Question about Rheem Water Heaters
I have a 50 gal rheem water heater, its making a clicking noise i have discovered if i shut off the cold water supply it stops, when i turn it back on then the clicking starts again, my t&p has popped but right now i have the gas off and its not heating but still clicking. any ideas
  • 3,640 Answers
Sediment build up is usually causes thumping and noises from tank. it needs flushed out. models, where the heat source is beneath the tank. The burner heats the water under the sediment, leading to a build of steam. The steam finally escapes as bubbles, which can cause the sounds.
have a good day !
Posted on Mar 14, 2011
How to flush out the water heater
Connect one end of garden hose to spout located near bottom of water heater. Put other end near drain or run to outside whichever suits your particular situation better. Shut off water valve at top of heater and open spout to drain. You might not have to drain the whole thing if you do this regularly. If it's never been done before you probably should. When water stops draining out shut off spout and open valve at top of tank to fill it back up. Disconnect garden hose. Water will be cold for about an hour before it has a chance to heat back up. Should be done about once a year or so depending on your water unless you have a self cleaning water heater.
Feb 09, 2013 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Where is water shut off valve on Rheem Electric Water Heater?
The shut-off is not on the water heater.
The shut-off is usually located on cold water pipe that enters water heater.
See image of shut-off:
http://waterheatertimer.org/images/Low-water-pressure-2-800.jpg
If shut-off is not located on cold pipe at water heater, then turn off water to house at water meter.
More resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Sep 25, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
New water heater,makeing a whisling noise ?
If you installed flexible lines at the supply connections, try moving supply's in a different position. You should also get a pressure gauge and check the incoming water pressure to the house. If there is a regulator, be sure and check on the regulated side.
Apr 21, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem RHEEM 50 GAL ELEC TALL Water Heater 1.5 yrs old, power at the elements, new elements installed new thermostat installed, still no hot water.
Hello Check the red overtemp reset button at the temp control.Check for contintuity at the elements with a volt meter (pull one wire off first) they should have a reading otherwise they are open & shot.Last is overdrawing (busted pipe) shut off the cold water supply for a 1/2 hour and open it back up and feel the hot water supply pipe.Is it hot?The tank can't keep up with the demand.
Sep 16, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Installed a new 50 gal electric Rheem water heater. Within about an hour the tank began making a strange bell like ringing. When you shut the power off the noise stops. What the heck?
Sounds like pressure building up in your line to much. Did you make sure to get all of the air out of the system by opening up your relief valve?
Jun 03, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
My gas water heater (Rheem) is making noise, like
Stop wondering, replace the thing and your troubles will be over. Your troubles are inside the tank and not worth even giving it another thought. Go for it!
Oct 12, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water leak at top rheem 21v40s-2
you need to replace the water heater, the tank is cracked and under pressure so it is forcing the water to the nearest opening
Jun 03, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Losing hot water in one facet only
There is something in the line or in the faucet.Are your pipes going to the faucet black iron or galvinze.Some of the pipe will rust up and stop a full flow of water.But I would check the faucet first to see if the screw is loose or somethng in it.
Mar 17, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem 50 Gal Hot Water Heater will not stay lit
On the back of the gas valve (where you turn the temp up) there is a stem that actually goes into the tank that senses the temprature of the water it could be dirty or buried in sediment depending on how old the tank is, or just bad. if the tank is over 10 years old i wouldn't bother replacing the gas valve, the tank is probably not far behind. A new valve will run around $100.00 maybe a little less. You wont find it at menards or home depot in stock but they may be able to order it for you. Menards sells rheem products or try you local plumbing supply house. REMEMBER TO RELIEVE THE PRESSURE ON THE TANK BEFORE YOU WORK ON IT. IF YOU CHANGE THE VALVE DRAIN IT FIRST!
Feb 10, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water Heaters Logo
214 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
