Question about Toshiba (P000204210) Motherboard
Toshiba L200 (A410) Windows Vista Screen starts flickering with horizontal lines of different colors flashing across it when power cord is plugged, though it runs smoothly when using the battery
  • 656 Answers
Please check the yga cable for loose contact or breakage
Posted on Mar 17, 2011
Horizontal lines LED hisense tv
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Hisense Televison & Video
Display flashes horizontal lines
It's not unusual for a monitor to use different circuit paths based on the the display resolution chosen and so, one could have a resolution that is faulty, while another works just fine. Monitors normally just get dim, or power supplies fail, or other more common failures, blank or white dots... etc.; but, should a monitor live long enough without failing in those areas, usually one or more resolutions will fail. Doesn't leave you much of an option, other than a repair shop, if one could be found; but, as long as it works at that or another resolution, and I'd check the other settings and use it if you have something where it can be used. Sorry for the not so good news.
Jul 02, 2017 | AOC I2353PH New
Problem: Intermittent flashing horizontal lines of different colors or freezes up on a black screen after a few minutes on the desktop screen. Have done the following: Re-installed Vista Ultimate, updated...
Could be hardware problem. You might need to try to connect to a different screen which you know is working. If it appear to be normal, it indicate that you need to replace the screen.
May 29, 2011 | Toshiba Satellite P105-S921 Notebook
Nothing but multi colered lines verticly on the screen
Try this:
Turn it off.
Disconnect power cord and any other device attached to it.
Take battery out.
Without anything attached. Hold down the power button for 10-15 seconds.
Connect the power cord only.
Hold down F2 (while it's off)
Turn it on while holding down F2.
Let go of F2 when something comes out of the screen.
If multi colored lines still appears.
You have either defective LCD(screen) or video card.
Jan 30, 2010 | Toshiba Tecra M2 Notebook
Computer crashed and won't boot. restarts before it loads
Firefox is a bad virus program three thing to do
1st safe mode
if not, reboot vista disk.
If can't you need to go to bios to run cd to restart fresh program. but remember if this you loose all media.
Dec 05, 2009 | HP Pavilion DV9500Z Notebook PC
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
There is a component failure on the board inside the display. Since you did not post the model number that is all that I can tell you.
Mar 17, 2017 | LG Studioworks 700B (White) 17 in.CRT...
I had a similar problem on a different monitor and fixed the green sparkles by selecting a lower refresh rate.
Aug 15, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Laptop screen flickers and color is distorted
Sounds like the CCFL is failing.. (Backlight)... Pink hue is common when these start to go out..
Dec 14, 2007 | Computers & Internet
Toshiba (P000204210) Motherboard Logo
200 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
