Question about Yard Machines Cultivator
I have a 31cc yard-man culltivator. I have a carburetor problem. The engine will only run if I manually choke the carb with my finger over the air intake. Other wise the engine is not getting gas.
  • tedyellen Mar 14, 2011
    That sounds like very good advice. Hopefully I can get back to working on it tomorow and let you know if your solution solved the problem. In the mean time, thanks for your quick reponse. Ted
  • 2,510 Answers
The jets and/or passages are blocked and you are forcing extra fuel in to keep the engine running by choking it. Strip the carb and clean out the jets and valves and the needle valve and seat. Blow out all the passages if you can, but be careful of losing little screens etc. that may be in the passages. Do not use wire or hard object to clean jets, use a tooth pick etc. so as not to damage or enlarge the orifices.
Posted on Mar 14, 2011
  • Hans Pearson
    Hans Pearson Mar 14, 2011
    I look forward to hearing from you - Hans.
Motor will start but I have to manually hold the choke open until it warms up otherwise choke closes on its own
Yes this is the semi automated startup process. If the fuel is bad(old) or the carburetor has residue restricting the fuel passages the engine will run lean requiring some enrichment.(choke) I suspect that the engine may be hunting when warm. Use carburetor cleaner along with a fuel stabilizer.
Check/replace the fuel filter.
Empty fuel tank and purchase some no ethanol from home supply running the engine will assist in cleaning the passages. When engine is running close the choke a fuel times to give the engine a poor mans clean out, Avoid disassemble of the carb with out having technical compliance.(these are delicate and susceptible to contamination).
Never leave fuel in the engine when in storage. Ethanol gums up the fuel passages.
Hope this helps?
Mar 11, 2016 | Husqvarna HD800HW 160cc Gas 22-in 3-in-1...
Engine won't run with choke off
Sounds like a dirty carburetor. By choking the unit you are manually changing the air fuel mixture by choking off air. You need to remove and clean carb. If you not confident, bring it to a reputable shop. Hope this helpd.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 05, 2013 | Briggs & Stratton Garden
How do you adjust the choke on a 1996 mtd lawn tractor
shouldn't need the choke on after running you must have plugged jets inside the carb
Aug 26, 2012 | Mtd Products Yard Machines 158CC Tiller
I have a 4.5 yardman lawnmower and i cant get it started what can i do to fix this?
Check for clean air filter, good strong spark and good fuel flow to the engine. The only other thing that could be out of whack and prevent starting is the "air-gap" between the ignition coil and the flywheel. To try and coax the engine into starting, remove the air filter and shoot a good shot of carb/choke spray into the carb throat with the choke off. Then immediately try to start the engine normally (with it choked). We are trying to get it to run so it will start drawing fuel normally from the carburetor. A clogged carb main jet can cause your problem too. It is the brass bolt that holds the float bowl onto the carburetor body. Remove it, inspect it and clean it. Use no metal objects on it as the small orifices that meter fuel thru it have to stay that way. Look for clogged holes in the unthreaded section of the bolt near the top. Clean it till shiny and reinstall. Try the carb/choke cleaner a few times and post back if needed. We are here to help.
May 22, 2011 | Yard Man Garden
Yard man won't accerate
When ever this happens to a two cycle engine you can bet the main jet in the carburetor is stopped up. Take it apart and run a very small wire through every passage in that carburetor. Now blow compressed air through each passage and reinstall.
Aug 23, 2009 | Garden
Ryobi 31cc , 17inch weed ,hard to start ,needs to stay choked to
I got on here to find the solution for the same problem. This seems to be fairly common. I need to have it at 3/4 choke to run properly. Other posts say the exact same thing, about the 3/4 choke. It is apparenly something that breaks occationally.
I'm going to remove the carb and take it apart. My suspection is the diaphram in the bottom of the carb. There isn't much you can do with the carb, it is very simple and has few parts.
There is a chance that it is a blocked passageway also.
There are instructions for adjusting the mixture, but they are not clear enough. I will be posting a clarification reqest on one of those posts. Will also post again after I check the diaphram.
Jul 11, 2009 | Ryobi Three Trimmer Combo
Engine revs up and down on MTD 13.5 HP Yard Man lawn
Hello ctacket You may have 1 of 2 problems. First the carb. may just be dirty. It should have a 1/2 inch bolt directly in the bottom of the Carb. bowl. turn off the fuel pecock. Remove this bolt and carefuly remove the bowl. It has a rubber gasket at the top becareful not to damage that. ck for dirt or gummy old fuel and clean with spray can brake cleaner. 2nd problem may be a bit harder to find and fix. it sounds a little like a speed governor spring may be missing, out of adjustment or has gotten very weak with age. This is located on top of the carb. and hooks to another rod on the engine. as engine load increses the engine slows down (cutting into thick grass, no matter what speed you have set the engine at will slow down the engine down, then this gov. moves the speed rod on the carb to increse engine speed to over come the load) I hope I this makes sense. Ck for dirty carb bowl first, then dig into the gov and spring. I will try and help you out if you need more.
Jul 01, 2009 | Mtd Garden
Machine will not start
Hi, This problem is common if you have not used the engine for some time or you ran out of gas while the engine was running. Should you like to venture this a try, you have to remove the air cleaner cover & remove the air filter element and temporarily replace it with a clean rug big enough to cover the entire air box. It should cover fully and snuggly the air intake of the carburetor. With the engine off and sparkplug remove, crank the engine several times. The idea is to manually choke the carbs (partial/controlled flooding), prime the carbs (if your engine is using a vacuum controlled fuel/pet cock/valve which of course must be turned on it it was manual). To verify that fuel is getting inside the combustion chamber, you have to stick your index finger to cover the sparkplug hole while cranking. This will cause popping out (because of compression) of your finger. Presence of fuel in your finger would be a good sign. Let it rest for a while then remove the rug, reinstall the air filter + cover & plug. Start your engine. As a safety precaution, when working, no open flames, make sure engine is off when doing the finger test. Based on your post "sparks coming from the plug" I will assume that your mechanically inclined since you were able to perform this test and therefore familiar with the use of tools and safe practice. Good luck and pls post again how things turn up. Kind regards.
Aug 11, 2007 | Karcher 2500 PSI Pressure Washer
Yard Machines Cultivator Logo
763 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
