Hi, I have a virus that I cant seem to get rid of. I have tried many things but at this point I'd like to just wipe the hard drive and re install. Can you help me out on this?
if its inspiron 8100 you wont have theoption of ctrl f11 as its older than 2005 when quick restore was added to dells. you will need the xp cd dell can ship it for under 11$ also download audio video network drivers for that model then burn them to cd .
However im able to remove almost all viruses with ubcd4win.com boot cd ( even with remote support= tech can do it remotely)
hellow,
get unplug your hard disk get usb to ide or usb to sata cable attach it to another antivirus protected system and scan it. all virus will be fix after scan. replug it to your system. if you are using windows xp follow this after scan:
boot it with windows xp bootable cd repair it by the repair option which comes after press F8.
remmember you must select repair option after F8 thats doesn't lose your data.
cheer.
Was this helpful?
Yes
No
Popular Solutions for Dell for Inspiron 8100 40 GB
WD3200AAJS Caviar SE. Started with not recognizd by WindowsVista. Restarted computer, worked for a...
(More)
WD3200AAJS Caviar SE. Started with not recognizd by WindowsVista. Restarted computer, worked for a while, now when pluged into AC, bluelight on front just pulses. what now? how to make internal? Thanks...Jason
I have a Buffalo 320GB Ministation hard drive. It works fine except when I want to save a file...
(More)
I have a Buffalo 320GB Ministation hard drive. It works fine except when I want to save a file larger than about 4 GB. It then gives me an error that there is not enough room on the disk even though the disk has 150+ GB free space. I suspect this is a format issue. How do I fix this?
mini pal seems to be dead. Power lights up on the face . drive doesn't seem to run up. Had been...
(More)
mini pal seems to be dead. Power lights up on the face . drive doesn't seem to run up. Had been alternately running fast and slowing. Anything I can do mechanically to fix the drive? make it spin the disk again?
Would like to upgrade my memory but I do not have a model number; system was built at gateway. I...
(More)
Would like to upgrade my memory but I do not have a model number; system was built at gateway. I know I have 512 MB of Ram and can upgrade but need to know what to purchase.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
