Question about Crosley CR78CD-P CD Shelf System
How do I play a record on my Crosley CR 78CD?
2 Suggested Answers
djnick989
  • 1067 Answers
SOURCE: crosley songwriter cd recording problem
maby the formatt its wrinting on is ther any options in menu of it to set the output formatt to mp3
Posted on Jan 22, 2008
Is there a way to install a aux input on a crosley cr-9 juke box radio? Thanks
You would have to break into the cassette player's audio output section. By finding where the audio joins the main amp of the unit. You couldn't do it via the record input section as that uses a different pre-amp which would not be compatible with CD. Once you find the point where the cassette audio joins the pre-amp section of the main amp, you should be able to take a link, from a pair of phono sockets that you will have to mount somewhere on the unit. If you don't use the cassette anymore than you can disconnect it. If you do want to use the cassette then the best bet is to also install a switch that will switch between the two. You will not be able to have both cassette and CD wires linked to the same pre-amp input. As one will vastly reduce the volume of the other. Which is why you would have to install a switch between the two.
May 02, 2017 | Crosley Audio Players & Recorders
Crosley model cr 78cd dead
Contact customer care :
customer service is 1-866-CROSLEY,
prinquiries@crosleybrands.com.
Dec 09, 2016 | Crosley Audio Players & Recorders
Crosley cr 54 cd records sound bad
It could be that the needle is worn. Also make sure that dust and dirt have not accumulated on the needle. It could be a bad ground. You didn't really describe what "sound awful" means. The phono section of the amplifier is much more sensitive than the amplifier section for the CD or radio because it is using much less input signal.
Mar 10, 2015 | Crosley Audio Players & Recorders
Cord for record player
Try the Crosley website they should be able to put you in touch with spare part dealers in your area.
Jul 05, 2013 | Audio Players & Recorders
My CD's will no play at all. Radio is playing o.k.
CR number is on bottom of unit.
We cleaned our CD player to improve sound quality.
Some older CD media would not play.
Nov 11, 2011 | Crosley CR248 Turntable
CD's won't play. The counter stays at "00" & the LED light above the play buuton stays off.
I never have trouble playing CDs on a similar Crosley system, but you might want to first try playing a disc that you purchased at a store. It may be possible that your system cannot play some formats of burned discs.
Apr 12, 2011 | Crosley CR-74 Shelf System
Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Jan 04, 2009 | Crosley CR249TA Turntable
Crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
Dec 12, 2008 | Crosley Conductor CR73 Turntable
Crosley CR78CD-P CD Shelf System Logo
83 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
