Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
I am having motorola handsfree s9 and it's not working properly once i decrease the volume it's not increase again i think baton not working what should i do?
  • 4 Answers
Is it still possible to return it? This is traditionally not a fixable issue. it would cost as much to fix as to purchase a new one. Sorry
Posted on Mar 15, 2011
DNX7120 issue with VOL increase button. When this button is pressed once, the volume skyrockets to max, VOL decrease button does not work right away to lower the volume, nor does the ATT button. Unit...
I had the same issue. You can use the on screen volume buttons on screen to stop issue and don't use the physical buttons anymore. Watch out about a month after the volume problem started all physical buttons on my DXN7120 stopped working. There are a few reports of this online, I have not found a fix yet.
Dec 15, 2010 | Kenwood DNX7120 Car GPS Receiver
I have a motorola razr v3 that i hear fine out of but others cant hear me
You will have to get your cellphone repaired that is the only solution to fix this problem.IF it is under warranty then please get it replaced.
You can try taking the phone apart if you want and clean and reattached the connections to the speaker in the phone.
Good luck,
Please don't forget to rate the solution.
Mar 30, 2008 | Motorola Mobility RAZR V3
Volume button up does'nt work
maybe it is at full volume allready try increasing the volume you phone
Dec 02, 2009 | Motorola Mobility S9 Headphones
My volume is too low and the volume control
increase the volume on your phone or computer
Oct 22, 2009 | Motorola Mobility S9 Headphones
S9 malfunctioning
does the other buttons work play pause
if not then your phone most likely does not have
Audio Video Remote Control bluetooth Profile (AVRCP)
Aug 12, 2009 | Motorola Mobility S9 Headphones
Volume = either completely off or on quietly
HI,
You might have to install the fn keys drivers once again.
Aug 11, 2009 | ASUS Computers & Internet
How do I connect my motorola bluetooh headset S9 to my LG Vu920?
When using your S9 for the first time, follow these
steps to pair (connect) to your Phone:
Important: If you are pairing separate Bluetooth
devices for handsfree calls and streaming music, it is
recommended that you pair your S9 with your
handsfree device (phone) first.
1 Ensure the Bluetooth feature is enabled (turned
on) in your phone.
2 Turn on your S9 by pressing and holding (|) button
until the indicator light flashes three times in
blue.
After a few moments, the indicator light will be
steadily lit in blue to indicate your S9 is in pairing
mode.
3 From your device, perform a Bluetooth device
discovery/search. .
When pairing your S9, use
the following steps to perform a device discovery
from your phone:
After accessing the Settings Menu, go to bluetooth.
to add a new device, tap [New].
1. Tap [New] key to search the device that can be connected and which is
within range.
The phone lists Bluetooth devices it
finds.
b Select Motorola S9.
c Select OK or Yes to pair your S9 with
your phone.
d Enter the passkey: 0000
e Select OK.
When your S9 successfully pairs and connects to
your device, the indicator light displays blue with
10 quick purple flashes. If wearing your S9, you
will also hear an audio tone indicating successful
pairing and connection to your device.
4 To verify your S9 has successfully established a
handsfree calling connection with your phone,
dial a phone number you want to call and press
the Send key on your phone.
When successfully connected, you hear ringing
on your S9. A Bluetooth Handsfree Phone (HFP)
connection is now established with your phone
Jul 13, 2009 | LG Vu CU920 Cellular Phone
Motorola motorokr doesn't work
The mic stopped working on my S9 after 2 weeks and removing the BT device and repairing did the trick...try removing the S9 bluetooth device from phone, then re-adding and pairing again. this worked for me (I have an LG Voyager that I use with the Motorola S9). .
Mar 27, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Cannot increase volume on my Motorola S 9 stereo headset.
The problem is that the unit is not immune to sweat as Motorola claims it is. Mine did the same thing with trying to lower the volume. You might try to dry it out good with a hair dryer (but don't get it too hot). That might help for a while, but eventually it will short out again and you won't be able to fix it. Sony just came out with a unit that is similar and I am going to dump the Motorola for the Sony to see if it works better.
Nov 25, 2008 | Motorola Mobility MOTOROKR S9 + Bluetooth...
Cant hear an incoming caller talk
Press the navigation key: right arrow to increase volume, left to decrease volume. Maximum volume is 7.
Dec 11, 2006 | Motorola Mobility Earwrap Handsfree For...
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
