Question about Samsung CLX-3160 All-In-One Laser Printer
When I try to scan my computer does not see the scanner but I have no roblem rinting
    Scholar:
  • 45 Answers
This is a common problem with all-in-one printer/scanner combos. Printer drivers and Scanner drivers are installed seperately unless the driver cd is REALLY high-speed (i've never seen it work once). What you'll need to do is open your control panel, go to "scanners and cameras" and click "add an imaging device" (on the left side of the window). It'll start a wizard to walk you through the steps of installing the scanner. Make sure the scanner is connected and turned on, and that you have your driver cd/installation disc loaded. If you dont have the disc, then you'll need to have the drivers in a folder somewhere on your pc, and you'll have to manually point the wizard to that folder. This should square you away. Good Luck
Posted on Mar 14, 2011
I have installed HP PHoto and Imaging Softward for ScanJet 3570c 48 bit. Everytime I try to click on icons on the scanner, my computer shows an error message that there is a problem with connecting to the...
Does the same error occur if you launch a scan from the computer? What OS do you have? Vista only has a basic driver available and does not support the scanner buttons. (You can launch the scans from a number of options: third-party software, Windows Fax and Scan (new scan), Microsoft Paint (File > Import from Scanner or Camera > New Scan) and Windows Photo Gallery.)
If the error occurs when you launch the scan from the computer, try a new data cable and different USB ports. Try a direct USB connection if you use a hub. Then check your USB ports and the drivers for the USB. (For Windows, look in the Device Manager. Start > Control Panel > System > Device Manager (exact directions will depend on the OS).
The HP Photo and Imaging software requires you to set the default scan destinations in the software before you can use the buttons on the scanner (for those OS/driver versions that support the feature). Always open the software and scan from the computer to see what the defaults will be. Each version of HP's imaging software set up these buttons differently; the help option is useful. Try Scan > Scan settings to find where to set the color and black & white destinations.
I hope this helps. If you add a comment with your OS and whether the computer can launch a scan, I'll provide additional help if I can.
(who inherited a scanner when a USB hub failure aggravated the original user into buying a new scanner thinking it was a scanner problem.)
Aug 12, 2011 | HP ScanJet 3570C Flatbed Scanner
My scanner doesn't work...when i press scan button it says preparing for the scan and than it says scan problem!!!!
Disconnect the Scanner or Printer from the Computer .Then uninstall the printer or scanner software.Restart, your computer,then re-install your software restart your Computer try scanning
Oct 04, 2010 | HP Office Equipment & Supplies
Won't scan photo to computer.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | HP Photosmart C4280 Aio Printer
Hp f340 will not scan
Aug 18, 2009 | HP Deskjet F340 All-In-One InkJet Printer
Error messages appear when scanning from glass to macbook.
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Faxing using Lexmark 1290
quero um dowlod pra instalar no meu computador...
Sep 21, 2008 | Lexmark X1290 All-In-One InkJet Printer
SCAN STOPS MIDWAY
Are you getting an error/ red light on the scanner button when its on? when scanning from Paint ( File, then from scanners and cameras) does it freeze as well? or only when using epson scan? make sure cable is directly connected from the scanner to your computer, no hubs or anything.. keep me posted.
Have a nice day!!
Jun 12, 2008 | Epson Perfection 4990 Flatbed Scanner
No Show!
Two things you can easily check:
Ensure the issue is not caused by Electro Magnetic Interference (EMI) EMI can cause similar image quality issues. Verify that the scanner is not in the direct vicinity of the computer monitor and/or speakers. If so, relocate the scanner at least three feet away from the monitor and/or speakers and retry the scan.
Also, try this as well:
Re-home the scanning carriage The scanning carriage in the scanner may have lost the home position and needs to be reset.
  1. Shut the computer system off and then disconnect the scanner from the power source. Leave the scanner disconnected from the power source for at least one full minute.
  2. Reconnect the power and then restart the computer system.
  3. When the computer system has fully restarted, try scanning again.
Oh.. and you ARE using the power supply that came w/ the scanner aren't you?? If not, you NEED to.
Maggie B
Feb 21, 2008 | HP Scanjet 4570cxi Flatbed Scanner
Samsung CLX-3160 All-In-One Laser Printer Logo
154 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
