Ive got a freesat dish and reciever but we get 90% signal but no quality any suggestions
  • 102 Answers
Your on the wrong satellite, If your on any satellite youll get a high Signal but you wont get a high quality until your on the specific satellite. Astra 2A is for freesat. If you can bring that up on the menu then just keep moving the dish until the quality goes above 50% and that will suffice for a decent picture.
Posted on Mar 14, 2011
Can i connect the tv to a sattelite dish to recieve freeview
No you need to connect a terrestrial aerial to get freeview
To get freesat you connect a sat dish and lnb
Nov 29, 2015 | Televison & Video
Humax Freesat was working fine then lost signal and now is not reognising postcode. We have unplugged/repluged, checked all cables (all OK) and tried to restart but as it is now not recognising postcode...
This can happen if the dish is slightly misaligned. I believe the postcode tables are read from a satellite which is about 0.3 degrees away from the Astra satellites. If your dish is slightly misaligned it may not be able to receive it correctly, also the following is the standard procedure which you've probably already been through, but I hope it helps:
1. Freesat Detection Fails / Invalid Postcode
  • Unplug the Foxsat-HDR from the mains and unplug the cable from your dish which is connected to the LNB IN
    connection.
  • Check that the "F-type" connector is firmly on the end of the cable.
  • Power on the and follow the Installation Wizard again.
2. If still not Detecting the signal or verifying postcode
  • Select NEXT through the Installation Wizard and then FINISH at the end.
  • Press the OK button to enter the SETUP menu and Select Manual Tune.
  • Select the following Transponder (11428 H 27500 A) from the list of Transponders.
  • Check that you are receiving stable levels for both Signal Strength & Signal Quality or >50%.
  • If you are not receiving sufficient Signal on this Transponder then you may require an installer to check your
    Dish Alignment, LNB, cabling, or connectors.
Nov 16, 2017 | Humax FOXAT HDR DTV Receiver
Will my westinghouse tv work in the uk in conjuction with a bush hd freesat box?
Both the tv and the Bush HD freesat box was bought in the Euoupean union?Wright?Yes,it will work together with no problems,both the tv and Bush HD freesat box both are recieving the same tv incomming broadcasting signal in PAL signal frequencies will be compatible.
Oct 27, 2011 | Westinghouse TX-47F430S 47 in. LCD TV
How do I update my humax box?
Hello
You have to getin to this site for a software update to your Humax Foxsat.
(http://www.humaxdigital.com/freesat)
From ite main Menu, come to "Edit Channels" window and select the third option 'Software Update" and 'OK".
# When there is no new software to update, a popup will appear
# Software updates for products will be detected using the Automatic Update option
OTA - Over the Air Software Updates will be broadcast via satellite for the product when new updates are
available. Humax reserves the right for deciding when the software updates will be released.
Follow below to ensure that you receive the OTA Software Updates when they are released:
1* You are connected to a suitable satellite dish and are receiving the all of the freesat service.
2* The signal strength and quality are at a high level; if you are experiencing problems with the signal
then please do not continue with the download.
3* The product is in Standby mode each night allowing it to detect, download, and install the updates
when broadcast
Caution:
* Please do not unplug the product from the mains during the software update procedure; this can
cause the product not to operate.
* Please do not remove the antenna cable from the dish from the product during the update as this can
Note:
* For information on the release of new software or the changes made please visit www.humaxdigital.
com/freesat.
* The download can take between 5 - 10 minutes to complete.
* During the update process you will not be able to use the product.
* During the software update scheduled recordings will not take place.
* You cannot schedule programmes during software update
OK.
Sep 18, 2011 | Humax FOXAT HDR DTV Receiver
How do you tune in tv channels when you only have a signal input from a satelite dish and no sky decoder. TV is a sharp lc-32l400x with built in freeview. Can we plug dish straight into TV aerial port...
You require a satelite decoder/receiver for your dish and an aerial for your TV.
The choice is yours. Plug a satelite receiver, for freesat, into the A/V input on the TV or have an aerial installed for freeview.
Jan 19, 2011 | Televison & Video
I have a sharp aquos 32DH500E TV and have difficulties with receiving all the freeview DTV channels. I've used the auto tune function and get most freeview channels but not ITV, C4, C5 and the signal on...
Your lack of channels is from a specific group and is usually caused by poor signal from your aerial. A new larger aerial may solve that.
Freesat is OK if you have a dish installed.
Jun 03, 2017 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
Dec 29, 2010 | Samsung Televison & Video
Trying to install an English freesat box in Spain is this possible as the the signal says no signal strength on the screen whats the answer anybody help us The model number is DTR2520 it is a brand new...
is a dish position , not in position, need a special signal meter, to tune the right signal, and normaly must replace the dish head, old models has low digital output signal. you need a specialist to tune the dish position and get the proper compatible dish head. for your receiver.
Feb 16, 2010 | Audio Players & Recorders
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
