Question about Proform 755cs Treadmill Motor Control Board 127847
Hi I have a pro form 755 cs and I lost the key to turn it on. what where can I get that part.
4 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: My Pro-form 980 CS will not start. I plug the key
Press the Stop and the Speed Up keys down while inserting the safety key. This should get you into calibration mode. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. If you cannot get into calibration or if the EPROM test fails then the upper console will have to be replaced.
If you get pass to this point then proceed with the calibrating the incline and speed.
Press either incline key and the incline will calibrate automatically.
Be careful the treadmill will run at full speed in the next mode DO NOT STAND ON THE WALKING BELT.Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled
The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
Posted on Jun 12, 2010
rohdd
  • 283 Answers
SOURCE: Pro-form 990 cs won't turn on
Is this a new machine for you? Are you sure the magnetic key is correctly in place.
Also, check to see if there is a red re-set button near where the cord comes into the machine, if so. unplug. press re-set and try again. If this does not work please re-post your question
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is really appreciated for the FREE answering of your question.
Posted on Feb 11, 2011
Pedometer pro form +fat
I've lost the manual on how to use pro form pedometer + fat. Please help
Feb 11, 2013 | Proform Pro-Form - SP-200 Pedometer...
Pro-form 980, regardless what button I hit the speed goes to 12
1) test the speed sensor, for open or faulty, see the adjustment. Clean if and tight the connector very well
2) tight the ribbon cable for keypads , and clean it
3) replace batteries,and clean the contacts baterries very well
4) adjust the Reed swtich, test for open or faulty, clean it and tigh the connector very well see the diagram
5) Run the software calibration for troubleshooting, diagnose, and fix it.
Jan 22, 2013 | Proform 980 CS Treadmill
Will ATI Radeon x1900 run on my Dell Optiplex 755?
Looking at the specifications for the Optiplex 755 line I'm seeing the highest power supply is in the minitower version at 305W. I can't find a document specifying the power requirements for the Radeon x1900, but most benchmark power consumption tests show the system pulls around 280 - 300W with that card installed.
The problem is either your specific Optiplex 755 configuration can't support the power requirements, I don't know if you have the MiniTower, Desktop Tower, Small Form Factor or Ultra Small Form Factor version of the sytem or the card is itself is bad.
Jul 06, 2012 | Dell Optiplex 755 Desktop Intel Celeron...
We are wondering how to lubricate the pro-form 380 E treadmill. Can't seem to find any directions in the User's Manual.
hi,
For lubricating treadmill you can use teflon based silicon lubricant. The followihg video will help you to lubricate your treadmill.
OK
Aug 16, 2011 | Proform 380 CS Treadmill !
Feb 11, 2011 | Proform Exercise & Fitness
Jun 12, 2010 | Proform 980 CS Treadmill
Photoshop CS And Imageready CS Lost 24 number serial Key
this is serial number for adode photoshop cs and image ready
1045-1756-0999-0999-3438-3575
Dec 15, 2008 | Adobe Photoshop 7.0 for PC
Proform 755cs Treadmill Motor Control Board  127847 Logo
23 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
