Question about Kodak ESP 5 Printer
I have an esp5 all in one printer. the print head is filthy and i want to know if there is a solvent or whatever that i can use to clean it.
Josue Pongco
  • 154 Answers
SOURCE: I need to know what printer head I need for an all
The printhead is replaceable, call kodak and i think they will send you the replacement for free. 1800 421 6699
Posted on Oct 02, 2009
  • 295 Answers
SOURCE: I have a kodak esp5 all in one printer and i am
Kindly go to www.kodak.com/go/printheadsupport and see how to install the printhead properly. Make sure that it snaps in to place properly. If issue persists,call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.Printhead is the part which holds the cartridges and has 4000 nozzles which sucks ink from cartridges.It Might have gone bad.
Posted on Oct 20, 2009
CViveiros
  • 55 Answers
SOURCE: My Kodak ESP5 AiO printer has its print head stuck at its right.
Dear Sir/Ma'am,
• To resolve this issue remove the cartridges and then the printhead (Upon removing the cartridges look into the slot where the black cartridge fitted into. On the vertical wall at the back you will see two small contact points. Place your finger above those points on the black plastic and run your finger towards the top of the printhead. You will feel a little button and by pressing it , it will release the printhead.)
• Remove power
• Please now check for any objects or paper that might be obstructing the movement of the printer carriage - if any are found please remove them
• Wait 5-7 minutes
• Reinsert power
• Reinsert printhead (When inserting the Printhead please ensure that you hear it click into place)
• Then re-insert cartridges, black first then colour.Please also ensure that you hear them clip into place
Regards,
CViveiros
Posted on Oct 26, 2009
SOURCE: How do I clean the print head for a kodak printer
This is for Kodak AiO printer that has home center software installed
1.On your computer, start the KODAK AiO Home Center software.
2.Click the Help (?) icon located at the upper-right corner of the Home Center window
3.From the Help toolbar, select Maintenance.
4.Click Printhead Cleaning, and wait for the printer to complete the cleaning.
If there is NO Kodak AiO home Center software installed
1. 5100 printer HOME CENTER should be use or open the printer access door wait for the printhead to move at the middle then close the printer access door forcing the printehead to eject ink on the printhead nozzle
2.5300 & 5500 printer press the MENU button > select CLEAN PRINTHEAD > then select BASIC/DEEP CLEAN
3. ESP3 printer [press and hold at the same time COPY and CANCEL button for atleast 10 sec or until the printer start moving]
Posted on Nov 21, 2009
pineworks
  • 4041 Answers
SOURCE: Kodak esp 5 All in one printer won't print
Hi there
I would try removing you printer driver and close Pc down then restart your PC and reinstall your printer diver again some times works.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Black ink will not print
You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
Jun 18, 2012 | Kodak ESP5 AllInOne InkJet Printer
AFTER CHANGING INK, PTINTER STARTED PRINTING BLANK
Make sure you removed the plastic strip off the printer cartridge that you inserted into the printer. If you did then clean the heads.
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3. Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Mar 31, 2010 | Canon Office Equipment & Supplies
I cant print on my canon s200spx. the printer is working but nothing is printed. whats wrong?
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
Hope this helps. .
Mar 26, 2010 | Canon S200 InkJet Printer
Printer doesn't print
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
Mar 25, 2010 | Canon BJC S450 InkJet Printer
Print Head error
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
Hope this helps. .
Clearing printer
Turn off your computer and completely shut down.
Turn off your printer.
Disconnect all cables and electrical cords from your printer.
Make sure the electrical cord is also removed from the wall.
Wait 5 minutes and reconnect the power cord to the printer.
Then connect the printer cable from the computer to the printer.
Turn on your printer
Now reboot your computer (cold boot)
Your printer should now clear itself.
Mar 22, 2010 | Canon PIXMA MP830 All-In-One InkJet...
My printer was printing just fine and now it is printing out blank pages. I just put in a new ink cartridge before printing and now it won't print at all. The little tear drop shape on the printer is...
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
Hope this helps. .
Feb 07, 2010 | HP LaserJet 5550 Printer
I have black lines printing throughtout my documents. I have a Lexmark 2600 printer
Print head may need to be cleaned.
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
Hope this helps. .
Feb 07, 2010 | Lexmark X2600 InkJet Printer
Black ink will not print properly even after cleaning. Printer keeps telling me there is a programing error and yellow light comes on continuously printer will not print at all
Unplug printer power cord, wait 30 seconds, reconnect.
then
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
Supplies needed:
paper towels
latex gloves
warm water
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
Feb 05, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
I have a Cannon pixma IP30000 printer. Loved it.
Hi, I have pulled many printers apart when they failed printing...
mostly it is a circuit board problem...some have fuses...others don't...even if it has a fuse it will be soldered onto the circuit board...
have you checked that the lead is properly pushed into it's socket...I know this is basically a silly question...but have you checked???
If you are absolutely sure that there is power to the printer, it may mean that it is now dead as a Dodo...even with a lot of problems you should get a power up light...
you may be surprised to know that I have found paperclips do a lot of damage to printers when they fall into the paper feeder slot...as do little creepy things...
hope you get the printer going...
cheers
haitchhcee
Dec 03, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Ip4000r not printing cyan
Supplies needed:
paper towels
latex gloves
warm water
PROCEDURE:
Hope this helps. .
Jul 22, 2007 | Canon PIXMA iP4000R InkJet Printer
Kodak ESP 5 Printer Logo
47 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
