Question about Xerox Office Equipment & Supplies
We have a xerox 3030 machine with a status code LL.60 and a NVM fault .. What does that mean and
5 Suggested Answers
SOURCE: xerox 5334 fault code U4-1
Reset the fault code first as follow:
Enter in diagnostic mode
Enter 20-3 and press 0 then press start again .
Hope it will solve if not done check the heater lamp continuty if found fault replace same.
Posted on Sep 20, 2008
  • 990 Answers
SOURCE: Xerox WC Pro 423 fault code U4-6 & U4-4
Hello sir; The U-4 code all are fuser problem, there haave noway to fix it the only way is replace the fuser unit
Posted on Aug 23, 2009
  • 53 Answers
SOURCE: xerox 5225 fault code 010-320
that is a fuser overheat code suggest you have a techintion repair or replace the fuser
Posted on Jan 18, 2010
  • 2072 Answers
SOURCE: fault code 006-381 on a xerox workecentre 24
That is a ROS ( laser ) fault.Either the ROS unit or the MCU ( main processor board) have failed.
Honestly, its a tossup as to which is the problem.
Posted on Mar 31, 2010
Sln for Xerox wc 5330 error code 092-315
092-315 ATC Fail RAP
BSD-ON: BSD 9.3 - Development and Toner Dispense Control
The frequency at which the ATC Average Fail or the ATC Amplitude Fail has been occurring
has exceeded the threshold value.
NOTE: •
Although this Fault can be cleared by turning the power OFF and ON and it will be possible to output a few sheets of printouts, when this Fault has occurred a certain number of
times, it will no longer be clearable by turning the power OFF and ON. To clear it, clear the
value of NVM location [752-022] (ATC Average Fail) or NVM location [752-023] (ATC
Amplitude Fail) to "0" (
NVM Read/Write). If the machine is not repaired back to normal
status, this Fault will occur again during the operation.
• When turning the power OFF, turn OFF the power switch first and then the main power
switch.
Procedure
Check the following:
• The connection between the MCU PWB
P/J413 and the Xero/Developer Cartridge P/
J615
for open circuit, short circuit, and poor contact
• The Toner Dispense Motor for revolution failure:
Component Control [093-002] (PL 8.2)
• The Toner Cartridge for internal toner blockage
If no problems are found, replace the following parts in sequence:
• Drum Cartridge (
PL 8.1)
• MCU PWB (
PL 18.2)
See Service Manual page 827 (2-831):
https://docviewer.yandex.ru/?url=ya-disk-public%3A%2F%2FEXv3f5bJ9f7WprcvyqxuiVsXMlmyrp4nx2LzJa50u6s%3D&name=Xerox_WC_5335F_SD.pdf&page=827&c=55716712dd0d
Xerox WorkCentre 5335 Family 5325 5330 5335 Service Manual
Jun 05, 2015 | Xerox WorkCentre 5325 5330 5335 Black...
WHAT IS THE NVM RESET FUSER CODE FOR THE XEROX 7545 COPIER\
Have a look at the following link:
http://www.enxmag.com/2013_months/aug2013/WorkCentre7425StyleFaultCodeList_82013.htm
It has a list of fault codes and also tells you how to reset NVM counts. Look in the bottom right of the page for the instructions. Hope this helps.
Jul 16, 2014 | Xerox Workcentre 7545/P 7545P Color...
Xerox 5225 fault code 010-320???
If you have a Xerox WC5225 with Error Code 010-320, then you have a fuser problem. The fuser is the heated item which bonds the image, just before it exits the unit. The machine monitors the temperature sensors and heating elements on this part.
The fuser is sold as PN 126K24980. It is easy to replace yourself.
Nov 23, 2010 | Xerox DocuColor 3535 Copier
As soon as machine is turned ON error code 124-315 appears. pls help!
Here is a note from a Xerox Tech:
Everything points to NVM coruption so try with reseating the NVM pwb. And then maybe NVM init.
Hope these helps.
Nov 23, 2010 | Xerox DocuColor 12 Printer
Xerox 8830 LL-60 Checksum fault
enter in diag mode and press 03-60 reset the nvm
Nov 01, 2010 | Xerox 8830 Copier
Erorr code 10-327
reset ur fuser module
press 0 and hold for 5 second than press start button
enter passcode 6789 and press confirm
press machine status and press tools on touch screen
press maintenance and diagnostics
nvm read /write
type chainlink 744-220
enter new value 0 and save
after close the log
restart ur machine
Sep 25, 2010 | Xerox CopyCentre C128 Black and White...
Xerox 5855copier showing 03-326
Try cleaning the optics even if they seem to be clean
Apr 08, 2010 | Xerox 5855C Copier
Fault code problem whit xerox 5665
This sounds like a fuser problem, underheat or over heat. On this machine also, it might be related to NVM, or NVM memory corruption. Sometimes the batteries on the Main Board, they just get old and die.
This can be a multiple problem on the machine.
This might require a Xerox service person to visit the machine.
Some ideas are: A bad heat sensor(Thermistor), very fragil and brittle.
A NVM might need to be reset, Over heat or underheat code in the diagnostice service mode. You need a service manual to find it.Very complicated to explain.
A full sump bottle can cause this, the machine enters a code in the NVM and will keep the machine from "Logicly turning on." Or a broken full sump bottle, sensor falls off or not in place will cause the machine to enter a error code in the NVM.
Good luck.
Apr 03, 2009 | Xerox 5665 Copier
NVM settings
In tray one there is a hidden compartment take a flat blade screwdriver to the cover as you are looking directly down at the top of the front of the drawer you should be able to open the top of the compartment. In there is what is called the birtcertificate for the machine and the original NVM settings are in there.
Dec 24, 2008 | Xerox DocuColor 12 Printer
182 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
