Question about Ricoh IS300e Flatbed Scanner
Error when trying to network scan: 12320: Cannot find the scanner, check if the scanner main power is on. image scanner is300e
3 Suggested Answers
  • 319 Answers
SOURCE: getting error code Code[ffff:0024]while scanning
I would try uninstalling the driver and reinstalling it. Could be because the computer is not reading the scanner.
Posted on Dec 31, 2007
SOURCE: Richo 1515 MF Error message: 12320 couldn't find the scanner.
The scanner had been previously configured and did work on another PC that crashed. We used adobe 5.0 to import. (obv this was awhile ago) I remember having this problem then but I don't remember how we fixed it.
It's a MF and the PC can print to it, but I can't get the scanner to communicate.
Any help appreciated.
Posted on Feb 27, 2009
Black copy problem
Subject: Full page solid image or error code C3200
Model: FS-6025MFP
Phenomenon: A full page solid image may appear on the print-out or error code C3200 (Exposure lamp
error) may occur.
Cause: The digital transistor in the CCD power supply circuit at the main board may be damaged,
resulting in the CCD failure.
Field measure: When the above mentioned phenomena occur, please replace the Main board with the latest type
(Parts PWB main assy).
Nov 02, 2014 | Kyocera FS-6025MFP Laser Multifunction...
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
AR-M237 PRINTS BUT DOES NOT SCAN
You may have a problem with the physical board connected to the machine, try re seating the card with the machine off and unplugged. Its a data issue over the network, it may be the board itself. Try re seating it first.
Mar 23, 2010 | Sharp AR-M237 Copier
Code error ffff:0024
While I am trying to scan the images, I am getting the error Code[ffff:0024] & I am unable to scan anything from Epson 1500 model. While I switch on the scanner, it sounds lot from the scanner for continuous 2 minutes. I couldn't get scanned anything ... please
give me the solution.
Mar 30, 2009 | Acer Scan to Web 3300U Flatbed Scanner
This is a message on your PC...not the machine itself obviously? Was this scanner ever configured to work on your PC? If not, then follow this link to my comments to someone else about this machine:
http://www.fixya.com/support/t1718617-ricoh_1515mf_scanning
Feb 27, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
ERROR CODE C0660
This is a scanner problem, try the following...
C0650, C0660
Step Check Item Result Action
1 Scanner can be moved manually.
NO Correct drive coupling (Scanner
Belt tension, pulley operation,
drive cable tension)
2 Scan motion: initial scan motion after the
Power Switch has been turned ON or Front
Door has been opened and closed.
NO Carry out misfeed/malfunction
troubleshooting procedures.
3 Connectors are connected properly on
Scanner Motor Drive Board: PWB-IC
PJ1IC, PJ2IC, and PJ3IC.
NO Check connectors for connection.
4 Scanner Motor turns when the Start key is
pressed.
Change motor. Change
Scanner Motor Drive Board.
5 I/O check for Scanner Home Sensor: the
voltage across PJ6C-2 on Image Processing
Board and GND is DC 0 V (home position)
when the sensor is blocked and DC 5
V when the sensor is unblocked.
YES Change Image Processing
Board.
NO Check sensor for installation.
Correct detecting plate.
Check sensor connector for
connection. Change sensor.
6 “IR Area” check:
Malfunction when Power Switch is turned
ON after “Top Image” has been set to 0 and
“FD-Mag.” to 1.000.
Apr 03, 2008 | Minolta CF2001 Copier
"Scan Request Failed"
Problem: Lexmark cannot retrieve applications list
I have the Lexmark X3550 with the WiFi option board installed (makes it same as the model X4550) and get the “cannot retrieve applications list” message on one of the five computers connected to my router (Linksys WRT54G V8) and using wireless printing and scanning. Just like everyone else with a similar Lexmark WiFi printer/scanner, I can print wireless, but cannot get the wireless scanner to work on one of my PCs.
The fix, in my case, was to change the Lexmark network name in their Imaging Studio application. This worked for several weeks, but now I get the “cannot retrieve applications list” message again. I have not fixed the new error yet, but changing the network name may work for you. Here are the steps to change the Imaging Studio network name.
1. Launch Lexmark Imaging Studio. (Double left-click on its icon)
2. Left-Click on “View or change network settings”.
3. Enter a new network name in the first box shown. (This box contained the correct network name for my PC, but another name was needed to make the scanner work. I simply added “-lex” at the end of the current network name.)
4. Left-Click OK. You should return to the Imaging Studio screen.
5. Close the Lexmark Imaging Studio window. (The tray icon should remain at the screen lower right.)
6. On the printer, press the Scan Mode button.
7. On the printer’s display screen, select the Computer Name that you entered for the new network name. Just use the arrow buttons until the exact name is shown.
8. Press the Check button. The display screen should show “Downloading Applications List”. Within about 10 seconds the message should change to “ *Scan to Computer ”. Wireless scanning should now work.
9.. Press the Start Color or Start Black button. “Requesting Scan” will be shown. After a few seconds scanning will start. The process is a bit slow.
10. After a while you may see an empty small Lexmark window onscreen. Later, the Lexmark Imaging Studio will appear onscreen, then change to show many options and features. An image of the scanned item will appear in a Lexmark window. Save and/or edit the image. Another scan can be done by pressing the printer’s Check button again. Be sure the correct computer name is shown on the printer’s display.
That’s it. A new computer name was the solution. Your PC and printer may require a restart (power off) after changing the “computer name”.
Regards,
Fbyrd99
Oct 23, 2007 | Lexmark X3550 All-In-One Printer
Getting error code Code[ffff:0024]while scanning
while i am trying to scan the images .. i am getting the error code like Code[ffff:0024] while warming up the scanner, besides a sound from the scanner making it power off (light inside the scanner goes off ) so that i could not get scanned anything ... what will be the reason ? please suggest me the trouble shoot kaarthik
Apr 14, 2007 | Acer Scan to Web 3300U Flatbed Scanner
Ricoh IS300e Flatbed Scanner Logo
165 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
