65
have a nice day!
skype:lampdeng
Canon lv- x5
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
Lampdeng Limited
Jerry
Jan 15, 2014 | Canon LV-LP12 Projector Lamp for LV-S1,...
I have a problem with my Canon LV-7265 Projector. When I turn it on, a message appear "please clean the filter" with a blue windows! Please help me how to fix this problem. I try to clean 2...
You need to go into the settings menu and find the lamp reset and filter reset area, sometimes when you get to the reset part you hold down enter then an additional box may show reset/OK, select OK which should reset the filter hours. Most projectors have the filter reset but sometimes resetting can be difficult to work out. I had an old NEC where you had to hold down the on button of the remote for ten seconds to reset.
Hopefully this helps. There may be support from the manufacturers website plus downloadable user instructions.
Good luck
Aug 04, 2011 | Canon LV-7265 Projector
Canon LV-S2 projector not work with component signal input
Try unplugging the projector. This seemingly works but I can't figure out WHY....
Mar 18, 2009 | Canon LV-S2 Multimedia Projector
Canon lv-s1
Update the problem in details. And you can get the same in canon authorized service center.
Regards,
prakasam
Apr 21, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Lv-s1 canon projector
Hi there
Open up the unit and replace the fuse on the Powersupply ( where the AC inlet sits )
If this doesn't do the trick you will have to replace the Powersupply itself.
But most of the time it is only the fuse that has gone.
Apr 14, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Cannot reset projector after new lamp installed
hi
Have you reset the lamp timer after replacing the lamp, if not then do so and see the user manual for that.
Viren
Jan 24, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Canon LV-7265 Projector Logo
295 people viewed this question
old marine
old marine
