Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Hayward spa heater about 5 years old, when we turned it on for the first time in probably a year as soon as the water heater came on it started making a loud clanging sound
    President:
  • Hayward Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
For starters you will need to proceed carefully...the noise you hear is water beginning to boil within the heat exchanger. The pressure that results can cause the unit to rupture or worse, blow. DO NOT ALLOW THE HEATER TO OPERATE IN THIS CONDITION FOR MORE THAN A MOMENT OR TWO as you attempt to repair it.
Water boils in a heater due to low flow, allowing the water to get too hot as it passes thru, or a faulty part or parts within the unit. We'll start with parts:
The bypass valve inside the header may be the issue if it is stuck closed. You will also want to inspect the thermostatic control valve in the header (if one is present) and inspect the overall condition of the heat exchanger. It is likely aggressive water has damaged some or all of these parts causing the banging noise you hear.
If the heater checks out then flow is the likely cause. It is possible there is an issue with the pump and/or filter not getting enough flow thru the heater. Check the overall system flow. If it is reduced too low the water inside the heater gets too hot and begins to boil causing the noise you here. Speeding the flow back up will eliminate the issue. Check all the trap baskets and the filter for debris and clean up what you find; backwash a sand filter or clean a cartridge or DE unit. If your pressure gauge is broke replace it and check system pressure. If it is low again that is a sign of a flow problem. If flow is low and all these items check out open up the pump and inspect the impeller for clogged vanes or a blocked inlet eye.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
Posted on Mar 14, 2011
I have Hayward H400IDL2 heater 6 years old. I recently had #1 and #2 1.5 amp fuses blow. I replaced them and then the #4 2.5 amp blew so I replaced it. When I press the mode button to spa the heater
Hi, this is John the Hayward tech. If you are now seeing the #4 fuse go that is on the low voltage side. I would guess the main circuit board. I left a manual on your other post.
Aug 24, 2014 | Hayward Pool & Spa
Hi I hay a Hayward H400 pool heater. It is 2
This is a water flow problem and will be the by-pass assembly in the water manifold. Or their may be an external by-pass wich will be a valve bridging the inlet and outlet pipes for the water. This valve if you have it should be 80-90% closed to force water through heater. Before you do anything be sure to check to be sure the filter and baskets are clean. Often this is the problem.
Apr 25, 2010 | Pool & Spa
I have a Hayward pool heater. It's about 5 years
would not suggest trying to manually light,its an electronic ign model so you may damage some wires with an open flame.try powering off then turning back on and see if display retuns to normal
Jun 19, 2009 | Hayward H Series Pool & Spa Heater 400k...
Have pilot light lit but unit willnot come on hayward h350 heater
check millivolt output,if it is in normal range(400-600)check for continuity on pressure switch,flame rollout and high limits.
Jun 06, 2009 | Hayward H Series Pool & Spa Heater...
Hayward 150 Pool Heater- cannot get lit
Your pilot head is probably clogged with spiders. Disassemble and clean it out and it should start working.
Jun 03, 2009 | Hayward 150k Lp H Series Spa & Pool Heater...
1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
May 27, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
164 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
